Old May 26, 2011, 12:57 AM
Tartago is online now
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
New Product
Hobbyking 70mm EDF Mig-15 with Flaps, electric retracts and airbrake
Specs:
span: 1100mm
Length: 1118mm g
Weight: 1600g
EDF: 70mm with 2836 kv 2770 Outrunner Brushless Motor
ESC: 45A
Servos: 9g x 10
6-7 Channel (throttle, elevator, aileron, rudder/steering, retracts, flaps/airbrake)
The plane looks very nice! I ordered one and will review it soon.
Tartago is online now Find More Posts by Tartago
Old May 26, 2011, 06:58 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
It looks similar to the one by Nitrop. They mentioned tha is made by Exceed-RC.
But this one has airbrakes.
The NP has a nicer scale landing gear though.
Old May 27, 2011, 10:04 AM
Shraga is offline
Find More Posts by Shraga
Israel
Joined Apr 2004
Hi Tartago
I also would like to order one, waiting for your review
Shraga is offline Find More Posts by Shraga
Old Jun 01, 2011, 07:15 PM
Back to EDF
Tartago's Avatar
Joined Apr 2006
Yesterday it was finally delivered to the mail.
Old Jun 02, 2011, 07:37 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
Mig-15 arrived. Unboxing and first look
Today I received the Mig-15 and I found the following:
- Surface finishing: Excelent except the 37mm cannon (see pic). Good painting job.
- Electronics installation: Good. Only the main retracts and one of the airbrakes need attention.
- Wings: CF or FG rod reinforces 3/4 of each wing half. Thay could have added 3" more and I'll be happier.
- Compartment size: Enough for 4s 2200 to 3200.
- EDF and ESC accessibility: Very good. Just two screws and you are there.
- Cockpit. Not many things here. It needs many scale touches. The space is more for a torso pilot than a full body one.
- Retracts: Units not so scale. The motion is slow and scale. The mains are not flush with the wing. I think is because the wheel and strut are too thick for the wing and the electric retract is not fit for this purpose. Also no gear doors.
- Overall I like it. I will continue with assembly and testing asap.
Old Jun 02, 2011, 08:04 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
Retract and airbrake videos
Here is one of the retracts:
70mm EDF Mig-15 retracts (0 min 17 sec)
and one of the airbrakes showing the unglued servo issue.
70mm EDF Mig-15 airbrakes (0 min 13 sec)
Old Jun 03, 2011, 06:09 AM
colinsouthey is offline
Find More Posts by colinsouthey
Joined May 2010
How did you resolve the problem of no hardware for the front wheel steering?
colinsouthey is offline Find More Posts by colinsouthey
Old Jun 03, 2011, 10:15 PM
Back to EDF
Tartago's Avatar
Joined Apr 2006
I used two pieces of fishing line. Then I got those small metal rings used in jewellery to close the lines and crimped to hold the lines in place.
Its quite fast and strong.
Old Jun 05, 2011, 01:31 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
Maiden flight and review
Yesterday I maidened her with a Rhino 3700mAh 20C 4S.
It took me almost all the runway to take off. I made it 20m before the line of trees.
The power was barely enough to avoid crashing. Definitely needs a >50C battery.
The plane is very noble, and didn't have any bad flying habits. Is, by far, the easiest to fly EDF I've had.
The EDF is badly balanced. It vibrates badly at 1/4 and 3/4 throttle.
The landing gear seemed to be glued with stamp licking glue. Both mains went off at first landing attempt.
No major damage, some scratches only.
The ESC is not properly attached inside the ducting so one wire was brushing against the prop adapter hub.
The plane is gorgeous, but its full of quality control issues. I think is better to wait for the kit version, where you can choose your EDF, ESC combination.
The EDF unit must be replaced with something reliable and balanced. I am checking the HET Typhoon Brushless EDF 2W-20-75A.
With some changes, this plane can be a real blast. Also, first change all the foam hinges with real CA hinges.
Edited video:
70mm EDF Mig-15 EPO with retracts, flaps and airbrakes. (2 min 24 sec)
Old Jun 06, 2011, 01:04 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
I ordered one DPS Series 72mm EDF from Lander.
They say dynamically balanced. Let's see.
Old Jun 07, 2011, 07:18 PM
Back to EDF
Tartago's Avatar
Joined Apr 2006
Mig-15 pilot
This ultradetail pilot fits nicely. Just cut down the cockpit floor and hot glue it to the seat.
Old Jun 07, 2011, 07:20 PM
splitpilot is offline
Find More Posts by splitpilot
splitpilot's Avatar
trying to catch Mr. FrSky... It flyes
Joined Jan 2005
splitpilot is offline Find More Posts by splitpilot
Old Jun 07, 2011, 10:37 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Thanks for the pics ..it will fly better with more power ...i have a exceed 70mm Mig 15 and it is a ball on 900-1000 wattsa 4000 mah 4s 30c batt
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 08, 2011, 12:58 AM
Back to EDF
Tartago's Avatar
Joined Apr 2006
The new EDF has a 2550kv Motor - 1200watt
Now I need to think about the right battery and ESC for it.
What battery do you use?
Sold (STILL FOR SALE) NIB Exceed 70mm Mig 15 w/electric retracts. (Local pick-up, LA Cali) T-CAT Aircraft - Electric - Jets (FS/W) 4 May 05, 2011 10:09 PM
Sold NIB Exceed RC 70mm Mig 15 w/electric retracts. Local pick-up, LA Cali. T-CAT Aircraft - Electric - Jets (FS/W) 3 May 04, 2011 04:23 AM
Discussion new:4/15/2011Fiberglas hobbyking Kits: F22 dual 70mm Kit & 90mm MIG texbird Electric Ducted Fan Jet Talk 0 Apr 15, 2011 12:27 PM
Sold Exceed RC Mig 15 70mm EDF jet Kit (local pick-up SoCal) T-CAT Aircraft - Electric - Jets (FS/W) 4 Apr 02, 2011 01:19 PM
Sold Exceed RC Mig 15 70mm EDF jet Kit (local pick-up SoCal) T-CAT Aircraft - Electric - Airplanes (FS/W) 0 Apr 01, 2011 12:36 PM
