Old Jan 13, 2013, 04:23 PM
New Zealand, Taranaki, New Plymouth
Joined Jan 2013
When you guys are building these wings does the bottom layer remain flat when the glue has set and clamps removed.I found that even though my eagle wing was flat when clapped there is now an 8mm rise to the LE from the bottom edge of the spar.How will this effect the wing ?
headon is offline Find More Posts by headon
Old Jan 13, 2013, 08:33 PM
MB326 Dino Driver
Macchi326Driver's Avatar
Newcastle, NSW Australia
Joined Dec 2006
Anton,.. Posting the pics of your Impala's just make me want one even more now,... Might jut have to do something about that but eagerly awaiting the Corro-pala ,...or corro-Macchi
Bakkie,.. Mate another great movie,.. I am so glad I found this thread and even your local thread heaps of info and great Corro flying!,.. Thanks to all you guys,,. You seem to have so much fun!,..
Macchi326Driver is offline Find More Posts by Macchi326Driver
Old Jan 15, 2013, 02:03 AM
Joined Jan 2013
Howdy,
Corrosair
I am about to glue in the tail elevator section to the fuzz and am not quite sure if both sides of the elevator are supposed to work independently ? The plans show a staple shaped object connecting both sides.Does the push rod from the servo connect to this ?? What is this staple shape made of and how does it go in ??
any help at this point would be great !!!
Old Jan 15, 2013, 12:49 PM
a Yankee in South Africa
Flying Beagle's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined May 2004
Hello headon
when "folding" the wing, it is very important to keep the leading edge down tight against the table, Sean and I both use a wooden jig that is cut an angle. Be sure the LE of the wing is wedged tight into the corner, then clamp the wing trailing edge down. If the wing is built correctly, you should notice a slight undercamber, when removing the completed wing from the jig. see the A-10 pics here
http://www.rcgroups.com/forums/showp...&postcount=629
the Corrosair wing is obviously a bit more complicated, but the principles are the same
the elevator joiner is simply a metal wire bent in the shape of a staple, per the plans. you can sharpen the tips to make the metal joiner a bit easier to push into the correx flutes. the elevator control horn is mounted to only one side.
Flying Beagle is offline Find More Posts by Flying Beagle
Old Jan 15, 2013, 02:28 PM
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Originally Posted by Flying Beagle View Post
Hello headon
the elevator joiner is simply a metal wire......
What gauge wire do you use FBI?
johannlochner is offline Find More Posts by johannlochner
Old Jan 15, 2013, 03:32 PM
Joined Jan 2013
Its called 'coat hanger'# gauge special run.Dont worry I got many more stupid question to come yet
Thanks again FB for your input.
Old Jan 15, 2013, 05:22 PM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
"I can only get 3.3mm coro so will they fly OK all in 3mm ,wings and all ?"
Headon, 2mm white Coreflute available from here
Coloured 3mm available from some sources and of course 1/8th inch too.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jan 15, 2013, 10:17 PM
Joined May 2004
Rusty. Thanks for posting the correx supply link. I find that finding correx is not easy in some places. I will add that link to page 1
Headon
A coat hangar will work just fine.
Old Jan 16, 2013, 12:32 AM
Stirring the pot
Joined Jun 2008
I only have "plastic"ones!
Last edited by johannlochner; Jan 16, 2013 at 12:33 AM. Reason: J, fearful that he may sound "stupid"
Old Jan 16, 2013, 08:54 AM
Joined May 2004
headon, you can just ignore Jane, he is just poking fun at how we Americans use 'guages' to size our wires
Old Jan 16, 2013, 04:16 PM
When the wind blows
African's Avatar
South Africa, WC, Cape Town
Joined Jul 2012
Tip tanks
Please don't forget the tip tanks !
Ant
African is offline Find More Posts by African
Old Jan 17, 2013, 10:10 PM
Joined Jan 2013
OK,moving along
Should the front and tail wing be level to one another , horizontaly.?? I am sure there is correct terminology I should be using here ,I just dont know the lingo
Old Jan 17, 2013, 10:47 PM
Stirring the pot
Joined Jun 2008
Originally Posted by headon View Post
OK,moving along
Never mind my jack a$$ comments!
You are 100% correct.
It's referred to as the wing incidence, and yes it's set at 0 deg.
It's the imaginary line taken from the wing leading edge to the trailing edge.
(A profiled section is hard to lay down "flat")
Post some photos, it would be great to see your progress!
J
Old Jan 18, 2013, 01:37 AM
Joined May 2004
yes guys.....please post some pics,...
surely there are other Corro-slopeys out there, that have been built with the plans from this thread.....
Old Jan 18, 2013, 03:10 AM
Joined Jan 2013
My corosair ,its been a big learning curve ,cant wait to get this done ... and flying.
Fuzz and wings all 3mm.I cut out every second flute on fuzz and top wing surface to reduce some tension and easier glue down.
Used hot glue on fuzz and contact adhesive on wings.Both take only 30 to 60 sec to go off so the build can continue on all day and night
I use a fan blowing across the work bench continually to get rid of the fumes and it helps the glue to kick off.
Its been an intense few days
Description:
Description:
Description:
Description:
Found EPP, PSS slopers RTF or near RTF in good condition! Phil Davy Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 09:08 AM
Sold Medium weight pss slopers ***Prices Reduced*** Brandon Aircraft - Sailplanes (FS/W) 6 Dec 29, 2007 11:28 PM
For Sale "PRICE REDUCTION" - Slopers for Sale - CSD, PSS, Polecat, Dave's Aircraft Works 664KIX Aircraft - Sailplanes (FS/W) 16 Jul 04, 2007 01:00 PM
Correx or Corroplast in the UK edthedoc Electric Plane Talk 3 Apr 19, 2005 05:37 AM
Correx / Corroplast Park or Indoor Flyer irpilot Parkflyers 1 Oct 08, 2002 07:43 AM
