Old May 26, 2011, 11:34 AM
Joined May 2011
Ducted fans for a quad?
Has anyone explored using ducted fans for a quad (or other multi)? It would seem to me that the greater efficiency would be ideal even with the added weight. Not only that - it would save on broken props...
spokeshave is offline Find More Posts by spokeshave
Old May 26, 2011, 11:51 AM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
I don't think it's greater efficiency, infact it won't be even close
Forget about yaw unless you tilt motors and when you do that, you lose more power
And you would end up with a very loud setup
Don't get me wrong, it would be a very cool setup but that's it
Moe
mkmkmk13 is offline Find More Posts by mkmkmk13
Old May 26, 2011, 12:28 PM
Joined May 2011
I was under the impression that ducted fans were more efficient than propellers alone. As for yaw, I believe motion in yaw is accomplished by varying the speeds of the pairs of like-directioned propellers to change the overal angular momentum. I din't see why this couldn't be done with ducted fans as well.
Old May 26, 2011, 12:48 PM
Portugal
Joined Jul 2010
My understanding of this is that EDF units (as fitted to scale jet models, etc.) operate at very high rpm and that their purpose is to produce high thrust in a compact package. As such, their small diameter and additional weight would make them a bit redundant for a quad. (Remember that thrust is always proportional to swept area, i.e. diameter).
"Shrouded" fans, on the other hand, might be more relevant to quads: larger diameter, using a shroud (generally a much shorter tube than a "duct"). The efficiency gain (i.e. the additional thrust/watt) is likely to be very small, but if you needed to enclose the propellers anyway (e.g. for flying indoors) then you might as well attempt to recoup some of the thrust lost to the additional weight.
But note: I've heard of some "casual" shroud setups causing problems - something to do with interference with tangential airflow. So a shroud needs to be very carefully designed.
jes1111 is offline Find More Posts by jes1111
Old May 26, 2011, 01:08 PM
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi,
It has been done. Here is one link from 2007 on a quad EDF build from the Mega Index: http://www.rcgroups.com/forums/showt...light=edf+vtol
Cheers,
Jim
Vote for my Bro Joe here: Quadrocopter and Tricopter Mega Link Index
jesolins is online now Find More Posts by jesolins
Old May 26, 2011, 01:35 PM
mkmkmk13's Avatar
USA, CA, Anaheim
Joined May 2007
If you are asking about efficiency, amp for amp props are more efficient
EDFs have no torque, so no yaw control
They are normally used for the scale look and the sound they make
But if you are looking for the wow factor, EDFs are super cool you can even build a UFO style quad
Old May 26, 2011, 02:12 PM
USA, WV, Parkersburg
Joined Jun 2007
I'd like to see a micro quad out of 30mm fans. Something in a 8-10in frame. Then wrap it with some thin depron and make a small UFO
Garrett1234567 is offline Find More Posts by Garrett1234567
Old May 30, 2011, 10:17 AM
Vermont
Joined Dec 2003
Would be cool to see a thrust vectoring system like on a mig 28. Don't think they make a flight control system for that. Go for it!
spacecase is offline Find More Posts by spacecase
Old May 30, 2011, 11:18 AM
Spiritual Hovering
Coptaire's Avatar
Paris, France
Joined Sep 2010
I am currently evaluating shrouded prop, building my own shroud like this.
I plan to build a quad with 4 shrouds, after testing.
There is a thread for this project:
Propeller Shroud Project
Coptaire is offline Find More Posts by Coptaire
Old Jun 04, 2011, 10:56 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Very nice man.... What's the wieght of this ring?
panos2408 is offline Find More Posts by panos2408
Old Jun 05, 2011, 04:06 AM
Spiritual Hovering
Coptaire's Avatar
Paris, France
Joined Sep 2010
79 grams. It is just the prototype to conduct thrust test. Later, we could have molded version.
You could read more details from:
http://www.rcgroups.com/forums/showthread.php?t=1447212
For Sale 2 GWS 55mm Ducted fans with brushed motors Lammergier Aircraft - Electric - Power Systems (FS/W) 5 Jun 26, 2011 02:51 PM
Found Want to Trade FY-90Q Quad Controller for differnt Quad controller FL62 Aircraft - Electric - Helis (FS/W) 5 Mar 11, 2011 06:43 PM
ROSSI 90 not for ducted fans Terb Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2003 09:44 AM
How Close Is Moto Calc for Ducted Fans? Joe Elston Electric Ducted Fan Jet Talk 19 Oct 16, 2002 06:17 PM
Astroflight Brushless 020 for ducted fans(Help!!!) crazythumbs Power Systems 6 May 28, 2001 03:30 AM
