Old Nov 14, 2011, 08:01 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Ive been using trex 500 landing gear on my scarab euro but theyre not quite tall enough for what I want to do. Im looking for something like those on the x650 pic below that could be fitted to the scarab. The x650 ones have a specific mounting design that wouldnt work with the flat plate of the scarab. Any ideas?
Im not so keen on the carbon mwc legs. Too much $$$
Stunt Double is offline Find More Posts by Stunt Double
Old Nov 15, 2011, 11:51 AM
Mike SF is offline
Find More Posts by Mike SF
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
Originally Posted by Adidas4275 View Post
thanks, what pins are you using from the lipo? is there a connector designed to connect to the balance connector that isnt on a board?
You get buy connectors here: http://www.dpcav.com/xcart/product.p...cat=252&page=4
Mike SF is offline Find More Posts by Mike SF
Old Nov 15, 2011, 11:58 AM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
I have a quick question for you guys who have moved to 4s, how do you power your video TX?
Mine is 12v so I was looking for a smaller 3s battery to power it, how do I determine how long the lipo can power the vTX?
I have a 200mw vTX could I use a 350mah or 500mah?
Any help would be appreciated?
Where so you mount the battery on the scarab?
I'm using a 400 mW vTX + E-OSD + FPV camera powered throught the balance plug of a 4S lipo. No interferences in the video. I'm using 3 ferrite rings to suppress noise: one at the vTX, one directly at the 12v power distribution behind the balance plug and the third in the 5V UBEC line to the Paris board. I tried a fourth one in my servo line (tricopter), but it did not have any effect so I removed it to save weight.
Old Nov 15, 2011, 12:49 PM
glambert is offline
Find More Posts by glambert
France, IdF, Châtenay-Malabry
Joined Aug 2010
Originally Posted by glambert View Post
With all the feedback received, I thought that I would better do it and test it... Here is it, the Scarab compliant with cabin luggage for frequent travelers... I cut the booms to 12 cm then the 8'' props just not overlap with the frame. This gives a diagonal of about 40 cm. I hesitated between using only the small frames or the quadocta frame but I found it is taking less place in the case with the quadocta frame. Very stable flight when auto level is on. Not tested in FPV yet as I miss some daylight when I come back from work... Gregory
Finally not a good idea for FPV. LOS was ok but way too unstable for FPV, even after trying different PID configurations. Increasing PID gave wobble before having a stable quad...
glambert is offline Find More Posts by glambert
Old Nov 17, 2011, 12:16 AM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
http://youtu.be/8BNojO4uc7I?hd=1
Bay Area Super Prestige Race #2, Sierra Point San Francisco California.
Scarab QuadOctakopta, Carbonbird 775kv motors and Paris v.4 - FTW!
crazyj is offline Find More Posts by crazyj
Old Nov 17, 2011, 12:17 AM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
Originally Posted by AP_OZ View Post
hey guys,
here is something a little different..... i shot this for a mate who removed a 45m (147ft) tree from a backyard in Sydney Australia... Aerial shots were done using a multiwiicopter PARIS Sirius & SCARAB YSiix and hexiicopter - http://www.multiwiicopter.com/produc...opter-multiwii
hope you all enjoy!!
Cheers,
John
http://vimeo.com/31945584
Nicely done John! Lots of great camera angles make it fun to watch all the way through.
Old Nov 17, 2011, 12:37 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
are you flying with the gopro FPV or anther camera?
without seeing the props isnt it hard to tell what the tilt of the multicopter is?
Adidas4275 is offline Find More Posts by Adidas4275
Old Nov 17, 2011, 01:04 AM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
FPV using the GoPro. The camera is tilted down maybe 5 degrees. I mainly look at the direction and distance to the ground to get my bearings in flight.
Old Nov 21, 2011, 09:16 AM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
Here's a video I shot for the Singlespeed Cyclocross World Championship held yesterday (11/20/2011) at San Francisco's Golden Gate Park.
It was an exciting race with costumed riders and many obstacles. It rained a lot, but I was able to fly in the mist between storms. The riders were awesomely-muddy from the course.
Aerial footage was shot using my MultiWiiCopter.com Scarab QuadOctakopta and Stealth all controlled by Paris v.4 Sirius boards.
SSCXWC 2011 - MWC Aerial Footage (4 min 2 sec)
Cheers,
Jason
Old Nov 21, 2011, 09:18 AM
BayAreaCrasher is offline
Find More Posts by BayAreaCrasher
BayAreaCrasher's Avatar
Joined Feb 2011
brilliant
BayAreaCrasher is offline Find More Posts by BayAreaCrasher
Old Nov 22, 2011, 09:27 AM
glambert is offline
Joined Aug 2010
Hello,
A little question on Carbonbirds and triple prop. I just converted my scarab quadocta to the carbonbirds and triples and 4S. I did the first flight test this morning a I noticed that while gentle flying is very smooth and vibration free, when opening widely the throttle I a one of the motors/prop that tends to climb faster than the 3 others, this activates the level correction from my multiwii controller and gives small vibrations while giving me much less power and climb speed than I am used to on the former 3S / 8' prop. The triples are perfectly equilibrated.
Could this be a bad prop with maybe a slightly differents (increased) pitch? Other ideas?
Gregory
Old Nov 22, 2011, 11:25 AM
Adidas4275's Avatar
Joined Mar 2011
Have you calibrated the ESCs?
Might be worth redoing once.
Old Nov 22, 2011, 06:30 PM
glambert is offline
Joined Aug 2010
I did it with the Turnigy programming card. Good idea to double check maybe I have a different timing on this one... Greg
Old Nov 22, 2011, 06:54 PM
Adidas4275's Avatar
Joined Mar 2011
no, calibrate them to the reciever
http://www.multiwiicopter.com/pages/multiwiicopter-wiki
I also get my engines calibrated perfectly in 1 step -> using this combo-calibration-Wii lead I made (below) -
So I now can program all Six/four/Three engines in a single step - hooked direct to the Tx/Rx THRO port -
follow your owners manual ESC calibration procedure : -
Full Throttle ->
PWR to ESC on ->
2 Beeps ->
Throttle to idle ->
3 Beeps - Done!
This is only used to calibrate all engines so the props turn at exactly the same time - it is not used for flying!
Old Nov 25, 2011, 03:56 AM
Nyholm is offline
Find More Posts by Nyholm
Joined Nov 2011
Calibrate the Paris-card/transmitter?
Hi there.
How important is it to calibrate the transmitter to the Paris-card (V4, 0)?
And how do I do then?
I need advice on a basic approach to the Futaba transmitter that fit well when I filming and photograph with Copter'n.
Thanks in advance from a novice at this.....
/ / Thomas.
Nyholm is offline Find More Posts by Nyholm
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
