Old Dec 21, 2012, 03:37 PM
Dan Zero-G is online now
Find More Posts by Dan Zero-G
France, PACA, Aix-en-Provence
Joined Dec 2007
Originally Posted by target View Post
Which Supra models use the wider joiners??
Target
I remember researching this at the time.
Only the Supra Spread Tow (the lightest one) has the thinner spars and the thinner joiners. All other versions use the normal wing joiners.
It is for this reason I got the 'Hard Spread', which is the same spread tow, but with the normal, wider, spar and joiners.
This means my Hard Spread wing is compatible with my older Carbon Light wings. I have verified this and can vouch that they are fully compatible.
Dan Zero-G is online now Find More Posts by Dan Zero-G
Old Dec 21, 2012, 04:35 PM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Originally Posted by IHAVAWDY View Post
Curious
I see a lot of measurements on the Maxa from various web sites but I can't find one w/ measurement from leading edge of wing to tip of nose? Anyone have that # ? Thanks
17 3/8" actual, not projected.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Dec 21, 2012, 05:26 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Perfect, thank you!
I am thinking of using the stock joiners in a bagged wing Supra, and had never heard of more than one width.
R,
Target
target is offline Find More Posts by target
Old Dec 22, 2012, 03:36 AM
Zhaokun Deng is offline
Find More Posts by Zhaokun Deng
Guangzhou Baiyun, China
Joined Dec 2003
My Maxa 4E hit a lamp pole directly. But it was still controllable and I continued to climb up to a same altitude,then landed safety.
The right tip is damaged and found there is no spar on tip. Spread carbon and Rohacell is very very thin.
Zhaokun Deng is offline Find More Posts by Zhaokun Deng
Old Dec 22, 2012, 03:37 AM
Joined Dec 2003
Hit the lamp pole directly.
Old Dec 22, 2012, 03:39 AM
Joined Dec 2003
Don't know how to repair it.
Old Dec 22, 2012, 10:58 AM
mrfski is offline
Find More Posts by mrfski
Martin
USA, CA, Piedmont
Joined May 2005
Maxa repair
I have repaired a lot of wings and yours is pretty serious but it can be repaired. The best way is to remove all the damaged skin top and bottom and epoxy in a blue foam section that you can shape back to the wing profile and cover it with glass. The repairs will add weight and you will probably have a hard time finding paint to match this color.
My 2 cents says order another tip.
Mart
mrfski is offline Find More Posts by mrfski
Old Dec 22, 2012, 11:40 AM
Kyle Paulson is offline
Find More Posts by Kyle Paulson
Joined Nov 2004
New tip dude!
Kyle Paulson is offline Find More Posts by Kyle Paulson
Old Dec 22, 2012, 11:55 AM
Joined Dec 2003
Yes , Mart. Your method is a classical way to repair molded wings. I do not think I am skillful to finish all steps well in that way. I am a stupid completist, so I struggled inside my mind and then decided to fix with singing an old song loudly: My Way! It is a nice song.
I used a ruler to keep verything straight back to its own position. Using a carbon strip inside to strengthen the broken instruction. There is no spar in the tip. Rohacell and spread carbon are extremely thin. Then I only use CA to glue the original broken instructions. Then Spain with neon orange.
I make a test fly in a very calm condition, it flies perfectly! I just feel happy. The new tip will cost me about 350 ero and one month to wait.
Kun
Old Dec 22, 2012, 11:57 AM
Joined Dec 2003
Not very bad. Only 30 minutes.
Old Dec 22, 2012, 12:12 PM
Joined Dec 2003
If you keep every thing back, only using CA can make the thin Rohacell very hard. It is an easy way to repair. Of cause, it is not perfect.
Old Dec 22, 2012, 01:53 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Nice job.
R,
Target
Old Dec 22, 2012, 02:22 PM
mrfski is offline
Martin
USA, CA, Piedmont
Joined May 2005
That will work just fine and look perfect when the plane is circling high over head.
Mart
Old Dec 22, 2012, 04:19 PM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
very surprised to hear there is no spar full span...
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Dec 22, 2012, 04:42 PM
jimsoars is offline
Find More Posts by jimsoars
United States, CO, Broomfield
Joined Jan 2003
They always look easier to fix about a week after the incident...
Jim
jimsoars is offline Find More Posts by jimsoars
Discussion source for hold down nut on a supra stab? charlie tasto Thermal 9 Sep 01, 2011 09:09 PM
Sold Ready to Bag Supra Wing cores includes all parts & fuse Jose E Bruzual Aircraft - Sailplanes (FS/W) 12 Jun 15, 2011 12:49 PM
For Sale Supra New Custom Dave Hauch Built Re-List icharus Aircraft - Sailplanes (FS/W) 0 Apr 21, 2011 04:33 PM
Discussion carbon push rods in teflon tubing for Supra Upvector Composites Fabrication 7 Mar 04, 2011 05:49 PM
