Espritmodel.com Heli Air
Old Dec 22, 2012, 05:04 PM
LSF V aspirant
tewatson's Avatar
Orange, CA
Joined Oct 2006
I think most J planes are designed this way...there is no structural need for the spar to go completely to the wing tip.
Tom
Originally Posted by IHAVAWDY View Post
very surprised to hear there is no spar full span...
tewatson is online now Find More Posts by tewatson
Old Dec 22, 2012, 09:25 PM
Guangzhou Baiyun, China
Joined Dec 2003
Thank God there is no full span spar, if so, I will lost the whole MAXA when it hit the lamp pole with full motor power.
The carbon wing joint was also broken, but it was not totally broke into two pieces. It means the outer wing and central wing and wing joint suffer very hard strike at that monument. Fortunately, the tip damaged and absorb most collapse strike, the rest survived.
MAXA is light and stiff enough for competition, there is no need with full span spar at all. After all , it is not designed for hitting a lamp pole like my way.
Zhaokun Deng is offline Find More Posts by Zhaokun Deng
Old Dec 23, 2012, 01:07 AM
Francesco's Avatar
United States, CA, Berkeley
Joined Apr 2001
In this case, you might want to check the joiner boxes too.
Francesco is online now Find More Posts by Francesco
Old Dec 23, 2012, 03:39 AM
hst
Taiwan
Joined Aug 2006
Hit the lamp pole directly.
Bless you!
If I were there with my Supra, I would never take off in that direction.
Maybe you'd like to share with us some flight videos in the Electric Sailplane forum.
Maxa-e videos are still rare these days......
Very interested in the new long-tail version of Maxa-e 4m.
hst is offline Find More Posts by hst
Old Dec 23, 2012, 08:11 AM
Joined Dec 2003
I am interested in the Windy version .does anyone fly this version?
In landing path , I found the 4m light version is easy to be disturbed by gust in slow speed. So I decide to order the windy version, hopefully it should be more stable in landing.
Kun
Old Dec 23, 2012, 08:42 AM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Kun- is it possible to use a bit less landing flaps on your landing approach, to avoid slowing the model too much? Then use the brake at the end?
Maybe the flaps work so well that your approach is slower than you want for gusty winds.
Glad you fixed your model.
R,
Target
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Dec 24, 2012, 01:04 AM
Joined Dec 2003
Target, you are right. You can approach with a normal speed, then use break just before landing. It will be much better control. Because our flying field is not very large, we used to slow down the model avoiding rushing out of the landing range.
Merry Christmas and happy new year! Chinese New Year will be 2 months later. So I will have two long holiday, but need to buy double gifts!
Old Dec 24, 2012, 01:09 AM
Joined Dec 2003
http://v.youku.com/v_show/id_XNDMwMjk0Njcy.html?x
This is a short Vedio of its maiden flight.
Old Dec 24, 2012, 02:21 PM
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
Maxa + Pole = Sucks
Hope you can fix it
ak79 is offline Find More Posts by ak79
Site Sponsor
Old Dec 24, 2012, 03:08 PM
Joined Nov 2004
Is it My imagination? I added about three more millimeters to the reflex mode for Zoom on my Maxa. It seemed to make quite a big difference. Has anyone else noticed the same thing? It seems like I am getting at least 50 more feet of altitude on the Zoom. Am I imagining things?
Kyle Paulson is offline Find More Posts by Kyle Paulson
Old Dec 24, 2012, 03:09 PM
Francesco's Avatar
Joined Apr 2001
I also heard about that. How much reflex do you think you have now? I'd like to try.
Old Dec 24, 2012, 03:13 PM
Joined Nov 2004
The top of the wing is now flat. So instead of running a straight edge on the bottom of the wing like they suggest for reflex, I pretty much have a straight edge on the top of the wing now for Zoom only. This much reflex for ranging out/covering ground, is definitely too much reflex. The suggested reflex seems perfect for covering ground and long distances with minimum loss of altitude.
Old Dec 24, 2012, 03:16 PM
Francesco's Avatar
Joined Apr 2001
Excellent reference point. Thank you, let me try and I'll tell you how it feels.
Old Dec 24, 2012, 03:22 PM
San Diego
Joined Aug 2004
The Supra also benefits from a similar reflex setting.
Tom
Kiesling is offline Find More Posts by Kiesling
Old Dec 24, 2012, 03:24 PM
Francesco's Avatar
Joined Apr 2001
Tom
Mmmh as far as I can remember, the Supra airfoil was known for being in optimal reflex when the bottom was flat.
Discussion source for hold down nut on a supra stab? charlie tasto Thermal 9 Sep 01, 2011 09:09 PM
Sold Ready to Bag Supra Wing cores includes all parts & fuse Jose E Bruzual Aircraft - Sailplanes (FS/W) 12 Jun 15, 2011 12:49 PM
For Sale Supra New Custom Dave Hauch Built Re-List icharus Aircraft - Sailplanes (FS/W) 0 Apr 21, 2011 04:33 PM
Discussion carbon push rods in teflon tubing for Supra Upvector Composites Fabrication 7 Mar 04, 2011 05:49 PM
