Old May 29, 2011, 01:16 PM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
Question
Where to buy SkyWalker V3 ?
who offers best price ? i need 2x SW
i found that bevrc offers free shipping but i have bad expirence with them
jsxx is offline Find More Posts by jsxx
Old May 29, 2011, 01:20 PM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
LowpriceRc.com
I just got 2 Skywalkers v3 and one mini Skywalker.
All in good condition.
KristianS is offline Find More Posts by KristianS
Old May 29, 2011, 01:22 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
readymaderc.com
lowpricedrc.com
whakahere is offline Find More Posts by whakahere
Old May 29, 2011, 01:33 PM
jsxx is offline
jsxx's Avatar
Joined Jan 2011
are they offer free shipping ?
$300 shipping from readymaderc....
Old May 29, 2011, 01:42 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
If you want free shipping then bevrc is the place to get it from. I know you are not happy with their responds from with your CL. So it is up to you.
Old May 29, 2011, 01:43 PM
FPV addict
Giske, Norway
Joined Aug 2009
Nope, BEVRC is the only site that I've seen that offers free shipping.
Old May 29, 2011, 02:12 PM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
Had 2 skywalkers from BEVRC, always been quick delivery.
Cir2kuk is offline Find More Posts by Cir2kuk
Old May 29, 2011, 02:28 PM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
http://www.rcgroups.com/forums/showthread.php?t=1445851
henkvdw is offline Find More Posts by henkvdw
Old May 30, 2011, 07:27 AM
dtm360 is offline
Find More Posts by dtm360
Hong Kong
Joined Sep 2004
Just received my free shipping Skywalker from BEVRC from Shanghai to Hong Kong in less than a week (4 days). Plane arrived in good condition, cannot complain.
LowPriceRC are literally down the road from me. Also have good service from them, but they charge for shipping and don't allow me to local pick up..... because they are just an office!
dtm360 is offline Find More Posts by dtm360
Old May 30, 2011, 08:50 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Whats different anyway?
I never did see what they changed exactly.
BushmanLA is offline Find More Posts by BushmanLA
Old Sep 21, 2011, 02:23 AM
saidrc is offline
Find More Posts by saidrc
Joined Aug 2011
LowPriceRc
Hi
I am interested to order the Skywalker 2012 airplane from LowPricerc.
I did ask following questions from them several days ago but got no respond so far.
Currently following items are on my shopping list:
oSkywalker EPO EP Glider Aircraft (2012 version) for FPV
oMoxie Punch Series 30C 14.8V 4S 5000mAh Lipo,
oMoxie Brushless Outrunner Motor 990KV,
o APC 9x6 Thin Electric Pusher Propeller,
o Astral Alu E-prop Spinners Adapter Motor Shaft=5mm Propeller Shaft=8mm Set,
Have I chosen right setup (strong enough for a heavy FPV gear)? What kind of servo should I order? I have already the transmitter and receiver. Is there any other item I should include to my order beside the FPV equipments? I appreciate if someone helps me to choose related and recommended items which lowpricerc has in stock. I want to order everything from one store.
saidrc is offline Find More Posts by saidrc
Old Sep 21, 2011, 06:35 AM
dtm360 is offline
Hong Kong
Joined Sep 2004
You could save yourself 56g (more important) and USD12 by going for the 20C 5000mah batteries.
The Skywalker should be pulling around 40 (ish) Amps..... 20C give you a ceiling of 100A which is plenty enough for the SW....30C is simply overkill and adding weight!
I use Emax ES08MA metal gear servos on the SW... I like these, they are very smooth for a 9g servo. You can get away with the plastic gear version on the ailerons ES08A....
Old Sep 21, 2011, 10:20 PM
saidrc is offline
Joined Aug 2011
Thank you dtm360. Have I chosen right propeller and spinner? The motor is strong enough for a heavy fpv gear? Also do you think it is necessary to order a program box like Moxie V Edition ESC 40A, HobbyWing Advanced Professional LCD Program Box. I have never had electric airplane and I am new in this. Any other item you would suggest to buy? Also I am wondering if the sales team or support team of LowPricerc ever responds to enquiries. I am a bit skeptic about them.
Old Sep 22, 2011, 07:15 AM
dtm360 is offline
Hong Kong
Joined Sep 2004
I actually use the Moxie V 50A ESC. Same weight as the 40A, just gives you a little more margin for error. The 40A is probably just the same ESC with a few FETs missing.
I have the programmer also, but this is purely for convenience. You basically use it once or twice, once you find the right setting you will never use it again. All the settings can be programmed without it by listening to beeps and moving the TX sticks.
I use the basic 2814 980kv motor flies my 2.1kg SW fine. Don't expect to do any major aerobatics? The motor you are speccing is supposed to be more powerful, so you will be OK.
You may want to get a few more tubes of that foam glue and fibre tape for re-inforcing the tail, they are pretty cheap.
'Au' from Lowprice is OK, don't expect too much technical support on the build, but I did receive an ESC with a broken BEC before, he was pretty quick in responding and refunding the Paypal after I sent the unit back.
Old Sep 22, 2011, 01:48 PM
saidrc is offline
Joined Aug 2011
Thanks dtm360.
- I did not find Moxie 50A ESC on their website, how about choosing moxie 60A 2-4s 4A?
-I will also order the programmer.
- Emax ES08MA servos are not on their website list. I don’t know which servos to choose. Which one of Moxie servos are 9g? I prefer to use metal gear servos.
-I have also ordered servo tester. Do you think it is useful?
-Is 12x8 propeller good to go with 990kv motor?
- I do not have any battery charger or balancer. They have Astral batter balancer 3 in1. Is it useful to order?
-I ordered 4 Astral foam safe contact glue and 2 Astral super tape as you advised.
Since I want to order everything in one package and from one store, please advice if you think I will need anything else to setup the skywalker.
Sorry for my dummy questions.
Sold NIB SkyWalker V3 smileyz FPV Equipment (FS/W) 2 May 28, 2011 12:29 AM
Discussion Skywalker available stateside? Or, where to order? motoguy1 FPV Talk 8 Mar 21, 2011 02:08 PM
Discussion Where to buy Nimh falcbenry Batteries and Chargers 3 Mar 15, 2011 03:53 PM
Discussion Where to buy Spektrum micro rx? JIMA Scale Kit/Scratch Built 11 Mar 07, 2011 02:20 PM
Discussion Where to buy 6020 motor replacement? overedline Coaxial Helicopters 2 Mar 07, 2011 12:17 AM
