Old Nov 27, 2011, 05:27 PM
drmgcm is offline
Find More Posts by drmgcm
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Originally Posted by Adidas4275 View Post
yes, but with Y adapters you need the props to spin the same direction, since the FC does not know it has 8 motors it has to act like there are 4 for yaw.... where as a true 8 motor config has control of all 8 motors independently.
I have not done it, but many on here have with fairly good results.
Tks for the update.
Danny
drmgcm is offline Find More Posts by drmgcm
Old Nov 29, 2011, 01:57 AM
VegasFreak is offline
Find More Posts by VegasFreak
Joined May 2008
:Hi all I plan on getting the Carbon SCARAB hexiiKopta shown here.....http://www.multiwiicopter.com/produc...opter-multiwii
I plan on using a ReplayXD for video and a fpv unit for visual just not sure how i'm gonna mount everything and what kind of fpv system i'm gonna use. Is everything they recommend a good setup for the camera system i'll be using?
Is the flight control board stable enough to keep the heli in one spot and self level if I get into trouble? How reliable is their electronics and what kind of maintenance(if any) will be needed on motor bearings and everything else?
if all goes well i'll be getting one by next week
VegasFreak is offline Find More Posts by VegasFreak
Old Nov 29, 2011, 05:03 AM
mrrf900 is offline
Find More Posts by mrrf900
Do it once, do it right
New Zealand
Joined Jan 2011
Hi. I have just finished building the hex using all the recommended motors,esc, etc. Still in the process of trimming and fine tuning.
This is my first multirotor. The level mode is a saviour. While flying in acro when things have started to go pear shaped I have just given it a bit of throttle and flicked the level mode.
Hex gains control, I stop holding my breath and can relax, compose myself and bring the hex slowly back to the ground and then breath a sigh of relief.
The carbonbird motors run very smooth and the triple props are fairly easy to balance once you get going.
For a first multirotor I have found this hex a joy to built and very stable to start with.
Only heil's I have flown in the past is a $40 co-axial IR indoor toy.
I am planning to put fvp and camera gear on it once I get proficient at flying.
I have no doubts you will love it.
Cheers
Richard
mrrf900 is offline Find More Posts by mrrf900
Old Nov 29, 2011, 06:51 AM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
I've received the new gimbal for the GoPro to fit the Quad/octa or Trikopta. Made by Multiwiicopter. So I'm just waiting for the servo to come from HK Gimabal has roll compensation.
quadslo is offline Find More Posts by quadslo
Old Nov 29, 2011, 02:11 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Cool are they selling it, I looked yesterday and saw the pic but no link to buy.
Is it direct drive.
Adidas4275 is offline Find More Posts by Adidas4275
Old Nov 29, 2011, 06:38 PM
quadslo is offline
Slovenia
Joined Feb 2011
It is not avalaible yet, but I think it will be soon.
I will be using this servos: http://www.hobbyking.com/hobbyking/s...8760&aff=34224
Old Nov 29, 2011, 11:17 PM
Adidas4275's Avatar
Joined Mar 2011
Why not some savox or futaba's?
Old Nov 29, 2011, 11:35 PM
Stunt Double is offline
Find More Posts by Stunt Double
Multi Rotor Maniac
Stunt Double's Avatar
Australia, VIC, Melbourne
Joined Oct 2007
mrrf900, youre a brave man starting out with an expensive hexacopter as your first multi-rotor!! Although if you do crash a scarab its usually just a broken arm or prop, the central core is super strong. Would be great to live in NZ as an FPV pilot.
Stunt Double is offline Find More Posts by Stunt Double
Old Nov 29, 2011, 11:53 PM
mrrf900 is offline
New Zealand
Joined Jan 2011
Hi, brave or silly, I still havent decided.
Im not intending to do anything other than slow training flights around a rugby field until I get the hang of things.
One of the best things I did was put a piece of a pool noodle on the front arm for orientation. It was been a saviour a few times now. I might even end up leaving it on there.
As far a FPV goes it will be a while till I get to that point.
I have been thinking about FPV though. To a certain point it must be a bit easier to fly as you dont need to worry so much about orientation as you are always looking forward through the camera.
On the subject of FPV, of the people that are using clover leaf aerials, has anyone noticed much loss having it sideways instead of pointing up?
Cheers
Richard
Old Nov 30, 2011, 12:00 AM
Multi Rotor Maniac
Joined Oct 2007
With a nice stable hexacopter im sure you will pick up FPV very quickly.
Old Nov 30, 2011, 12:32 AM
Adidas4275's Avatar
Joined Mar 2011
fpv has its challenges.... your camera resolution needs to be good to pick up detail and little vibrations.
g/l with the hex.
Old Nov 30, 2011, 04:34 AM
quadslo is offline
Slovenia
Joined Feb 2011
Quinton suggested this one, and it was already tested on this gimbal
Old Nov 30, 2011, 12:09 PM
Adidas4275's Avatar
Joined Mar 2011
cool, thanks for the link then. They are digital and metal gear.
Old Nov 30, 2011, 07:05 PM
Mike SF is offline
Find More Posts by Mike SF
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
Richard
I just made this transition to FPV and I find it much easier than I thought. After the first 2-3 flights I could start relaxing (a little). The tricky part for me is not orientation anymore, but altitude. It's not so easy to see if you are going up or down once you reached a certain altitude. But I hope with more flights I get more used to it.
Mike SF is offline Find More Posts by Mike SF
Latest blog entry: Video: an abandoned shipyard
Old Nov 30, 2011, 07:10 PM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
Im suffering the orientation blues... the Tri is much easier than the quad (naturally) looking forward to viewing through the cam.... have it all now cept the goggles but Id like a head tracker.... might have to just jump in here with both feet...
Artie in Aus is offline Find More Posts by Artie in Aus
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 10:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 09:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 05:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 08:45 AM
