Good luck! Jason |
i like the price point on the carbon's but i already own 7 KDA 20-22ls I am looking at revamping my hanger to have a heavy lifting Y-6 and a foldable lighter x4 so I am really looking for heavy lifting motors for my Y-6, the Quad will use my KDAs for now. I am looking at the scarab Y-6 but I really need something that is easy to take apart and put together, as I will be traveling with it, and will have larger gear (like the droidworx with a gimble) from all of your experiences with the larger frame is it easier to remove the booms and put them back together? with the small frame it was hard to work on because you had to remove the FC before working with all the screws. should I look else where for a traveling Y-6? |
Good luck with whatever direction you choose. |
NEW - Indoor Scarab Quadcopter
Here's a new quadcopter that will be offered by MultiWiiCopter.com soon. It is called the Indoor Scarab quad. The new copter is essentially a Scarab 12 Euro but with the smaller CarbonBird 1220kv motors, 8x4.5 props and really short booms.
The Paris 4 with Sirius controls the little copter perfectly. Since the Scarab is so small and lightweight (1.3lbs/580g flying) the PIDs (P) needed to be increased to about 5! Awesome stability and agility with the Paris 4 Sirius! The key to this copter is to keep it LIGHTWEIGHT! Use the CarbonBird 1220kv motors, recommended 8x4.5 props, 10amp ESCs and proper 2200 3s battery and you'll have a winning combination! At 1.3 lbs, you can easily get 15 minute flights with the 2200 3s. For even better performance use a 1600 3s and the copter is going to ZOOM-ZOOM! Here is a video of it being built and test flown by yours truly:
The build commenced at 8am today and the first test flight was at 2pm. Yes, I know, I'm a MACHINE...
Australia, NSW, Sydney
Joined Jun 2011
I wouldn't class that as an indoor quad unless you live in a warehouse!
It doesn't look much smaller than my (hopefully) soon to be completed 'outdoor' quad. More importantly when will MWC release an affordable hex frame kit along the lines of the scarab 12. That's what I'm hanging out for!
The best thing you can do is just build the model to fit the requirements through the use of bullet plugs. It wont be very difficult.. I have pulled apart my hex a few times to travel with and it probably takes about 20 mins to pull apart and pack up and about the same to put back together. This could be done quicker but i am quite pedantic with my models and check, double and sometimes triple check components. The only thing I would recommend is making sure you have heaps of spare hardware so you dont strip the screws and can't reassemble. |
yeah, i already have bought like 3 packs of your 2mm button head screws and the scarab tool. I just sold my original scarab 12 frame, so hopefully soon ill be building my Y-6 |
| Thread Tools | |
| Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid | hercdriver7777 | 3D Foamies | 556 | May 07, 2013 02:23 PM |
| Discussion Radical RC Stick 400 Build Thread~~~Now with Video | Carnifax | Electric Plane Talk | 181 | Oct 08, 2012 09:43 PM |
| Question Skywalker 3 Build Advice and Eventual Build Thread! | Ecibob | Video Piloting (FPV/RPV) | 2 | May 01, 2011 04:46 PM |
| Discussion Easyglider Build Thread (Help wanted) | worzul | Foamies (Kits) | 2 | Mar 18, 2011 07:45 AM |
