Old Nov 14, 2012, 10:51 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
Water and trees! Very brave.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Nov 15, 2012, 06:06 AM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
If i build MR, i will go for MK or AeroQuad or maybe YS-X6. But for fixed wing, APM is the best in term of cos and simplicity. Just choose a normal airframe like Skywalker, download everything needed, copy SW PID's from the web, calibrate your tx with GCS, set your plane level, set your default home altitute, charge your batteries, check your battery location related to CofG, set flying mode (a bit tricky here, manual, stabilize, fly by wire A, fly by wire B, RTL and Auto - all my other AP is very simple, CC only 2 mode CIC and PIC, Ptreyx also 2 mode manual/auto and MK 4 mode manual/PH/CH/AH) and you ready for flying.
Upon arrived at flying field, on tx, connect battery, wait for GPS locked by looking at blue LED blinking under the GPS unit and you good to go. Once you in the air, you got all the flying mode except Auto.
It is really not difficult if you already have some experienced with other type of autopilot.
Meez is offline Find More Posts by Meez
Old Nov 15, 2012, 07:15 AM
cyberbillp is online now
Find More Posts by cyberbillp
cyberbillp's Avatar
United States, FL, Melbourne
Joined Mar 2012
Florida
Haha. Around here, this is as wide open as it gets.
The stupid wind is brutal too.
cyberbillp is online now Find More Posts by cyberbillp
Old Nov 24, 2012, 12:11 PM
MtnSnowFlyer is offline
Find More Posts by MtnSnowFlyer
United States, AK, McKinley Park
Joined Dec 2010
Anyone have any real world experience with operating these things in very cold temperatures? I'm talking -40. Also -10 to -30 are common where I live in the winter. I recently discovered that my Paris multiwii v4 r5 board(on a quadcopter) doesn't seem to like these temps and rather than get a new type of fly-it-yourself board it might be fun to dabble with a full autopilot. I definitely like the price of the ardupilot.
Anybody out there with real world experience on this topic?
By the way, straight up rc planes and my tricopter (with a KK v.1 board) seem to do just fine in these temps. Check out a couple of my videos from last winter. Winter is a great time to fly here as usually the air is quite still.
Flying an RC plane at 40 below zero, plus some fun science. (3 min 31 sec)
Happy Sun Dog New Year - Watch in HD! (1 min 48 sec)
MtnSnowFlyer is offline Find More Posts by MtnSnowFlyer
Old Nov 24, 2012, 12:27 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Not that cold here yet.
I was out flying my APM 2.0 the other day at around 0 or 5 above - It depended on which thermometer I was looking at.
My flight was brief only being about 10 minutes total. The APM was entirely exposed to the temperature and if you count the transit time from home to flight I would guess that my APM was outside at that temperature for about 30 minutes before I flew.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Nov 24, 2012, 12:38 PM
AMA 937634
Stone1295's Avatar
Joined Jan 2010
Oh yeah, I should've mentioned that I didn't appear to have any problems.
I was testing out my new SkySurfer and my APM and servos worked well. I'll eventually place the APM into my Skywalker but I wanted something cheap and readily available in the US so I don't have to wait a month and pay a lot for the over seas shipping if something goes wrong.
I'll work my way up to longer flights eventually but this first, brief, flight was only to test some of the settings and the manual and stabilize modes. No waypoints or RTL tests on this flight.
-Mike
Old Nov 24, 2012, 05:58 PM
brakar is offline
Find More Posts by brakar
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
I did have a lot of flights with the flexipilot (as in pteryx and easyuav) last winter at temperatures between -15 and -25C, never noticed any difference. Except as mentioned, still and heavy air, (and stiff fingers).
brakar is offline Find More Posts by brakar
Old Nov 24, 2012, 06:17 PM
Joined Dec 2010
Thanks Mike! That's good to know. Hopefully it gets colder for you soon so you can do some testing for me.
Rob
-Mike
Old Nov 24, 2012, 07:00 PM
AMA 937634
Stone1295's Avatar
Joined Jan 2010
Well -40 isn't too common this close to the ocean but we do typically have some -20 weeks in February or March.
It's hovering around 10 above at the moment and the wind is around 7mph so today would've been another good day for test flights but I got bogged down on work around the house.
-Mike
Old Nov 24, 2012, 07:43 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
There are many consumer gyros that don't play well when it is cold. Not sure about the Wii stuff but I can say that any of the HobbyKing stand alone gyro's will not participate if it gets in the single digits (F)
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Nov 26, 2012, 09:43 AM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Servos themselves often don't like extreme cold. Some have speculated that the grease inside can congeal at those low temperatures. I suspect that higher quality servos such as Futaba or Hitec won't be nearly as affected as cheaper brands. I say that because I personally have used both Futaba and Hitec servos on many projects over the years, and some were used extensively in the winter in MI. I don't remember tryingthem out in temps well below 0, but did quite a bit of RC activity around 5 degrees and never had a problem.
philthyy is offline Find More Posts by philthyy
Old Dec 15, 2012, 10:29 AM
cyberbillp's Avatar
Joined Mar 2012
Nice video btw.
Old Dec 15, 2012, 10:45 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
RCTimer APM2.5
Has anyone had any problems with these? Are they just as good as the ones from 3DR? http://www.rctimer.com/index.php?gOo...2&productname=
Iím getting ready to make an order and would like some inputs.
RC Man is online now Find More Posts by RC Man
Old Dec 15, 2012, 12:25 PM
kempo is offline
Find More Posts by kempo
kempo's Avatar
United States, CO, Denver
Joined Nov 2008
I don't know if IKE1 has bought something but my recommendation is UAVDevBoard.
Great support, great community.
Here is my build log (pictures, videos):
http://www.rcgroups.com/forums/showthread.php?t=1610263
kempo is offline Find More Posts by kempo
Old Dec 15, 2012, 08:56 PM
Khosravi is offline
Find More Posts by Khosravi
Chris Khosravi - KK4LJH
Khosravi's Avatar
United States, GA, Marietta
Joined Jul 2004
I have 4 of them and they work excellent. I can't compare these APM 2.5's with the real APM 2.5's but I used to have a real APM 1 and they perform better because of the better sensors on board.
- Chris
Khosravi is offline Find More Posts by Khosravi
Discussion Can anyone recommend a rc helicopter that handles wind well. Allan Gibbs Beginner Training Area (Heli-Electric) 47 May 07, 2011 11:10 AM
Discussion Can anyone recommend simulation software that will work on a Mac? Allan Gibbs Beginner Training Area (Heli-Electric) 3 Apr 22, 2011 12:51 PM
Discussion Can anyone reccomend a good Power supply. Goleith Batteries and Chargers 12 Mar 07, 2011 03:25 AM
Discussion Can anyone recommend a good self-righting speedboat that can handle saltwater? Fairmont Dock Talk 14 May 20, 2008 06:22 PM
Can anyone recommend a good, real looking Indoor flyer? Sport Flyer Parkflyers 6 Sep 25, 2004 06:21 PM
