Jan 12, 2013, 11:42 AM
South Africa, Eastern Cape, Port Elizabeth
Joined May 2004
Originally Posted by headon
I'm going a little crazy just looking at corosairs flying around on my screen ,time to built !!!
I can only get 3.3mm coro so will they fly OK all in 3mm ,wings and all ?
Also ,what weight did you guys add to the nose to get the CG on point ?
If I print out the PDF file at 100% will this be to actual full size scale ?
D
Thanks headon, I think the Corsair surprises us with how well it slope flys with the gull wing, but it just works! I recall we added about 200grams of lead in the spinner. The spinner is a plastic curtain rod cap we found at the local home improvement store. I had a mid-air on Thursday that knocked the spinner clean off, I thought for sure I was going to have to emergency land a very 'pitchy' airframe, but it flew just fine and actually rolled even better. So the CG on the plans might be a bit conservative. Yes print the plans at 100percent or 1:1 on A0 paper. Yes other guys have built using only 3mm, the wing will be just a bit heavier
