Joined Aug 2012
Hi I'm new. I have here a http://www.multiwiicopter.com/produc...lectronica-fpv. I'm new and I can not understand why spinning like a top to the left then to the right on the ground and I can not lift it. Really need your help.
All the Scarab Tri airframes need reverse yaw set in the sketch file (firmware) |
Look for the code section under Conf.H in the MultiWii ardunio code and choose the reverse rotation for the tricopter yaw. Then upload the modified code to the ardunio. :-) /************************************************** ***********************************************/ /**************** SECTION 2 - COPTER TYPE SPECIFIC OPTIONS *******/ /************************************************** ***********************************************/ /******************************** TRI *********************************/ //#define YAW_DIRECTION 1 #define YAW_DIRECTION -1 // if you want to reverse the yaw correction direction /* you can change the tricopter servo travel here */ #define TRI_YAW_CONSTRAINT_MIN 1100 #define TRI_YAW_CONSTRAINT_MAX 1900 #define TRI_YAW_MIDDLE 1500 // tail servo center pos. - use this for initial trim; later trim midpoint via LCD |
Joined Aug 2012
Joined Jul 2012
testing my scarabs position hold in a reasonable breeze, 12-14 mph and gusty, switched PH off at around 42secs, apologies for my poor video compressions skills and shakes.
http://www.youtube.com/watch?v=207qtilTr8Q |
Joined Jun 2012
4 months or so to Christmas, right? Pretty sure I've been a good boy this year.
Joined Jan 2005
Avatar Maiden
Finally got time to fly this evening. 4 packs back to back so far and getting things dialed in. I'm probably going to fly Los for a while and then install the fpv gear I bought with the kit.
Super impressed with this platform. Kit went right together and flew very nicely right out of the box. This will be my 8th fpv model and I must say this has been the smoothest build so far! |
| Thread Tools | |
| Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid | hercdriver7777 | 3D Foamies | 558 | May 22, 2013 11:14 AM |
| Discussion Radical RC Stick 400 Build Thread~~~Now with Video | Carnifax | Electric Plane Talk | 181 | Oct 08, 2012 09:43 PM |
| Question Skywalker 3 Build Advice and Eventual Build Thread! | Ecibob | Video Piloting (FPV/RPV) | 2 | May 01, 2011 04:46 PM |
| Discussion Easyglider Build Thread (Help wanted) | worzul | Foamies (Kits) | 2 | Mar 18, 2011 07:45 AM |
