Old Sep 19, 2011, 11:02 AM
w2hef is offline
Find More Posts by w2hef
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
awesome
OK.. you have convinced me... how's the quad to fly... i have a witespy now and trying to learn more... i do want another quad...
should i go with 14amp ESC's or is 10 enough.
motors.... they are out of stock on them...
any suggestions... that video was awesome...
Originally Posted by crazyj View Post
Here's my latest video - chasing a ST-Models FW-190 around the field with my Scarab QuadOcta running a Paris v.4 board and Sirius 600
http://www.youtube.com/watch?v=iUkNXNBOA4w&hd=1
w2hef is offline Find More Posts by w2hef
Old Sep 19, 2011, 11:07 AM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Great! The HobbyWing 10amp ESCS (same a Turnigy Plush) are a perfect match for the Scarab QuadOcta with CarbonBird motors:
http://www.multiwiicopter.com/collec...-10-amp-flyfun
I'm glad you liked the video - should see some of my others!
http://www.youtube.com/user/bigguyyyy365?feature=mhee
crazyj is offline Find More Posts by crazyj
Old Sep 19, 2011, 11:42 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
can i use the 14's esc's...
anything else i should know about... will order everything tomorrow.
how's there shipping times?
i'm assuming i can use my DX8 spektrum with a good 2.4 receiver.
how about wiring.. will i have enough with the motors and the esc's?
Old Sep 19, 2011, 11:47 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
so far i have:
Carbon SCARAB Quad/Octa 12mm airframe 175mm Core - Multiwii FRAME
PARIS - HEX/YSiix Sirius®600MP+ - v4.0 LLC Plug-n-play board
4 ESC HobbyWing® 10 amp - FlyFun
SCARAB frame tool - deluxe - 1/16th 1.5875mm
CarbonBird Motor - Set of 4 - 775kva Brushless Multicopter Motors - OUT OF STOCK ??
Pro Photography Props Set 10"x4.5 CW/CCW - QuadCopter
What else will I need.... Can i find the motors somewhere else, as they are backorder?
Old Sep 19, 2011, 11:53 AM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
What brand 14amp ESCs are you looking at? The Plush/Hobbywing 10amps are well suited. 14amp is OK current-wise but you'll be adding weight with larger ESCs.
Yes a DX8 is great, I use a JR 11x with a Spektrum AR7010 with a satellite mounted on the rear carbon leg (away from my FPV VTX).
If you get the CarbonBird motors, they have long enough leads to make it all the way through the booms. You'll need maybe a few inches of 14awg wire to solder the ESCs together for the battery connection.
I live in California, and it takes about 1 week for the stuff to arrive from Australia - not sure if it would be faster or slower to ship to NY.
so far i have:
The motors should be arriving soon - that is the rumor. They are not sold anywhere else and are specially designed for the Scarab (low KV, good bearings and long wires). There are other motors (KDA) that will work too take a look here:
http://www.multiwiicopter.com/pages/gear-list
You will need a 4s 2200 battery - probably the best battery for the Scarab QuadOcta on CarbonBird motors. If you go with different motors then you might need to revise the battery and ESC selection!
The 9050 three bladed props are really good, I suggest getting those instead. or the 12" props for heavy lifting/hovering. The three-bladed props are great for fast forward flight and good-overall.
Old Sep 19, 2011, 12:01 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
Thanks... like i said i'm looking for a step up from the witespy... the others i looked at where the GAUI, MK $$$.... i'm assuming you did a lot of research and are very happy with this one... RIght?
Old Sep 19, 2011, 12:14 PM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
Yes, the Scarab QuadOcta is a step up from the WhiteSpy. It's larger and is a more advanced design with the ability to tilt the motors for better YAW. Slender booms make for efficient prop/thrust and flight times. Flight times are pretty good with small batteries and power/performance is hard to match. Plus it has a nice way to hold the GoPro camera.
Old Sep 19, 2011, 12:17 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
dang... the quad board is out of stock... is the tri/6 easier to fly than the quad?
would the hexa version be more stable... i'm a photographer and i want to use this for wedding overheads..
the quad board is out of stock and the motors are too!
Can i use different motors... I'll need six then. what size would be good?
thanks for all you help..
Old Sep 19, 2011, 02:15 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
opinions:
Should i get the Scarab QUADocta and wait for the PARIS board & motors to get back in stock?
or go with the Carbon SCARAB YSiixKopta and just have to wait for the motors?
I want something stable!
Old Sep 19, 2011, 02:46 PM
drmgcm is offline
Find More Posts by drmgcm
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Power to GoPro
Hi Guys,
Can the gopro be powered externally using the usb plug on 5v without having the main battery in it? or does the battery have to be in the gopro to use the usb as a power source?
Just curious as the battery is like around 30g in weight, it would be great to get rid of that weight.
Danny
drmgcm is offline Find More Posts by drmgcm
Old Sep 19, 2011, 02:48 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by drmgcm View Post
Hi Guys,
Danny
http://fangin.com/blog/2011/08/25/go...al-lipo-power/
Dialfonzo is offline Find More Posts by Dialfonzo
Old Sep 19, 2011, 02:54 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
opinions:
the boards are the same just solder some servo wires on and load the quad sketch....
Adidas4275 is offline Find More Posts by Adidas4275
Old Sep 19, 2011, 02:57 PM
drmgcm is offline
drmgcm's Avatar
Joined Nov 2005
Originally Posted by Dialfonzo View Post
Hi Dialfonzo,
thanks for the link, i'll see what i can come up with didn't read anything on there about him taking the battery out of the camera prior.
Danny
Old Sep 19, 2011, 03:07 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
really? awesome... got some learning ahead.... do you have a visual or document for that..? ALso, i'm hung up on MOTORS since they are out of stock... any ideas for that? thanks.
Old Sep 19, 2011, 03:08 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
Also, has anyone built the Carbon SCARAB YSiixKopta... i'd like to get some feedback on it.??
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
