Old May 28, 2011, 09:34 PM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
Has anyone ever used one of these?
I am interested in using one of these to check loaded RPM, however, the info on the item doesn't state whether it actually records the max RPM.
Has anyone had any experience with these?
http://www.ebay.com.au/itm/G-T-Power...item45f600a380
Here's where I got the idea to search on ebay for the same type of device.
6th item down on the list.
http://kintecracing.com/Accessories.html
mozzyrocks is offline Find More Posts by mozzyrocks
Old May 29, 2011, 03:07 AM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
Well, with the one on E-bay it says it shows the KV while the motor is working. Maybe it does not keep record than of the max rpm's.
I also thought about getting one, but would like one that can work for both brushed and brushless motors, if available
SARCFAN is offline Find More Posts by SARCFAN
Old May 29, 2011, 08:15 AM
siberianhusky is offline
Find More Posts by siberianhusky
siberianhusky's Avatar
Canada, ON, Peterborough
Joined Nov 2009
Get an eagletree, Amps, volts, rpm, temps and GPS if you get that module. Full data logging downloadable to you PC, data comes out in a nice graph format.
with the inductive pickup you can measure up to 300 amps if I remember correctly.
There are a whole pile of other modules available for it that aren't much use in a boat, like a pitot tube!
Not sure about the brushed stuff, but nitro and brushless are well supported.
siberianhusky is offline Find More Posts by siberianhusky
Old May 30, 2011, 10:46 AM
Joined Feb 2011
Available from HK?
Old May 30, 2011, 01:32 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Originally Posted by mozzyrocks View Post
Available from HK?
Yes, look into "Telemetry&FPV"section for Eagle tree
coriolan is offline Find More Posts by coriolan
Discussion Has anyone tried one of these FPV planes from HK yet? randall1959 FPV Aircraft 1 Mar 25, 2011 07:17 PM
Discussion Has anyone tried these fans? lowkeylaidback Foamy EDFs 5 Mar 21, 2011 04:36 PM
Discussion Has anyone ever stewmeat95 Dock Talk 17 Mar 19, 2011 04:21 PM
Question Has anyone ever built one of these kits? Mr. Robert Slope 22 Jan 02, 2008 04:16 PM
Has Anyone Ever Built One of These? Acer Electric Sailplanes 4 Dec 02, 2001 04:38 AM
