This thread is privately moderated by gluemaster, who may elect to delete unwanted replies.
Old May 28, 2011, 10:48 AM
gluemaster is offline
Find More Posts by gluemaster
Cub-O-Holic
gluemaster's Avatar
Deltona, FL
Joined Dec 2006
Hobbico Superstar EP to GP: Time for slime!
So this plane I got from my neighbor still had the electric motor and speed control in it and was originally a three channel plane. He modified the wing and added some ailerons but said the were pretty much ineffective so I figured since I was going to convert it to glow I would redo the ailerons and make some other changes. I'll get some pics up here in a bit. He has two of them, one with an OS 25LA and the other one with a 15LA. He says the 15 powered ship is very relaxing and the one with the 25 on it is a rocket, so I had a Thunder Tiger GP15 I was going to use but after I got everything installed to the point it would be ready to fly I was going to have to add an additional 6 oz of lead to the very end of the fuselage by the engine. Well after seeing how much it already weighed before the additional weight I decided to find a larger, heavier engine. I found a used K&B Sportster 28 at Grave's Hobbies in Orlando for a great price and decided it would probably work for what I wanted to do. After staying up until the wee hours this morning I finally had it ready to go. So I loaded up and headed for the place where I fly. I got the plane out, range checked it with my son's help and fueled it up. I fired it up, set the carb, taxied out and nailed the throttle. It took off rather quick and the climb out was really brisk. I got it trimmed out and flew around for a couple of minutes, did a couple of loops and rolls and then landed. I am only running a 3 oz tank in it and didn't really now how long it would fly. Didn't want any dead stick practice on the maiden. When I re-fueled it it didn't take much fuel to fill it back up. I flew it again and after almost 5 minutes I landed again and decided to pack up so I could bring it home to go over the plane. When I removed the wing I was shocked to see that the fuel tank was almost 3/4 full! I thought I was going to have to find some way to install a larger tank in it but I'll leave it alone. All that I think I need to do is add some down thrust to the engine as I have a lot of down elevator trim in it and the CG is right on the money.
gluemaster is offline Find More Posts by gluemaster
Discussion Hobbico Superstar EP Alex Schauer Beginner Training Area (Aircraft-Electric) 49 Jan 11, 2012 09:25 PM
Question Hobbico SuperStar EP With Symetrical Wing stompjrkz400 Electric Plane Talk 1 Jun 26, 2011 05:51 PM
For Sale For Sale-New Hobbico Superstar EP vpimike Aircraft - Electric - Airplanes (FS/W) 5 May 22, 2011 11:39 AM
Increasing flight time on a Hobbico SuperStar EP Select Plane AMarkIII Electric Plane Talk 2 May 18, 2005 07:48 PM
Great Starter for sale-- Hobbico Superstar ep jyurong Parkflyers 0 Feb 03, 2004 03:32 AM
