Old Dec 24, 2012, 03:55 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
On bagged Supras it was definitely better with more reflex for the zoom. Molded Supras also benefit, but not to the same extent from what I recall.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Dec 30, 2012, 05:16 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Originally Posted by Francesco View Post
Mmmh as far as I can remember, the Supra airfoil was known for being in optimal reflex when the bottom was flat.
Hi Francesco, on the molded Supra, for zoom speed it was actually -.5 degrees in reflex and not quite flat bottomed.
Cruise was 2 degrees camber, and penetration was with .5 degrees camber so there was a 1 degree reflex difference between fast flying vs zoom.
On the Maxa, there is also about a 1mm flap setting difference between fast horizontal flying ( penetration mode) and zoom speed. Penetration is with wing flat bottomed and adding an extra mm reflex to this would yield better performance for zoom speeds.
However, I think adding a bit more might be better as Kyle experienced because of the droop nose. The added reflex beyond optimal causes the wing to fly at just slightly less than "no lift" = negative lift which keeps the fuse more inline with the airflow. Just my hunch based on other planes I have tested .
fnnwizard is offline Find More Posts by fnnwizard
Old Dec 30, 2012, 06:37 PM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
That's curious, as I am not aware of a change in the airfoil between Dr. Drela's bagged Supra and the molded one.
Do you have a Maxa, Tuan? It'd be interesting to share our settings. Personally I think that 1 mm difference is too low to get to the minimum drag point. I think I have closer to 4 degrees difference. Plus, anything of that order of magnitude is likely to be "masked" by the linkage and servo slop. May be placebo, but nothing real.
Francesco is offline Find More Posts by Francesco
Old Dec 30, 2012, 09:33 PM
San Diego
Joined Aug 2004
The airfoil isn't different. Surface finish/smoothness is. From what I recall, the higher reflex numbers are driven by getting a Cl as close to zero as possible. Based on discussions with Mark, the higher reflex was more important for the not as smooth bagged wings. It should help the molded wings as well.
There was a significant difference in zooms with the additional reflex on my Supras - easily seen from the ground. So I would expect that if the Maxa has similar characteristics, it should be noticeable by trying different reflex settings for the zoom. It appears that Kyle already found this to be the case . . .
Tom
Old Dec 31, 2012, 12:03 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
No, I do not have Maxa. I am contemplating on getting 1. The 1mm is not from my observation, just from Vladimir's site. I cut and paste the speed settings below and included the pdf.
SPEED template
That template is for transition flying from one lift to another,
for returning from distant lift back, or for flying in high wind
conditions/environments. Speed setup could be applied by slider
first extreme position, or/and by assigned switch.
For best zoom performance we recommend to add 1mm more up
setting.
Discussion source for hold down nut on a supra stab? charlie tasto Thermal 9 Sep 01, 2011 09:09 PM
Sold Ready to Bag Supra Wing cores includes all parts & fuse Jose E Bruzual Aircraft - Sailplanes (FS/W) 12 Jun 15, 2011 12:49 PM
For Sale Supra New Custom Dave Hauch Built Re-List icharus Aircraft - Sailplanes (FS/W) 0 Apr 21, 2011 04:33 PM
Discussion carbon push rods in teflon tubing for Supra Upvector Composites Fabrication 7 Mar 04, 2011 05:49 PM
