Old May 30, 2011, 07:45 PM
JakeAB is offline
Find More Posts by JakeAB
Master of Creative Crashing
United States, MI, Berrien Springs
Joined Mar 2011
Question
Thread Lock for Plastic?
What should be used as thread locker for metal-to-plastic? I know blue Loctite is not good for plastic. I've read that many people use CA, but there are many types of CA--on my workbench I have four different kinds, but I don't know which (if any) will work.
The reason I ask that that I'm having trouble with things popping off my heli in flight. As I understand it, this is not good. I've used blue Loctite on everything metal-to-metal, and they're holding fine. It's the metal screws in plastic that's the problem.
JakeAB is offline Find More Posts by JakeAB
Old May 30, 2011, 08:21 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Originally Posted by JakeAB View Post
What should be used as thread locker for metal-to-plastic? I know blue Loctite is not good for plastic. I've read that many people use CA, but there are many types of CA--on my workbench I have four difference kinds, but I don't know which (if any) will work.
Loctite makes a special blend for metal to plastic but it's essentially CA. http://www.labsafety.com/search/Loct...58/?type=brand
A little bit of any CA should work fine.
Xrayted is offline Find More Posts by Xrayted
Old May 30, 2011, 09:12 PM
JakeAB is offline
Joined Mar 2011
Yeah, I've seen Loctite 425, but at $20 for a 20g bottle, that's awfully expensive CA. I'd like to know what makes it special.
I have thin, medium and thick CA, just plain CA with no special formulation. Is any thickness better than others, or should I just split the different and use medium?
Old May 30, 2011, 09:21 PM
Xrayted is offline
Closed Account
Joined Dec 2007
It's pretty much the same stuff so don't waste your money. The thinner ca will wick into the threads easier.
Old May 30, 2011, 09:22 PM
metalbenderusn is offline
Find More Posts by metalbenderusn
My dog is PERFECT in my eyes
Joined Mar 2010
If the hole is not stripped out, thin CA is fine. If the hole is stripped, thick CA is good.
metalbenderusn is offline Find More Posts by metalbenderusn
Old May 31, 2011, 03:16 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Thin can be messy, since it runs. I use medium. It dries a little slower, so is easier to use.
You might be over tightening the screws.
Roto Rob is offline Find More Posts by Roto Rob
Old May 31, 2011, 04:00 AM
papa38 is offline
Find More Posts by papa38
Recovering nitro addict
papa38's Avatar
Everett,Washington
Joined May 2005
All loctite is expensive I agree with Rob,medium gives you more time,and is a little stronger than thin. Thin is good for holes in wood,because it soaks in better.
papa38 is offline Find More Posts by papa38
Discussion Good thread lock for glass filled Nylon? AVsoarhead The Builders Workshop 4 Dec 09, 2010 12:47 AM
Help! Safe Thread Lock For EDFs? SyncroScott Electric Ducted Fan Jet Talk 1 Jul 13, 2008 06:39 PM
Rant I want instant thread lock! Why for we no have? HeliSmith Mini Helis 8 Jun 21, 2007 12:29 AM
Thread Lock for Servo Horn Screw? hydrogin Slope 5 Jan 13, 2005 07:05 PM
