Old Dec 11, 2012, 06:22 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I thought that I heard that having the aileron NOT extend to the tip caused a drag point where the deflected aileron outer tip met the fixed TE section....
By having curved up wing tips, you can't have the aileron extend all the way, so you have to have that design with the curved tips (aileron stopping short)
I suppose if the last bit of the wing TE swept forward, you could have a trileron extending to where the tip starts to curve up, and try to have the both features. Not sure if that would be better though...
I like simple, and flat tips with ailerons all the way out are pretty simple. I like that on the Maxa and Supra designs, as well as the newer Samba offerings.
R,
Target
target is offline Find More Posts by target
Old Dec 11, 2012, 07:23 PM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Originally Posted by RetoF3X View Post
I hope Joe W can chime in and explain why curved tips have disappeared in J planes too (although they spent most time at positive cl).
Best,
Reto
Sense there are so many Eploder pilots out there, pehaps one of them would be so kind as to cut off their " Hoerner tips" in the name of science, and report back to us on any findings? Maybe Shrederman??? It would really help this disscusion if we had actual studies done...
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Dec 11, 2012, 07:24 PM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
Target has like ten sploders maybe he would do it.
J. Wydronek is offline Find More Posts by J. Wydronek
Old Dec 11, 2012, 07:26 PM
IHAVAWDY is offline
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Target?? would you mind? I'd really like to know....
Old Dec 11, 2012, 07:38 PM
Joe W is offline
Find More Posts by Joe W
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
Winglets have their place for some designs. It makes sense if the design is span constrained (e.g. airliner gate spacing), or if it is an after-market performance improvement where the equivalent performance span extension would exceed the wing structure bending allowables. For the case of airliners, spar weight is expensive in terms of performance, it makes sense to "extend the wingtip" via winglets, as the winglet adds only a small contribution to the spar loads. A tip extension adds a lot to the wing bending loads...
As for a hoerner style wing tip, they look cool. They may even add enough performance to offset the increased manufacturing weight (as small as it is), although this isn't at all certain. The cool curled up wingtip is essentially a really low aspect ratio winglet. Due to the really low aspect ratio, it doesn't do much. The performance gain is typically a percentage of the gains if one just unrolled the tip to flat (maybe 70-80%?). How much span delta comes out via the unrolling process for the typical hoerner winglet?
Joe W is offline Find More Posts by Joe W
Old Dec 11, 2012, 07:53 PM
IHAVAWDY is offline
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Thanks Joe, I'm still curious though, Target if your busy I totally understand...just send "one" out here and I'll conduct the tests, and I promise to keep notes so ALL intestested parties will benefit, it'll be a tax deductable contribution on your part T. I'll send the tax "papers'' as soon as I recieve the plane.
Old Dec 11, 2012, 08:42 PM
alvaro corzo is offline
Find More Posts by alvaro corzo
alvaro corzo's Avatar
United States, CA, San Diego
Joined Feb 2006
this discussion
calls for some wind tunnel testing
alvaro corzo is offline Find More Posts by alvaro corzo
Old Dec 11, 2012, 11:44 PM
floquet is online now
Find More Posts by floquet
Hugh Blackburn
floquet's Avatar
Melbourne, Australia
Joined Jun 2005
The size of differences we are considering would be undetectable in wind tunnel testing.
Hugh
floquet is online now Find More Posts by floquet
Old Dec 12, 2012, 12:01 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I actually have only one currently flyable Xplorer, and its a 4 meter. If I could heat and unroll the tips, and extend the aileron, I would be your guinea pig.
Until then, I will call it "curly".
R,
Target
Old Dec 12, 2012, 11:52 AM
RetoF3X is offline
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
In fact Mike Lachowski had cut off the curved wingtips of his Caracho for the 2003 F3B worlds.
I hope he can chime in on his findings. But in short he described the plane as a 2.9m wingspan plane with 0.1m airbreaks on each side when it was flying with the curved tips.
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Dec 12, 2012, 12:12 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Reto
I cut off the wing at the start of the curl. This is the extreme case for size. I made a mold for the rest of the wing (flat) and the actual wing was 3.3M when it was finished. Really big improvement in how well it launched. Tom Kiesling also flew one of mine at team selections the next cycle.
The only bad part about extending the tips was the V-tail which was small and too flat to begin with.
mlachow is offline Find More Posts by mlachow
Old Dec 12, 2012, 12:24 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Yup, the Caracho was hugely improved with the removal of the curly tips. It did everything better. In fact Mike had a perfect score for the first round at the 2003 F3B World Championships with that model.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Dec 12, 2012, 01:33 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
And that perfect score included the speed run with a touch and go, snap roll to inverted, and an upside down finish! Oh it was exciting
Wish I had a video replay on that, cuz it would be worth ing
M
FLY F3B is offline Find More Posts by FLY F3B
Old Dec 12, 2012, 06:47 PM
Dyno Don is offline
Find More Posts by Dyno Don
Dyno Don's Avatar
United States, AZ, Surprise
Joined Jun 2003
M
Oh Man that would have been a great Video.!!. sounds exciting..
Dyno Don is offline Find More Posts by Dyno Don
Old Dec 13, 2012, 09:13 AM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Lots of interesting stuff happened at the 2003 Kirkheim F3B Worlds...
jtlsf5 is online now Find More Posts by jtlsf5
Discussion source for hold down nut on a supra stab? charlie tasto Thermal 9 Sep 01, 2011 09:09 PM
Sold Ready to Bag Supra Wing cores includes all parts & fuse Jose E Bruzual Aircraft - Sailplanes (FS/W) 12 Jun 15, 2011 12:49 PM
For Sale Supra New Custom Dave Hauch Built Re-List icharus Aircraft - Sailplanes (FS/W) 0 Apr 21, 2011 04:33 PM
Discussion carbon push rods in teflon tubing for Supra Upvector Composites Fabrication 7 Mar 04, 2011 05:49 PM
