Old Apr 08, 2012, 04:59 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Nov 2002
Originally Posted by AP_OZ View Post
Attachment 4767055 and then there was eight.
Very interesting! Can't wait to see the end results.
crazyj is offline Find More Posts by crazyj
Old Apr 08, 2012, 05:03 PM
IconFlyer is offline
Find More Posts by IconFlyer
Joined May 2011
Originally Posted by Tretch5000 View Post
i had the same issue with my hitech servo's. i ended up taking it apart and adding so heavy weight grease inside to get rid of that 1 degree of backlash. worked like a charm. i would say it's for sure the gain settings. i noticed if i went to high it wanted to correct extremely fast causing a quick snap in the video picture. looked good from the ground. but when i played it back it was jittery. so i kept playing with my gains until i got it right for my machine. fly it in manual mode. not gps OR atti. just fly it normally and see if you get the same results. i ended up with 130 for my gain setting across the board. the twitching went away when i used manual mode but when i would go into height hold or gps mode it would come back. try that i think what you may be seeing is the copter correcting it'self very fast. the servo cant react that fast.
Great advice...thanks so much, I will experiment with different gain settings although I think mine are too low...basically it doesn't correct until it's too late at which point it corrects aggressively.
IconFlyer is offline Find More Posts by IconFlyer
Old Apr 08, 2012, 06:28 PM
jimfc is offline
Find More Posts by jimfc
So I have a head on my butt.
jimfc's Avatar
United States, FL, Palm Harbor
Joined Dec 2010
I'm stoked!
Although it is quite windy today, I decided to try a test on the battery on my Scarab Y6 - I flew it around straight for 13 minutes before landing. It still had at least a couple more minutes of flight time left when I checked the battery cells! Wow, never thought I would get that much flight time. Battery is a 3000mah 4S battery Sky Lipo. I have a 2650mah to still test.
Still no issues with the erratic flight I was having.
Jim
jimfc is offline Find More Posts by jimfc
Old Apr 08, 2012, 06:35 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
nice jim, glad it is back in the air
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 08, 2012, 06:36 PM
jesusita1918 is offline
Find More Posts by jesusita1918
Joined Mar 2012
IconFlyer -
Can you post a picture of your direct arrangement with the Scarab gimbal. Reading your postings you have me interested in not having the gimbal problems you first experienced.
jesusita1918 is offline Find More Posts by jesusita1918
Old Apr 08, 2012, 06:38 PM
jimfc is offline
jimfc's Avatar
Joined Dec 2010
Thanks!! Me too!!
BTW - I mistyped and indicated a 3S, that should have been 4S, I corrected the original post!
Old Apr 08, 2012, 07:59 PM
jimfc is offline
jimfc's Avatar
Joined Dec 2010
Here's a link to an interesting looking 3-axis gimbal mount for the GoPro.
http://www.shapeways.com/model/20725...tml?gid=ug5911
Jim
Old Apr 09, 2012, 09:51 AM
Joined May 2011
Originally Posted by jesusita1918 View Post
IconFlyer -
not pretty yet but 50 grams lighter
Old Apr 09, 2012, 10:22 AM
crazyj is offline
crazyj's Avatar
Joined Nov 2002
Jim
It's rubbish for what we're trying to do - trust me I bought one a long time ago...
Hope you have some super heavy grease in the servo gears to reduce any backlash-wiggles with the direct mount.
Old Apr 09, 2012, 10:23 AM
crazyj is offline
crazyj's Avatar
Joined Nov 2002
Objective: Find and record smooth AP and have fun while doing it!
Results: It's amazing how much beauty and history can be found down roads that are less traveled. These views were captured in San Francisco Bay Area, and are absolutely stunning!
Both the Scarab Triikopter and FPV Reconn were used to shoot this video. The Scarabs are both flying with the Paris V.4 Sirius, and are powered by the CarbonBird.com 775KV motors. You can't go wrong with the Scarabs!
MultiCopterPilot.com Scarab Triikopter and FPV Reconn: California Cruising" (2 min 6 sec)
Old Apr 09, 2012, 10:35 AM
djdavid60 is offline
Find More Posts by djdavid60
If it flies, I can crash it!
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
Great video crazyJ. You are getting me stoked to get my Y6 out in the wild!
djdavid60 is offline Find More Posts by djdavid60
Old Apr 09, 2012, 10:59 AM
jimfc is offline
jimfc's Avatar
Joined Dec 2010
Thanks Jason - I'll save my money!
Jim
Old Apr 09, 2012, 11:07 AM
Joined May 2011
The backlash is no different than when using the pushrods/bearings/boom block assembly...but yeah I'm going to try the heavy grease or even some sort of constant tension(rubber band or something).
Old Apr 09, 2012, 05:36 PM
Joined Mar 2012
Thank you for the pictures on the direct connection to the servo. If it works then the process is perfect.
Old Apr 09, 2012, 05:44 PM
Joined Mar 2012
Changing values using the MultiWiiCon_1_9 screen
I am trying to change values on the MultiWiiCon_1_9 screen and cannot figure the process.
I am reading the Paris board and it is reflecting motion about the three axis. The throttle and controls are alive I just cannot figure how to change values for in calibrating the transmitter.
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 634 Nov 16, 2014 10:06 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 09:55 PM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 05:46 PM
Discussion Easyglider Build Thread (Help wanted) worzul Foamies (Kits) 2 Mar 18, 2011 08:45 AM
