Old Mar 15, 2013, 10:01 PM
piccolo831 is online now
Find More Posts by piccolo831
Scarab Pro Pilot
piccolo831's Avatar
United States, CA, Capitola
Joined Jan 2011
Originally Posted by Edkirk View Post
Just finished my Scarab EDF Avatar, flies great. Plan to have it at the Multirotor Challenge next week.
http://www.multirotorchallenge.com/
I hope to see some of the west coast guys there.
That thing must eat batteries alive... 3 edfs and such...
piccolo831 is online now Find More Posts by piccolo831
Old Mar 15, 2013, 10:08 PM
Scarab Pro Pilot
piccolo831's Avatar
Joined Jan 2011
Originally Posted by crazyj View Post
Looks like a Hunter-killer from SkyNet - hope it's not self-aware yet...
Cool, that you're representing the Scarabs at the fun-fly. We're having a MutliRotor fun fly event soon in the Bay Area - I'll be there with my fleet.
http://fpvlab.com/forums/showthread....5th-Fremont-CA
Jason
Will I be able to sign up for that fun fly too?
Old Mar 15, 2013, 11:22 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Originally Posted by piccolo831 View Post
Jason
Sure - do it fast because it sounds like space is limited.
crazyj is offline Find More Posts by crazyj
Old Mar 15, 2013, 11:25 PM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
This is off-topic but the new YouTube channel design is horrible! For those who haven't switched don't do it - there's no return!
https://www.youtube.com/user/bigguyyyy365
Old Mar 15, 2013, 11:55 PM
Killroy1999 is offline
Find More Posts by Killroy1999
Joined Jun 2012
Unfortunately, I use Spektrum radios and receivers. Their fail safe keeps the last-know position of the channels and moves the throttle to whatever position you had when the RX was bound to the TX (I usually set 35-40% throttle for a gentle decent). You can't rely on a Spektrum system to go from MWC manual mode to GPS home when the RC link fails.
Perhaps Futaba's and other brands have better fail-safes.
EDIT: Most Spektrum receivers have only the Throttle fail-safe, unless you pay $$$ for their high-end receivers 8ch and up.
I don't have GPS, but GPS makes a lot of sense for the RTH mode.
My Futaba T8J allows you to set each channel to NOR (normal), which holds the the servo in the last commanded position.
OR
You can set each channel to 1-100% for fail safe.
I tested out the fail safe with the YSiix bound down and there is at least a 1 second delay, that means that if you are rolling and if fail safe comes on when you go behind a structure, then by the time you regain control you may be upside down, right?
That is why I though it may be beneficial to set the fail safe of AUX1 to turn on the LEVEL Flight mode and maybe AUX2 to turn on BARO, so you don't loose any altitude. That may give you time to get a signal.
Killroy1999 is offline Find More Posts by Killroy1999
Old Mar 16, 2013, 12:31 AM
Deet_aus is offline
Find More Posts by Deet_aus
I have a video for that
Australia, SA, Adelaide
Joined Apr 2012
My failsafe selects RTH, which also selects Angle, Baro and Mag
This is with throttle at mid stick also
Roll, Pitch and Yaw go to mid stick
Deet_aus is offline Find More Posts by Deet_aus
mrrf900 is offline
Find More Posts by mrrf900
Do it once, do it right
New Zealand
Joined Jan 2011
I use Spektrum and I can bind it so if fail-safe kicks in it will put all channels at bind position.
Set channels and switches, put bind plug in, power receiver, remove bind plug, holding bind button power on transmitter.
mrrf900 is offline Find More Posts by mrrf900
Old Mar 16, 2013, 01:30 AM
Groboz is offline
Find More Posts by Groboz
Groboz's Avatar
Australia, NT, Darwin
Joined Oct 2012
Strange thing happened today. I flew one battery, landed and fitted another one (new only 2 recharges). Took off and hovered while making small trim adjustments when the carbon armour just lost all power and fell out of the sky. Lucky I was only a metre off thick grass so a nice soft crash.
The battery was fully charged and I fitted another Lipo but apart from the start up tune there was no three beeps pause and a further beep signifying a 3 cell battery was connected. The Andromeda wasn't lighting up and stick inputs on the Tx did nothing.
Diagnostics so far has power to the board with red and green lights lit as well as the GPS. A rhythmic beep every 4 or so seconds has the motors twitching in sync so power going there (one wasn't twitching at first so I swapped that ESC but apart from now twitching with the others that didn't help).
I've checked all wires and they appear to be intact and I tested each of the 5 way JST power connectors with a multimeter and they're all relaying 12v.
My guess it's a ESC issue but apart from replacing the most suspect one I don't know what else to do. Anyone got any ideas.
Groboz is offline Find More Posts by Groboz
Old Mar 16, 2013, 04:16 AM
thequieteuropean is offline
Find More Posts by thequieteuropean
the best laid plans.......
thequieteuropean's Avatar
somewhere east of the pond
Joined Jun 2007
slow intermittent beeps normally point to lost rx signal, as in no reciever connected.
sure the soft crash did not dissconnec your rc somehow?
rio
thequieteuropean is offline Find More Posts by thequieteuropean
Old Mar 16, 2013, 08:11 AM
Thai is offline
Find More Posts by Thai
Shipped to work. Wife safe.
Thai's Avatar
Canada, eh?
Joined Jan 2007
Can you share the magic? Thanks.
Also, all work and no play, so I brought it to work today.
Thai is offline Find More Posts by Thai
Old Mar 16, 2013, 11:25 AM
crazyj is offline
crazyj's Avatar
Joined Oct 2002
Which RX are you using? My AR 6ch and 7ch RXs don't do this - plug your copter into the computer/GUI and then turn off the transmitter you will see what the different channels do when signal is lost.
Old Mar 17, 2013, 12:21 AM
Thai is offline
Thai's Avatar
Canada, eh?
Joined Jan 2007
Got my motors balanced pretty good now. No more jello or vibrations with the GoPro 3 Black.
Shot this at my work today. Outside and in the warehouse, there was too many customers in the store to do there, but I'll probably add on to this once I get a chance.
Let me know what you think!
Royal Distributing - MultiWiiCopter SCARAB Vampire HexiiCopter (4 min 20 sec)
Old Mar 17, 2013, 01:08 AM
Scarab Pro Pilot
piccolo831's Avatar
Joined Jan 2011
http://www.youtube.com/watch?v=evy_grNVKDk&hd=1
The GoPro really does help with the jello effect removal. Did you use the YouTube stabilizer option? The indoors one looks weird to me. Outdoor looks great.
Old Mar 17, 2013, 01:18 AM
Thai is offline
Thai's Avatar
Canada, eh?
Joined Jan 2007
Yeah the indoors ones was the result of YouTube's stabilization. I need more practice indoors. Gets pretty nerve racking with narrow isles so I'm a little shaky with corrections. It'll get better. Hopefully good enough this summer to get on Multiwiicopter's video page.
Old Mar 17, 2013, 01:21 AM
Scarab Pro Pilot
piccolo831's Avatar
Joined Jan 2011
Just wait til you start FPV'ing... a whole new lvl of exciting =)
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 09:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 07:45 AM
