Old May 29, 2011, 06:57 PM
Foam crasher is offline
Find More Posts by Foam crasher
Joined Nov 2010
:D :D :D Whoooopeeee!!!!!!!
Okay so today I was feeling bored and not wanting to study for Psychology so I did what every model builder does, I built a new plane! I downloaded a simple symmetrical wing airfoil which I then copied, cut out, and transfered to a piece of fir-mica. The chord is 6.5 inches and each wing panel is 24" long from the point. I used the simple method of cutting wing cores by anchoring one end of a wire to the table and having a handle on the other...... ect. I then used 45 M spray on adhesive and covered the cores with freezer paper wax side out.I swept the wings back by cutting 4", I believe, from the tail edge of the wings at the center. I glued the two halves together with hot glue. I used plastic election signs for the ailerons. Two 9 gram servos a 18 amp esc a rewound motor with a 8 4 prop and a 1500 mah 2 cell battery later I had a very good flying wing. I had to give it some up trim and some left roll but other then that it flew right out of my hand. Also you will notice no fins.. Flys great no flat spinning, tracks great. Hope you like it and make suggestions as I just started to build flying wings (they are so simple)Thanks a bunch:
Foam
Foam crasher is offline Find More Posts by Foam crasher
Old Jun 03, 2011, 10:25 PM
john wing is offline
Find More Posts by john wing
just winging it
john wing's Avatar
Fairfield, CA 94533
Joined Oct 2006
thats cool you can build your own wings
mabe cut your flaps at a angle for tighter rolls
great job.
john wing is offline Find More Posts by john wing
Old Jun 04, 2011, 09:54 AM
Joined Nov 2010
Hey thanks, As an up date I put a 800 mah 3 cell on it and it really can move now lots of fun and rollls like mad. DD
great job.
Discussion Gee Bee D model Dizzy5 Scale Kit/Scratch Built 60 Mar 12, 2013 03:10 PM
Sold Novus UH1-D Heli Black_Beard Aircraft - Electric - Helis (FS/W) 5 Mar 12, 2011 01:18 PM
Sold B&D retracts DSLMGK Aircraft - General - Miscellaneous (FS/W) 0 Mar 08, 2011 05:24 PM
