Old Oct 04, 2011, 09:28 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i have gone to using cheap al 12mm boom from ebay and i just cut them
i put a wooden down inside of the for about 2" to keep them from bending at the boom mount.
they are a little thinner but they work well with the wooden dowel.
Oh, and i run my wires outside the booms to speed the repair process up
Adidas4275 is offline Find More Posts by Adidas4275
Old Oct 04, 2011, 09:43 PM
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
Tricopter servo not working
I'm almost ready to maiden my SCARAB Tricopter, but I cannot get the tail servo working. It's not doing anything.
* I'm using the Paris 4.0 board powered by a UBEC
* The servo is connected to the e3 "port" of the Sirius, same as all 3 ESCs.
* I can arm the board and all engines are working when I move throttle, ELV and AIL
* I can connect the servo directly to the RX and it's working fine
* The GUI config shows a tricopter configuration with 3 engines and one servo.
* In the GUI config, the servo bar moves together with the YAW bar. So the board knows there is a servo and it can 'control' it.
* I did all calibration (1095 - 1500 - 1905, ESC throttle end points)
I must be missing something. It's seems there is no 'power' going to the servo.
Any ideas what's wrong?
Mike.
Mike SF is offline Find More Posts by Mike SF
Old Oct 04, 2011, 10:10 PM
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Salisbug,
you might want to invest in a simulator for your pc/mac which ever you use.
Pays off in the long run if you realy want to learn to fly with confidence, and pay less on crash parts.
Danny
Originally Posted by salisbug View Post
Just glancing over at the airframe last night I noticed that one of the booms was a bit droopy (I bet we've all been there before).
A closer look revealed 2 bent booms . Well, it did go in at a fair rate of knots. Just as well they sell a crash kit.
May need a few at this rate......
drmgcm is offline Find More Posts by drmgcm
Old Oct 04, 2011, 11:47 PM
Adidas4275's Avatar
Joined Mar 2011
from my experience, just learning to fly... it took about a month of me flying like a whimp and crashing from the simplest dumb thumb issues..... I flew small helis like the MCX, MSR and 120SR but nothing bigger or better and I am a proficient fixed wing pilot.
after that month the only crashes I have had since have been prop failures (solved by moving to APCs and not EPPs)
I am sure Ill make a dumb mistake soon and pay for it, but the scarab and other frames are really strong, the only think I seem to break is the booms and a motor mount...
I pulled the wires out of one motor..... that was my worst crash.
Sims are great, but a $100 sim is more than i paid in all my crash repairs (not including the unnecessary upgrades that I did while repairing )
Old Oct 05, 2011, 01:45 AM
France, IdF, Châtenay-Malabry
Joined Aug 2010
Originally Posted by Adidas4275 View Post
i find the KEDA motors to be in good balance....
i have not used the scarab hard mount, but it seems that it would be easy to get some vibrations to the camera with it....
i know others have made vibration isolating motor mounts that seem like a cool idea as well..
but all the high-end gimbals use vibration isolation or dampening
In went back to the OEM Gopro 3M mount attached directly under the frame. The result is no more gello as well as no props seen in the video.
Maybe Quinton should work on developing isolating boom mount made with rubber for it's Gopro mount.
Gregory
glambert is offline Find More Posts by glambert
Old Oct 05, 2011, 07:17 AM
disenfranchised...
AP_OZ's Avatar
Joined May 2010
Gregory
I've found that firm mounts are better than using soft material to absorb vibrations.
Best bet is to ditch the go-pro and get a ccd based camera for HD recording.
AP_OZ is offline Find More Posts by AP_OZ
Old Oct 05, 2011, 09:57 AM
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
WOOOHOOO... got my motors from MultiwiiCopter.com....
What kind of solder should i use and any specific kind of solder gun? wattage?
w2hef is offline Find More Posts by w2hef
Old Oct 05, 2011, 11:36 AM
Adidas4275's Avatar
Joined Mar 2011
I understand you have much more experience, but all high end mounts are isolated from the frame.
The gopro is a nice camera for what it is, are there better waterproof, impact resistant, light, inexpensive wide angle camera?
Is it cinema quality, no...... Does it need to be?
Old Oct 05, 2011, 11:46 AM
BayAreaCrasher's Avatar
Joined Feb 2011
What is a good alternative for the go-pro for video that is not tremendously expensive?
BayAreaCrasher is online now Find More Posts by BayAreaCrasher
Old Oct 05, 2011, 05:04 PM
Joined Feb 2011
Here is my new compilation shot with the Scarab 12 Quad/Octa and the GoPro.
http://www.youtube.com/watch?v=pny6QIrjJKw
quadslo is offline Find More Posts by quadslo
Old Oct 05, 2011, 05:31 PM
drmgcm's Avatar
Joined Nov 2005
Strange Problem. On Paris V4
Came across a really strange problem today, i went out for a spot of flying and the #3 motor (Forward Left on X quad) kept on shutting down, lucky for me it was before take off. I did manage to get a short flight in eventually, but as soon as i landed and tried to take off the #3 motor would shut down just before take off and quad would tip over.
I've never seen this before, the motor was not excessively hot, nor was the ESC, so i am counting out thermal shut down.
Anyone else ever had this before?
Also i did a bench test about 20 mins later to see what would happen, and the same happens on the bench, #3 motor shuts down.
This is really bizzare.
Danny
Old Oct 05, 2011, 07:02 PM
Adidas4275's Avatar
Joined Mar 2011
great video..
do you fly FPV, LOS or both?
here is my latest
Heli Watching From the Air.mp4 (3 min 5 sec)
Old Oct 05, 2011, 07:25 PM
Joined Feb 2011
very very cool. is most of that done FPV or LOS?
Old Oct 06, 2011, 12:50 AM
Multi Rotor Maniac
Stunt Double's Avatar
Joined Oct 2007
that was really cool quadslo. A bit random but nice smooth footage
Stunt Double is offline Find More Posts by Stunt Double
Old Oct 06, 2011, 02:23 AM
Joined Feb 2011
All this is done without live downlink, but I also fly FPV.,
Here you can see my other videos. I've changed my account. So here are just my multicopter videos.
http://www.youtube.com/user/MultiWiiCopter?feature=mhee
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 556 May 07, 2013 02:23 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 181 Oct 08, 2012 09:43 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob Video Piloting (FPV/RPV) 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
