Sep 23, 2011, 10:33 AM
Lake Havasu, AZ
Joined Jun 2005
You are using older Agilent equipment than we are, however, that should be able to measure the output in dBm as well as dBuv. So, you should be able to see for yourself the 2483.50MHz restricted band edge violation I was referring to.
You seem to forget that I have spent the last 23 months designing and testing wafer level chipsets to be used in our new modules (which I also designed). This is all that I have been doing, working with the best RF engineers in the country. So, we have our own products, separate from Maxstream. The 6 channel Nano receiver (FCC:X5L-XPSRX6NP) was the first step in the process and that obviously has been extremely successful. The new DivBee module (FCC: X5L-XPSA24) offers a -108dBm of real sensitivity and 200mw EIRP of output power. The range is better than any 2.4GHz RC system available. I also have the exact same design (same board layout too) for our 900MHz system which is now in the process of preparing for FCC testing.
Even a block diagram of the components easily proves that the theoretical maximum sensitivity of the FrSky receivers can not be -104dBm. You have to factor in losses due to baluns, RF switches, filters, PCB traces, blocking caps, etc. The only true way to determine the actual sensitivity is by injecting a signal into the front-end and determining the actual gain, and then measure the cable loss and factor antenna gain. However, your final sensitivity can not somehow be magically higher than what the components being used are capable of providing.
