Old Oct 12, 2011, 10:35 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Nov 2002
BTW, I just tried the new DEV code on my MultiWiiCopter.com Scarab HexiiKopta with great results! No more need for the PPM SUM device with my Spektrum RX!
Thanks to AlexInParis and friends!
Of course this is a dev code, so you use at your own risk!
UPDATE: I just found out that the P value needed to be increased to 11 to fly well - very strange. Don't recommend the DEV code now..
crazyj is offline Find More Posts by crazyj
Old Oct 13, 2011, 12:02 AM
AP_OZ is offline
Find More Posts by AP_OZ
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Great development alex!! should make 6 engines much more obtainable for people now!
p.s. like the look of your hex Jason - have you flown it yet? if so, what do you think?
AP_OZ is offline Find More Posts by AP_OZ
Old Oct 13, 2011, 12:03 AM
AP_OZ is offline
disenfranchised...
AP_OZ's Avatar
Joined May 2010
forgot to ask.....
is there any other new features on the dev version?
Old Oct 13, 2011, 12:17 AM
crazyj is offline
crazyj's Avatar
Joined Nov 2002
Thanks John, yes I flew it with an old Warthox board with Wii gyro using the DEV code because I didn't want to modify the board for a HEX and use a PPM sum. So with that said the copter flies great but I think there's something very strange with the new DEV code. With the stock PIDs (p=4) the copter was really soft flight/gyros were not crisp like usual. The only way to get the copter to fly like my others on 1.7/1.8 was to increase the P to 11!
I'm going back to 1.8/1.7 code and will wait for my new Paris board to arrive in the mail. Then a real flight test will proceed.
Cheers,
Jason
Old Oct 13, 2011, 02:58 PM
Mike SF is offline
Find More Posts by Mike SF
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
Orientation help
I read in another thread that using orange or green blades are the best and easiest remedy to keep your orientation. So I painted the two front blades of my tricopter in orange and it worked really well. Very easy to spot and follow when you are flying. The paint added 1g per blade and I balanced them after the paint job.
Mike SF is offline Find More Posts by Mike SF
Latest blog entry: Video: an abandoned shipyard
Old Oct 13, 2011, 03:02 PM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
Engine clips became loose
Today, after changing the battery, the tricopter started to twitch. When I came home I saw that one of the motor shaft clips became loose. I assume this was the reason for the twitching, since now I can push the prop down without too much pressure.
Old Oct 13, 2011, 03:03 PM
crazyj is offline
crazyj's Avatar
Joined Nov 2002
OK! The HexiiKopta is complete and flying great! The build went very smoothly and quickly. Even the first flight was perfect! The Hexii came out to about 3 lbs. (1360g) ready to fly with the GoPro and a servo-tilt camera mount. FPV gear will be installed shortly as I'm making the FPV gear modular for all my models. Anyways, below is a time-lapse video of the build and the first flight. Enjoy!
MWC Scarab Hexii - Build and First Flight (2 min 43 sec)
Old Oct 13, 2011, 03:32 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Check the other end there is probably a screw to attach the shaft to the bell of the motor.
If not... check if the shaft is all way down in the bell hole.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 13, 2011, 05:11 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
what did you paint it with?
Adidas4275 is offline Find More Posts by Adidas4275
Old Oct 13, 2011, 06:16 PM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
I used Rust-Oleuem Fluorescent and sprayed two layers. Nothing fancy, but the rotating props are highly visible afterwards.
Old Oct 13, 2011, 06:19 PM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
Yes, there is a set screw which looks tight to me. Also the shaft is aligned with the bottom the same as the other motors, maybe slightly more. I will check once I get the clips back in and also use a little lock tight for the set screw.
Old Oct 13, 2011, 06:20 PM
Adidas4275's Avatar
Joined Mar 2011
great idea, i must try it
why just one blade? to save weight?
Old Oct 13, 2011, 06:31 PM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
2 blades, both front blades. The clearly mark the front "face" of the copter.
Old Oct 14, 2011, 12:46 AM
Stunt Double is offline
Find More Posts by Stunt Double
Multi Rotor Maniac
Stunt Double's Avatar
Australia, VIC, Melbourne
Joined Oct 2007
crazyj another fine video. What is the silver material youre using to balance the props? What do you think about the motor and legs visible in your video - are you going to move things around or change the position of the gopro?
Stunt Double is offline Find More Posts by Stunt Double
Old Oct 14, 2011, 01:01 AM
crazyj is offline
crazyj's Avatar
Joined Nov 2002
Thank you sir!
I built the Scarab WRONG with the front legs in front of the booms, they should have been behind the booms instead. I have already fixed this by switching the left and right legs - perfect!
The camera is mounted under the center section on a servo operated tilt mount. I can control the angle of tilt on a slider switch and easily get the motor out of the video frame.
Here's a pic showing the correct leg placement:
And quick pics of my camera mount & FPV stuff mounted:
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 10:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 09:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 05:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 08:45 AM
