This thread is privately moderated by Vagabond324, who may elect to delete unwanted replies.
Old May 25, 2011, 09:56 PM
Vagabond324 is offline
Find More Posts by Vagabond324
Trader Rating: 78
RETIRED PHILLY FIREFIGHTER
Vagabond324's Avatar
Philadelphia, PA USA
Joined May 2004
Trader Rating: 78
For Sale
Topflite Cessna 182 Skylane Gold Ed Kit .61-.91,81"
Email me for quick attention to your questions. jvt7532@aol.com
http://www3.towerhobbies.com/cgi-bin...?&I=LXHU91&P=7
Moving soon and need to move a few kits before I do. This is a beautiful kit and deserves to be built. I'm asking $175.00 + I'll split the shipping 50/50. I have some magazines with build reviews that I can send with it if you like. I also have available the Robart Front nose strut for an additional cost of $55.00 with this kit only if your interested. The strut is new.
The Classic Cessna 182 Looks You Want with Top Flite's Legendary Quality
in this 1/5 scale Cessna Skylane.
FEATURES: CAD engineered interlocking parts make building a breeze.
ABS strips for the control surfaces easily simulate the full-scale
Cessna's corrugated Fowler flaps, ailerons, and elevator.
INCLUDES: All the Wood to Build the Kit, Plastic Cowling, Clear Lexan Wind-
shields, Plastic Wheel Pants, Two-Piece Aluminum Landing Gear,
Plastic Wing Fairings, Decal Sheet, Pushrods, Rolled Plans,
Instruction Book, Adjustable Engine Mount, and misc. Hardware
SPECS: Wingspan: 81" Wing area: 906sq.in. Length: 64.5"
Weight: 10-12lbs. Wing loading: 23-28oz/sq.ft.
Throws: Hi Rate Low Rate CG: 4" aft of le @ root
Elev 1-1/16" each 3/4" each way Flaps: 1" Takeoff
Rud 1" each way 5/8" each way 2" Landing
Ail 5/8" each way 1/2" each way
REQUIRES: .61-.91 2-stroke or .91-1.20 4-stroke Engine
4-6 Channel Radio
5-7 servos (ailerons and flaps use two servos each)
5th and 6th channels for optional flaps and lights (see ACG for info)
4-plus Rolls of Covering
Building and Field Equipment
Part # 654
Fixed Steerable Nose Gear
w/Fork and Mount for 2 3/4" Wheel
Designed for use in model aircraft weighing 6 to 12 lbs. (2.7 - 6.5kg), the #654 Nosegear RoboStrut comes with mounting hardware for simple installation to firewalls. Other features include functional "oleo" action struts, made of 3/8" (9.52mm) diameter aircraft steel tubing, hardened steel steering tiller arm for positive ground control and a fork yoke oleo strut sized to accept up to a 2 3/4" wheel. Easy mounting to firewall with the included glass filled nylon mount. Can be adjusted for length.
MSRP $76.40 (ea.)
Vagabond324 is offline Find More Posts by Vagabond324
Old May 28, 2011, 12:50 PM
Turqui is online now
Find More Posts by Turqui
Trader Rating: 176
USA, FL, Weston
Joined Jan 2011
Trader Rating: 176
Pm sent.
Turqui is online now Find More Posts by Turqui
Old May 28, 2011, 10:49 PM
Trader Rating: 78
Joined May 2004
Trader Rating: 78
PM Replies
Still available
Old Nov 18, 2013, 09:57 PM
skywardready2 is offline
Find More Posts by skywardready2
Trader Rating: 0
Joined Feb 2013
Trader Rating: 0
Still have your 182 Cessna for sale? tobyhere400@gmail.com
skywardready2 is offline Find More Posts by skywardready2
Help! Top Flite Cessna 182 Skylane kit rolled plans the man Trader Talk 0 May 24, 2011 04:02 PM
For Sale Top Flite Cessna 182 Skylane Gold Ed Kit .61-.91,81" Vagabond324 Aircraft - Fuel - Airplanes (FS/W) 1 Feb 25, 2011 05:20 PM
For Sale Top Flite Cessna 182 Skylane Gold Ed Kit .61-.91,81" Vagabond324 Aircraft - Fuel - Airplanes (FS/W) 2 Jun 17, 2010 01:25 AM
Sold Top flite Cessna 182 Skylane 81" Gold Edition kit (IMAA legal) Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Jun 02, 2009 11:00 AM
For Sale Top Flite Cessna 182 Skylane Gold Kit (Price Lowered AGAIN) TryDave Aircraft - Fuel - Airplanes (FS/W) 0 Aug 25, 2007 12:14 PM
