Old May 29, 2011, 06:51 PM
villapilote is offline
Find More Posts by villapilote
Wilson, NC
Joined Aug 2009
47" WS Flying Wing with Landing Gear
We have many foam flying wings at our field and all of them are hand launched. I have seen many, many crashes at the hand launch. I know that many are during the maiden flight. I had no interest in crashing planes like that. But I liked the blue fan fold material. I played with it until I came up with a very durable and light weight landing gear. AUW is about 30oz. Since it is an airfoil flat bottom wing, the stall at landing is very predictable; it lands very slow. Two carbon arrow shafts glued against the inside bottom wing surface tie the landing gear and motor support together. I originally posted to the Bluecor Flying Wing thread, but then realized that my interest and contribution is a Flying Wing with landing gear, so I changed the subject and re-posted. Here are the photos:
villapilote is offline Find More Posts by villapilote
Old May 29, 2011, 09:57 PM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Good looking wing. Nice solution to stated goal.
Dave-
foamdave is online now Find More Posts by foamdave
Old Jun 15, 2011, 05:41 PM
Wilson, NC
Joined Aug 2009
Here is a video of some takeoff and landings.
Rudy and Wing1 (2 min 50 sec)
Old Oct 10, 2012, 10:30 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Love what you have done with the landing gear. I now understand that I have my gear too far to the read. Need to move they forward towards the CG. Thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Oct 13, 2012, 04:43 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
http://www.youtube.com/watch?v=leAU-N8bTOM
did they pay u anything to mow the lawn?
gazza2003au is offline Find More Posts by gazza2003au
Old Oct 16, 2012, 09:20 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
looks funny moving around in the grass . like some sort of bug , but i have to admit that its cool. it would look sweeter with retracts. hint hint.i sent the video link to my club members since 75% fly wings out of blue core so they are gona get a kick out of this as i did. great job
THESANDMAN is offline Find More Posts by THESANDMAN
Old Oct 16, 2012, 09:25 PM
Joined Aug 2009
It is not easy to put landing gear on a flying wing, I know. EEK!
Old Oct 19, 2012, 10:08 AM
Wilson, NC
Joined Aug 2009
I have seen many flying wings being hand launched, and immediatley crash. This happens most frequently on the first hand launch, when the trim and the CG are not yet correct. And also on the second launch, and the third, and the fourth; see where I'm going? It is a lot safer to do it with landing gear. Besides, I enjoy take-offs and landings; sometimes I'll do 10 in one flight.
Old Oct 19, 2012, 10:12 AM
Joined Aug 2009
I also believe it is much safer with landing gear. When things are right, it will reveal itself.
Question, how do you determine the location of the rear landing gear? I have tried a number of places without success, I don't seem to be able to get the wing to rotate for take off so now I am trying enlarging the nose gear so that the wing is angled for take-off without rotating.
Old Oct 20, 2012, 04:12 PM
Wilson, NC
Joined Aug 2009
Hi rimshotcopter
I assume you are using elevons, so you have ailerons and elevators. I locate the rear main gear about 1/2" to the rear of the CG. Like you, I also have the front gear so the wing sits on a level surface with some positive incidence. I originally started with the motor shaft being about 1" above the wing cord line. The wing was very sensitive in pitch, and on rare occasions would do an uncommanded 360 degree flip in a fraction of a second. It took me a long time to realize that the motor shaft should be located so the thrust line extends through the vertical CG. I no longer have the flying wing; too many crashes. I took the same motor and prop and built it into a twin boom pusher plane. The prop shaft is about 3/8" below the wing chord line. I have to use very long 1/8" diameter piano wire landing gear because I am using a 10" diameter prop. I have noticed that in the pusher configuration the motor and prop are much better protected than in a conventual configuration.
Old Oct 20, 2012, 04:28 PM
Joined Aug 2009
Awe!! Thank you Villapilote.
For Sale Robart Topflite B25 Landing Gear with extra Nose Gear warbirds Aircraft - Fuel - Airplanes (FS/W) 0 May 08, 2011 05:40 PM
Found 3dhobby 47 edge landing gear propnut07 Aircraft - General - Miscellaneous (FS/W) 0 Apr 03, 2011 09:26 PM
For Sale NIB Extreme Flight 47.5" Yak54e w/ CF landing gear RC Accessory Aircraft - Electric - Airplanes (FS/W) 1 Mar 29, 2011 08:50 AM
Wanted Landing gear for Extreme Flight Yak54 47" gregory.da Aircraft - Electric - Airplanes (FS/W) 2 Mar 27, 2011 12:36 PM
Discussion Cox P-47 WITH LANDING GEAR giddyuperic Electric Warbirds 1 Feb 25, 2008 04:26 PM
