Old May 19, 2012, 03:29 PM
Hoonigan is offline
Find More Posts by Hoonigan
Slopers do it in the wind
Hoonigan's Avatar
Joined Mar 2012
That is superb
Any chance of the wind playing the game tomorrow for us?
Hoonigan is offline Find More Posts by Hoonigan
Old May 19, 2012, 03:40 PM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Westery is predicted......but then again, it was predicted for today as well!
So do what I do................................................ refresh GWX every 60 seconds for the entire day till it turns!!
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old May 20, 2012, 12:11 AM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
CorroSpit
great pics Sean, thank you....The CorroSpit felt comfortable from the very beginning, no bad habits, good penetration, and great roll rate.....
need to get the plans updated so we can get a British invasion going in PE !
Flying Beagle is offline Find More Posts by Flying Beagle
Old May 20, 2012, 12:28 AM
aimrah2000 is offline
Find More Posts by aimrah2000
What goes up must come down
aimrah2000's Avatar
South Africa, EC, Port Elizabeth
Joined Aug 2009
Well done on the Spitfire!! Fantastic Job Jim. I am sorry I couldend make it out ther yesterday. Kids come first. But as you said "some other time"
Markus
aimrah2000 is offline Find More Posts by aimrah2000
Old May 20, 2012, 01:09 AM
scurve is offline
Find More Posts by scurve
Andrew
scurve's Avatar
Joined Feb 2011
Well done FB. Awesome.
scurve is offline Find More Posts by scurve
Old May 25, 2012, 01:35 AM
PeterRF is offline
Find More Posts by PeterRF
PeterRF's Avatar
Joined Jul 2011
Very nice Jim, that Spitty really looks awesome.
PeterRF is offline Find More Posts by PeterRF
Old May 25, 2012, 07:53 PM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
awesome FB!!!!! whats next??
draftman1 is offline Find More Posts by draftman1
Old May 26, 2012, 01:20 AM
Joined May 2004
A-10 CorrtHog .... in-progress
Old May 26, 2012, 02:28 PM
scurve is offline
Andrew
scurve's Avatar
Joined Feb 2011
Progress pictures?
Old May 27, 2012, 12:18 AM
Joined May 2004
I am farther along than this...but here's a sample
gonna put up a complete A-10 build post when ready
might work on the CorroSpit plans too
Old May 28, 2012, 11:15 AM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Another Corrospit
Just completed this one - could not wait for FB to work his way through his other creations to finally build his spitfire , so started my own, based on some very detailed balsa plans done some years ago by Dave Philpotts. Tried to keep some the distinctive spitfire characteristics:
1) 'Belly shape' of the nose underside (achieved using a foam block; also provides easy access to battery connection)
2) Flat topped fuse shape at engine bay, transitioning to greater curvature at canopy (large efffort of questionable value)
3) Wing trailing edge to fuselage fairings (surprisingly easy) - gives that distinctive curved transition from wing to fuse.
4) Flat wing centre section (made use of torque rods difficult, so I used pushrods for the ailerons, but would try to make torque rods work if I was building this again)
5) Extended ailerons, but kept them short of full span...just looks better
6) Moulded a coke bottle over a plug to get a more scale canopy
7) Added an (enlarged) air intake - acts as a handle for hand launches, plus used to direct cooling air into the ESC/ battery compartment. Hopefully it will stay on during rough landings
Unfortunately, there is limited wind in this part of the world, so the plane has an "APU" up front. Helps with the balance (needed no balancing weight with a 3300mAh Lipo), but it should work as a sloper as well.
Key dimensions: Span 115cm, ,AUW ~1350g. Flies like a dream. Surprisingly, hand launches are more docile than my Mig, despite all the dire warnings of the Spit's tip stalling vices.
Extreme Sports is offline Find More Posts by Extreme Sports
Old May 28, 2012, 11:49 AM
aimrah2000's Avatar
Joined Aug 2009
[QUOTE=Extreme Sports;21733620]Just completed this one - could not wait for FB to work his way through his other creations to finally build his spitfire , so started my own, based on some very detailed balsa plans done some years ago by Dave Philpotts.
Very well done Extreme Sport! your Spity looks fantastic. It looks like FB has some comptition now...
How did you manage to get the wing trailing edge to fuselage fairings right??
Old May 28, 2012, 12:29 PM
Joined May 2012
Aimrah2000, I simply kept the centre section of the wing top surface as part of the fuselage (In practice I put the wing doubler inside rather than on top of the main wing skin so as to make space for the matching part that is attached to the fuse). I then faired this on top using a triangle of 2mm corex from the thickest part of the wing to the trailing edge (I slit the inside flutes and trimmed to shape once glued on). This has the added benefit of ensuring that the wing is always properly centered. Finally, I melted some holes at the back for the elastic bands to go through. The attached pics may explain better than words.
Old May 28, 2012, 01:27 PM
EATHIS is offline
Find More Posts by EATHIS
EATHIS's Avatar
Joined Sep 2009
Man both those Spits look awesome. Just have to decide which one to fly. Electric driven or air driven. ......Well we have no park- fly fields available ... so it would have to be Jim`s air driven model.
EATHIS is offline Find More Posts by EATHIS
Found EPP, PSS slopers RTF or near RTF in good condition! Just flyy Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 09:08 AM
Sold Medium weight pss slopers ***Prices Reduced*** Brandon Aircraft - Sailplanes (FS/W) 6 Dec 29, 2007 11:28 PM
For Sale "PRICE REDUCTION" - Slopers for Sale - CSD, PSS, Polecat, Dave's Aircraft Works 664KIX Aircraft - Sailplanes (FS/W) 16 Jul 04, 2007 01:00 PM
Correx or Corroplast in the UK edthedoc Electric Plane Talk 3 Apr 19, 2005 05:37 AM
Correx / Corroplast Park or Indoor Flyer irpilot Parkflyers 1 Oct 08, 2002 07:43 AM
