Old May 26, 2011, 05:58 AM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
Rctimer 30A esc cutting out with KK board
I've had a problem with HK SS 25A programmable esc's stopping briefly due to them not keeping up with the signal speed of the KK blue-boards. I changed the esc's back to the old SS 45A ones and it worked ok. That was 3 weeks ago.
Time to build a hex. I ordered 6 rctimer 30A esc's http://www.rctimer.com/index.php?gOo...6&productname= as others have had a great run with them. 1st flight in the park tonight and the motors all cut out for 1/4 second just like the SS prog ones. I sat the hex on the ground under power and it did it again. Definitely the same problem.
Anyone else have this problem with recently bought rctimer esc's?
Pete
Efliernz is offline Find More Posts by Efliernz
Old May 26, 2011, 06:29 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
If you have the red wire from more than one ESC connected together they will do that. I had several crashes before I figured that out. Cut the red wire on all but one ESC – I use a servo extension so I don’t have to modify the ESC.
RC Man is offline Find More Posts by RC Man
Old May 26, 2011, 02:20 PM
Efliernz is offline
Efliernz's Avatar
Joined Jan 2007
Yup - tried that thanks!
All red wires were cut and the esc's were programmed with a ubec. I use a separate ubec on-board the hex.
Pete
Discussion I need some help with Minsoo Kim KK board SeismicCWave Multirotor Talk 1 Apr 08, 2011 06:01 AM
Discussion ESC cutting out too soon! What gives? dgliderguy Micro Ready-to-Fly 5 Mar 08, 2011 02:48 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
