Old May 28, 2011, 02:39 PM
dokes is offline
Find More Posts by dokes
Joined Jan 2011
CMP Corsair, gas engine choice?
I have a CMP Corsair, 75 inch span. It calls for a 1.20 four stroke on web site. I noticed the ESM version is similar in size, but calls for more power. I figure ESM suggestion is probably right.
So if I run gas, Should i throw in a Zenoah G-23 or a G-38? Weight difference is about 10 ounces. Not much it seems. In this plane will that be an issue?
I am not even sure the G-23 will have enough power? I own both engines , so want to start with the right one.
Power wise (compared to a four stroke,) what does a G-23 compare to?
Thanks all
dokes is online now Send a private message to dokes Find More Posts by dokes Edit/Delete Message
dokes is offline Find More Posts by dokes
Discussion 58" wingspan CMP .50 Corsair Electric conversion blade thrasher Electric Warbirds 1 Mar 10, 2011 04:42 PM
Question how big a gas engine for 140 size p51 from CMP ONERCBOATER Fuel Warbirds 16 Mar 15, 2010 02:22 PM
Discussion Engine choice for a CMP 71" spitfire roundthebend Fuel Warbirds 6 Mar 24, 2008 04:07 AM
For Sale CMP Corsair 120: cowl and fake radial engine dmajchrzak Aircraft - Fuel - Airplanes (FS/W) 0 Aug 29, 2007 09:26 PM
