Old Jul 11, 2011, 11:54 AM
azred is offline
Find More Posts by azred
United States, AZ, Scottsdale
Joined Jan 2010
HI Rusty
I have tried it both ways in the box, but in reality I am not arming the motors, I have disconnected everything from the board so i did not have any outside issues causing this. I am just trying to get the board, attached only to the usb to show that it is not moving. The Rx and servo outs have all been unplugged and I am not using the Tx just usb power. That is my concern, the board, loaded with the basic quad + firmware is sitting on the floor and yet senses wild movement on 3 axis. It would seem that it should stabilize right after hitting the Zero Accel Bias button, I can't see any other settings that might impact the sensors.
Gary
azred is offline Find More Posts by azred
Old Jul 11, 2011, 12:17 PM
peabody124 is offline
Find More Posts by peabody124
Joined May 2011
Originally Posted by azred View Post
Hi Rusty
the quad has been sitting in the same place for 3 days now, just unplug the usb from the pc for power down and up, i have also used the zero accel bias dozens of times and saved and restarted, the quad does the same thing each time i start it, Flight Data Screen shows level for 2 seconds then pitch up roll left and go into a tumble for 10 minutes or so then the pitch and roll start to center and only yaw continues to show the quad rotating rapidly. Since there is no place i see to the adjust the gyros or accels other than the zero accel button I am beginning to assume the board doesn't work?
Azred. Your gyro values are definitely way off on the scopes. When you rotate the board, do they respond at all?
peabody124 is offline Find More Posts by peabody124
Old Jul 11, 2011, 12:29 PM
azred is offline
Joined Jan 2010
Hi Rusty,
in the screen shot at 12:31:10 - 40 I am shaking the quad, lots of response from the Raw screen, only slight yaw response in the Actuals screen and the Flight Data screen showed some minor movement, but it was spinning so fast it may have been overloaded. From 40 on it is back on the ground.
Gary
Old Jul 12, 2011, 12:55 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Y4 copter control
KiwiRC Y4 Inside (1 min 36 sec)
matwelli is offline Find More Posts by matwelli
Old Jul 12, 2011, 05:16 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
Hey hey well done Mat
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jul 12, 2011, 06:10 PM
blindflight is online now
Find More Posts by blindflight
blindflight's Avatar
CA
Joined Dec 2003
Tricopter info
Hey guys, I'm switching my other board for the Open Pilot board. Before I do this any body had any issues with the servo on the tail. My present board is causing my tail servo to twitch alot, I cannot get the twitching out of the servo. Any recommendations?
blindflight is online now Find More Posts by blindflight
Old Jul 12, 2011, 08:00 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Are you getting twitching or slop in the servo? I have my CC board on a PVC tube tri with an HS-81 servo. My servo has a little slop, but I don't notice it twitching the tail around any.
Vantasstic is online now Find More Posts by Vantasstic
Old Jul 12, 2011, 08:52 PM
CA
Joined Dec 2003
Its some serous twitching...Everything is tight, rods but maybe its the board..
anatoly is offline
Find More Posts by anatoly
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
Which tail servo? I just finished a tri to add to the collection, and I started with a cheap HXT900 servo on the tail. It seems to have a twitch problem, but that's because it's trying to center with a load, or rather the weight of the motor on it. When I switched it out for a Corona 929MG servo, it got a lot less twitchier, but not completely gone. I'm thinking it's more about the servo than the board. I might just have to get something like an HS-81, which has twice the torque of the Corona servo, and there should not be as affected by the weight of the motor.
anatoly is offline Find More Posts by anatoly
Old Jul 12, 2011, 09:04 PM
CA
Joined Dec 2003
Good I'm not crazy . Yep , its some serious twitching with the other board. I'll hook up the CC board and see whats happens...
Old Jul 13, 2011, 02:21 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Testing outside in the wind revealed a serious issue - no where near enough yaw controll to hold its own, and maxed out, pitch is compromised
Broke 5 props testing
so, quick re-config, mounted both motors, side by side at a 30 deg V, and now its a fun machine ! yaw is very authoritive
Handles the wind, and you fly it like a tricopter, mixing yaw and roll for gracefull forward turns
Attached is the mix, if anyone wants to try
Old Jul 13, 2011, 06:19 AM
Tatty is offline
Find More Posts by Tatty
UK
Joined Jul 2002
I think getting a good tail servo for a tri is a bit hit and miss. I've tried 4 different makes on my t-copter until I found one that had no centre play issues.
I'm using a direct link, so the servo arm directly drives a plastic block the motor is mounted on. Even a small amount of play in the servo can cause excessive vibrations. So far I've found a Tower Pro MG90 is pretty good. A Cronona DS-929MG and even a Hitec HS-65MG were pretty bad.
Tatty is offline Find More Posts by Tatty
Old Jul 13, 2011, 11:06 AM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Mat
That sure is Kool. I'm going to build one when the CC boards are in stock again.
Neal
Nobert is offline Find More Posts by Nobert
Old Jul 13, 2011, 11:09 AM
Nobert is offline
Nobert's Avatar
Joined Jul 2002
Mat
That is an interesting configuration. What size props are you using? Dimensions please.I'm building one when the CC boards are available again.
Neal
Old Jul 13, 2011, 03:49 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Been following this project from time to time. Would really like to give one of these a try but I guess many people are waiting on hardware.....
cactus is offline Find More Posts by cactus
Discussion The Aussie RCG Coffee thread (aka "we don't drink instant") glydr Australia 164 Sep 08, 2012 03:33 AM
Discussion NEW? -Openpilot flight controller tc3wins Multirotor Talk 229 Mar 02, 2012 05:14 PM
Discussion Share your art! PinkYakRC Painting and Finishing Tips 13 Apr 27, 2011 07:04 PM
Discussion RCG 07 JR Indoor Live Coverage Thread Jim T. Graham JR Indoor Electric Festival 19 Nov 04, 2007 01:36 PM
Discussion My first RCG flame thread WBE Chit Chat 6 Sep 04, 2007 09:17 PM
