Old Dec 11, 2011, 08:20 PM
drmgcm is offline
Find More Posts by drmgcm
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Okay thanks, yep will stick to my tape method, thanks.
Danny
drmgcm is offline Find More Posts by drmgcm
AP_OZ is offline
Find More Posts by AP_OZ
disenfranchised...
AP_OZ's Avatar
Joined May 2010
THE MEGA MULTI-REPLY!!!
Originally Posted by Ironframe View Post
Hmm - PIDs need setting up I think - bit much jello/shake/instabililility...
CPF
im hearing you - hopefully the new firmware update will improve my hand stability!
Originally Posted by Mike SF View Post
The quality of the flycamone looks good (white balance could be warmer though). Is this the 133 lens you are using? Looks still quite narrow for FPV flight.
The good thing is you can adjust many of those settings using the small LCD screen on the camera. I do agree however that it washes out a little more than the go-pro. On the other hand it does handle low light much better than the go-pro.
Originally Posted by lloydh View Post
I see MWC have removed the original Scarab and the Scarab Euro frames from sale. The $99 euro frame was great value. Ive built up a second euro quad which I was going to sell but I might have to keep it now.
The new roll gimbal looks pretty good. Too bad it dont fit the smaller frame plates.
The new stealth will replace the old euro and original scarab.. Not sure what the price will be but it should be very competitive.
The roll gimble will fit as long as you have a boom mounting spot on the front of the plate.
p.s. keep the quad - he who has the most toys wins!
Originally Posted by Artie in Aus View Post
I would buy several frame plates now for the Euro, they may decide to stop supplying those in the future. All other parts are available on ebay etc...In fact I have 1 spare might get another and knock up a spare airframe...
The smaller plates will continue to be sold... They come in handy when running a second paris board and for the Stealth when it gets released.
Originally Posted by drmgcm View Post
Hey guys, i never did get a reply to this post, just curious if leaving the zip ties on is a viable idea?
Leaving the zip ties on is ok. I usually balance with the zip ties and then once i know which spot needs more weight, I apply some CA to that area.
AP_OZ is offline Find More Posts by AP_OZ
Old Dec 11, 2011, 08:42 PM
drmgcm is offline
drmgcm's Avatar
Joined Nov 2005
Thanks AP Oz for your reply.
Danny
Old Dec 12, 2011, 03:59 AM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Frist photo on the multiwiicopter page is small scarab with the V2 plate
quadslo is offline Find More Posts by quadslo
Old Dec 13, 2011, 03:29 AM
salisbug is online now
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Melbourne, Australia
Joined Jun 2002
Shane finally received his Scarab, built by Dean.
Shane couldn't wait for:
  • daylight (it was just about dark)
  • sobriety (he wasn't driving so he had a few tinnies under his belt
  • a suitable site (who needs a park when there is a thin strip of grass between a major highway and a packed carpark?)
Shane did a great job of controlling it - I guess being an experienced chopper pilot does have its advantages....
Please excuse the quality. As mentioned, it was almost dark:
Shane can't wait to try his Scarab (3 min 26 sec)
salisbug is online now Find More Posts by salisbug
Old Dec 13, 2011, 04:34 AM
flightattendant is offline
Find More Posts by flightattendant
Joined Dec 2011
green eye'd monster
hello everybody,
could someone please help me figure out this thing lol. Ive started building my multiwiicopter paris 3 plug and play and considering ive never built, flown, or programed anything like it' Im nearly finished it... BUT! after being interrupted using the GUIconfig and having to unplug and turn everything straight off, whilst i was configuring sub trims on tx.
now all's i got is a constant blinking green led with beeping from esc's at the same rate, I've try'd everything to restart the process and nothing works" not even in the GUIconfig anymore.
flightattendant is offline Find More Posts by flightattendant
Old Dec 14, 2011, 07:06 AM
glambert is offline
Find More Posts by glambert
France, IdF, Châtenay-Malabry
Joined Aug 2010
Hi Guys,
Okay so i'm using a standard JST-XH 4s Balance plug, now i've attached a pic for the pin breakdown, but use a multimeter to check before hand, just in case your plug is wired different, it shouldn't be though.
Then it is just a case of making a plug to tap into pin 1 (Positive for the Pack) and Pin 4 (3s Negative on the pack). You can probably buy a male JST-XH plug i've just not looked yet, however i just made mine for now using an old JST-XH housing and some spare pins i had. As you can see in my second pic, and the last of how the two plug together.
Hope this helps you guys.
All the best
Danny
I did this but I almost damaged my Eagles eyes OSD. It was saved in extremis. The reason is that the OSD does not connect the positive and thus makes a difference between main and OSD power but all negative are connected. The difference in the negative potential seemed to have created a short circuit. Now I am using a 7 gram DC/DC power converter from tracopower. It takes 9-18 Volts in but with a filtered 12 Volts out. Ref is TEL 5-1212.
Gregory
glambert is offline Find More Posts by glambert
Old Dec 14, 2011, 02:50 PM
quadslo is offline
Slovenia
Joined Feb 2011
I've just installed the new engine locks. They work really well. I recommend them to every Scarab owner
Old Dec 14, 2011, 10:35 PM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
+1 absolutely....
Artie in Aus is offline Find More Posts by Artie in Aus
Old Dec 14, 2011, 11:06 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
+1 for the engine locks too. Can't believe I lived without them before!!!
Here's the 4th and final race of the BASP Cyclocross series held at Coyote Point in SF Bay Area (California).
BASP Race #4 - Coyote Point - MWC Aerial Footage (4 min 8 sec)
Time to film something else!
crazyj is offline Find More Posts by crazyj
Old Dec 17, 2011, 04:44 AM
quadslo is offline
Slovenia
Joined Feb 2011
My Scarab HEXii now has a camera mount. Here:http://www.rcgroups.com/forums/showt...6#post20160934
Old Dec 17, 2011, 08:30 PM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
Here are some photos of my Scarab Stealth that's been upgraded to be a FPV Recon. Plus I was bored at home and wanted to play with my new Sony Nex-5n HDR settings...
Here's the link to the Scarab Stealth FPV Recon - very cool little copter.
http://www.multiwiicopter.com/produc...uad-fpv-reconn
Old Dec 18, 2011, 04:19 AM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Very nice Jason. How's it go with all the extra weight? Also, what batts are you using?
Old Dec 18, 2011, 04:37 AM
Ironframe is offline
Find More Posts by Ironframe
Awaiting software update..
Ironframe's Avatar
United Kingdom, Yorkshire
Joined Sep 2011
I have this on my wish list.. Is there any advantage in adding the MWC gimbal to that setup for the GP2? I suppose unless you do flips and expect folks to watch the film (without feeling sick) a few banking turns shouldn't upset too many viewers?
Also it comes with a 5.8GHz tx/rx system for the video, is that ok for the UK? I know it can't be 2.4GHz as it conflicts with our R/C but we seem to have so many limits on what can and can't be used and ours conflict with the standards in the US so there's no uniformity (again)
CPF
Ironframe is offline Find More Posts by Ironframe
Old Dec 18, 2011, 07:05 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
How does the GoPro footage look on the Stealth?
I always thought for a steady quadcopter you needed longer arms plus the stealth seems to ignore the common rule of atleast one propeller diameter spacing between all props.
Just another thing - compared to the larger quads, what changes had to be made to the PIDs?
Stunt Double is offline Find More Posts by Stunt Double
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
