Old Jul 14, 2011, 03:29 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
You certainly will be becoming a mixer expert there Mat, very cool.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jul 14, 2011, 04:18 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Originally Posted by Nobert View Post
Mat
That is an interesting configuration. What size props are you using? Dimensions please.I'm building one when the CC boards are available again.
Neal
Fair bit of info in this thread here http://forums.openpilot.org/topic/5592-y4-layout/
But, in a nutshell
Its a minsoo kim 290mm arm kit http://www.kkmulticopter.kr/index.ht...kk&modeb=Frame
The motors are 925 kv flycams, but rctimer 750's would be sweet for this
Front props are 10 by 4.5
Rear props are 8 by 3.8, you could use 10 by 4.5, would just need a bit more width, you could also use 9 by 5 GWS DD props, and just manually compensate for the yaw effect by adjusting the motor angle (27/33 instead of 30/30)
matwelli is offline Find More Posts by matwelli
Old Jul 14, 2011, 04:27 AM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
Mat, well done. how would you compare it flight wise to a stock quad?
Joshbb is offline Find More Posts by Joshbb
Old Jul 14, 2011, 04:54 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
a quad YAWs like a Tank , this yaws like a Tricopter.
I flew it in blustery conditions, it was very flyable, not quite as solid as my quad(very close), but still needed some tuning
I had a blast flying it, the turns were cool, using a mix of rudder and roll
Inside it is a solid as my quad
Remeber this was my quad i just reconfigured it, so the comparison is using identical components
Old Jul 14, 2011, 04:55 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Thanks Gary, stay posted , i have something special for this weekend if i get time
using 5 channels ..........
Old Jul 14, 2011, 04:58 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
one of my quads certainly doe NOT yaw like a tank.
this is with no height or position hold. just good trimming
FASTEST MIKROKOPTER YAW SPEED (0 min 14 sec)
Quad_Addict is offline Find More Posts by Quad_Addict
Old Jul 14, 2011, 06:07 AM
pbw is offline
pbw
Find More Posts by pbw
pbw
arachnida
pbw's Avatar
Belgium, Flanders, Antwerp
Joined Aug 2008
I also noticed that a good small qaud doesn't have to be slow on YAW, my Asctec FunPilot is really fast. I guess it depends on weight and lenght of the booms. But a trikopter has the fastest YAW I've seen so far.
Your video is amazing as the quad stays nice in place and keeps height!
pbw
pbw is offline Find More Posts by pbw
Old Jul 14, 2011, 06:29 AM
cferrell is offline
Find More Posts by cferrell
I did that on purpose.
Charlotte, NC
Joined Apr 2006
From my heli experience, you're better off with a non-metal gear tail servo. Metal wears out and gets sloppy, but it's very tough during a crash.
Usually a nylon or karbonite type gear train for a rudder is better. Less slop.
Originally Posted by Tatty View Post
I think getting a good tail servo for a tri is a bit hit and miss. I've tried 4 different makes on my t-copter until I found one that had no centre play issues.
I'm using a direct link, so the servo arm directly drives a plastic block the motor is mounted on. Even a small amount of play in the servo can cause excessive vibrations. So far I've found a Tower Pro MG90 is pretty good. A Cronona DS-929MG and even a Hitec HS-65MG were pretty bad.
cferrell is offline Find More Posts by cferrell
Old Jul 14, 2011, 07:29 AM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
http://www.youtube.com/watch?v=Ug9q_NJp38E
I think Mat means like a tank as in when a tank turns it does so on the spot via the tracks, not that it yaws slowly
Old Jul 14, 2011, 07:49 AM
pbw is offline
pbw
pbw
arachnida
pbw's Avatar
Joined Aug 2008
Oh, I see what you mean, missed the point.
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
In Matts video it does not stay in 1 spot when he yaws. If you seen that can you tell me at what time cus I dont see it.
Also it does yaw slow. he even said in another thread it was not flyable outside due to the yaw. I would say it has something to do with the small rear props.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Jul 14, 2011, 09:45 AM
Joined Dec 2006
he meant like a tank like that? oh either way i think i demonstrated that anyways
Old Jul 14, 2011, 09:56 AM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
Testing outside in the wind revealed a serious issue - no where near enough yaw controll to hold its own, and maxed out, pitch is compromised
Broke 5 props testing
so, quick re-config, mounted both motors, side by side at a 30 deg V, and now its a fun machine ! yaw is very authoritive
Handles the wind, and you fly it like a tricopter, mixing yaw and roll for gracefull forward turns
Attached is the mix, if anyone wants to try
Awesome looks like I can use the CopterControl in my Viper then. nice work Matt! very cool
I was using gyros and mixers for this flight and it was tough lol. CopterControl FC will tame the beast. hehe.
Viper Recon VTOL Hybrid quad rotor (0 min 56 sec)
superdave42 is offline Find More Posts by superdave42
Old Jul 14, 2011, 09:58 AM
Joined Dec 2006
http://www.youtube.com/watch?v=DY8Ulp7Rklo
i remember this last year, problem solved. this will be your product or johns tho? or just released plans dave?
Old Jul 14, 2011, 10:31 AM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
your right and that's why he says its not like a quad which yaws like a tank i.e on one spot his y4 yaws more like steering a car to use the same analogy
Discussion The Aussie RCG Coffee thread (aka "we don't drink instant") glydr Australia 164 Sep 08, 2012 03:33 AM
Discussion NEW? -Openpilot flight controller tc3wins Multirotor Talk 229 Mar 02, 2012 05:14 PM
Discussion Share your art! PinkYakRC Painting and Finishing Tips 13 Apr 27, 2011 07:04 PM
Discussion RCG 07 JR Indoor Live Coverage Thread Jim T. Graham JR Indoor Electric Festival 19 Nov 04, 2007 01:36 PM
Discussion My first RCG flame thread WBE Chit Chat 6 Sep 04, 2007 09:17 PM
