.I could have ballasted the ST's to the same weight (they are full strength), but my C-68 was slightly more expendable. No point risking my brand new ST's when I needed the C-68's weight anyway ![]() I also brought my 68 oz Disser Aspire since my model box fits 4 Aspires--just in case the forecast called for some morning dead air, although the ST's are equally perfect for that (in fact, my best dead air performances have been with the heavier C-68. But I've flown it in a lot more contests). I flew the Disser in the Visalia contest and was more proficient on it than the Maxa (which I only have a dozen flights on). |
Joined Feb 2010
Is it possible to have some info on profiles (thickness, curvature with intrados flatted). This is important to judge a plane.
It seems that the thickness of the profiles is 8.8 or 9% and 2% curvature if the photos published on the web are ok. Any confirmation? |
Berthoud CO
Joined Oct 2007
Maxa is ready for prime time
Hi Guys,
We have been snowed under in Boulder, but today I was able to test my Maxa with the new stiffer production center section. The results were great. I launched with full tension , Ober winch with Lucas motor in our F3J configuration (braided plus 1.28 mono on the airleg). Launch height has improved 50-75 feet over the previous configuration. There is still bend from the tips as this is a light 4m ship, but nothing compared to the previous version. The launches were very, very stable with no hint of falling off. I have even moved the tow hook amost all the way back. She goes vertical and pulls extremly hard all the way up. The good news is the new section only added 1 oz to the all up weight. Mine is now at 63.2 oz. As others have said the float and handling characteristics of this model are amazing. This is a very pilot friendly model. At this weight the plane's wing loading is 7.1 oz/sqft, which is the lightest wing loading model available and you can really see the difference with any sort of energy on the field at all. IMO this is a great one and we will be seeing a lot of them in competition! Thanks very much Barry! |
I have the specs for three models in front of me that start at 6.46 and at the larger end stop at 7.06...3.5 meters to 4.0....all lower than the reports on the maxa...but what does that mean anyways ? However back on track, I am interested in the spar change - was notified pre-Visalia that this was in the newer models - any word on the changes made there? Looks like a better spar for sure if the launches are translating higher. Have you put it under a real two man tow in a little wind? |
Berthoud CO
Joined Oct 2007
Barry should comment on the spar changes. My observations are that the Carbon 45 material looks thicker and overall the skin is stronger in combination with Spar to surface changes.
Regarding the launch tests, I would say what I ran was very much equivalent to a 2-man tow in 3-4mph breeze. We have done quite a bit of comparison of the F3J with winch method to a 2-man tow to support this. The increased center stiffness was very clear in observing the launches compared to the previous layup. My tow-hook is now 1/8"-3/16" away from the far back slot position, which allows for greatly increased pull on launch, something I was reticent to do on the previous layup. |
| Thread Tools | |
| Discussion source for hold down nut on a supra stab? | charlie tasto | Thermal | 9 | Sep 01, 2011 09:09 PM |
| Sold Ready to Bag Supra Wing cores includes all parts & fuse | Jose E Bruzual | Aircraft - Sailplanes (FS/W) | 12 | Jun 15, 2011 12:49 PM |
| For Sale Supra New Custom Dave Hauch Built Re-List | icharus | Aircraft - Sailplanes (FS/W) | 0 | Apr 21, 2011 04:33 PM |
| Discussion carbon push rods in teflon tubing for Supra | Upvector | Composites Fabrication | 7 | Mar 04, 2011 05:49 PM |
