Old Jul 04, 2011, 03:07 PM
Joecnc2006 is offline
Find More Posts by Joecnc2006
www.joescnc.com
Joecnc2006's Avatar
United States, TX, Marion
Joined Jun 2007
Originally Posted by NaterPin View Post
Thank you for the help Joe. Would you need to change the volts on it.
and
Could you post some pics on how you wired it in. If you have the time
the reculator board which the Bluetooth module is soldered to gives the correct 5v to 3.3v step down so nothing is required to be done.
Here are the pin outs and post i did.
http://forums.openpilot.org/topic/53...post__p__17314
Joecnc2006 is offline Find More Posts by Joecnc2006
Old Jul 04, 2011, 04:18 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Joecnc2006 View Post
Example is my Bluetooth connection.
And able to tune quad as per James in his video "OpenPilot TV Episode 2 - PID Tunning"
I tried tying up my quad for PID adjustments. As soon as I powered up the thing just started spinning around (pitch wise) on the string. So much for smooth throttle advancement. Maybe I need so throttle expo. Anyway, I just untied it and flew it to determine what adjustments to make. Anyone have good ideas/directions for a quad test stand?
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 04, 2011, 04:27 PM
www.joescnc.com
Joecnc2006's Avatar
Joined Jun 2007
mine did the same thing, run the RC calibration again Also place a box under the quad to level it and run zero accel bias calibration, and ensure the Zero Gyro Boias is clicked off when arming this should fix it.
Old Jul 04, 2011, 08:43 PM
peabody124 is online now
Find More Posts by peabody124
Joined May 2011
Yeah. That's why I particularly emphasized the RC input calibration at the beginning. I had an entire take of that video where i'm constantly mummbling WT-F to myself cause it was always pitching back at 5 deg/s. Turns out I'd bumped trim.
peabody124 is online now Find More Posts by peabody124
Old Jul 04, 2011, 08:48 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Well the spinning quad on a string was enough to (kinda) scare me from trying it again...for a while at least. I think starting off with a level box would have less chance of wildness...though the video of it made it looked soooooooooo easy.
Old Jul 04, 2011, 08:50 PM
www.joescnc.com
Joecnc2006's Avatar
Joined Jun 2007
throttle up very very slowly, you will gain confidence in it.
Old Jul 04, 2011, 09:19 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Oh I did. My motors don't spin up slow enough evidently. They went from not running to spinning quad almost immediately. Next time I'll make sure to try it outside. I was inside this time...close to the big screen TV. I would have sh&$ had it come off the screen and hit the TV...man would I been in trouble then.
Old Jul 04, 2011, 09:23 PM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
thats why i always get 100% without props on it, are you getting idle speed in motors when arming? assuming you ran all the calibration and motor idle output etc..
Quad_Addict is offline Find More Posts by Quad_Addict
Old Jul 04, 2011, 09:33 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
No, no motor rpms after arming. I do have it adjusted so a couple of clicks of throttle trim does start the motors up...perhaps I should have tried that? Either way...next time it's outside or in the garage.
Old Jul 04, 2011, 09:54 PM
sakumar is offline
Find More Posts by sakumar
Fremont, California, United States
Joined Oct 2001
Ki means integration, it adds some value proportional to error to the Kp every second (or millisecond). So ILimit is to be the bound for that windup. Or it can go crazy.
I'm lost on this still. Perhaps I just need to try it and see what it does.
Here's my understanding:
Take the example of a thermostat where you've set the desired temperature to (say) 75 degrees. The software measures the actual temperature and applies a correction proportional (Kp) to the difference between the desired temperature and the current actual temperature.
The software also adds up ("integrates", "I-term") the observed error over time. Ideally, the overshoot and undershoot will cancel out so the I-term is zero. But it could happen that even though the desired temperature is 75, the system consistently achieves a temperature of 73 degrees when just the Kp correction is applied. So the system has a 2 degree bias. Recognizing this, the software applies a second correction (Ki) proportional to the amount of this bias to compensate.
The "ILimit" sets a maximum amount to the Ki correction.
sakumar is offline Find More Posts by sakumar
Old Jul 05, 2011, 01:57 AM
dankers is offline
Find More Posts by dankers
OpenPilot
dankers's Avatar
Melbourne, Australia
Joined Apr 2004
what people forget is this project is not $$ driven, its about spreading the word and opening the project for all to contribute. of course some money had to be invested and they had to have a cap on this because it costs. i think it has proven to be a very supportive project and will continue even greater with the great response all of us have given them. its only the beginning as far as i can see
Nail on the head there. We always need people to contribute and get involved, that is the whole idea and everyone in the project loves it when that happens. We are working on getting the hardware, this but it does take time, please be patient guys, everyone involved is like you: real lives, real jobs, real families and this is meant to be a hobby for us. We are working on it and we did not expect anywhere near this response.
About clones, no we can not support that, we are non-profit and we have just small margin on the hardware to help keep the project going forward. We do this rather than take donations. If we lose that to cloners, how do we pay to develop new things? We can't, everyone loses except the cloners, I hope this is obvious and buying a clone is simply short term thinking. We are only getting started with CopterControl, we are also working on the Pro as well.
Also cloners will have to cut corners and use cheaper fake parts to make any margin anyway, its not as if our stuff has a huge margin on it. By them using poor hardware, it will result in a worse experience plus people buying clones then try and get support from the project and tie up the developers.
We also work on reducing our costs a bit, we can do this by ordering more boards at a time, this is what we have done for the next larger batch. This cost saving is passed on to you, hence the next batch of CopterControls are going to be $85 and now also include the serial cable (worth $4) by default as well.
I know there is frustration about not having hardware, honestly we are learning as we go, we have made the not enough stock mistake now and do not wish to repeat it! I am sorry about this. However please understand we had no idea if people were even interested in CC, we just made a board we wanted to see and this was the first ever batch.
Again apologies for the stock situation, we are working on it.
dankers is offline Find More Posts by dankers
Old Jul 05, 2011, 07:00 AM
Maxrr is offline
Find More Posts by Maxrr
Sydney, Australia
Joined Jul 2008
Wow, that price is low!
Will make it a no brainer when looking for a easy, fun, multifunction board that can stabilize (and more) almost any RC craft.
Maxrr is offline Find More Posts by Maxrr
Old Jul 05, 2011, 07:01 AM
Kadath is offline
Find More Posts by Kadath
Kadath's Avatar
Quebec, Canada
Joined Apr 2008
Hey, no apologies needed Dankers. What you guys have done so far is just amazing and deserve thanks. The least we can do is wait patiently.
Kadath is offline Find More Posts by Kadath
Old Jul 05, 2011, 07:31 AM
Felias is offline
Find More Posts by Felias
Joined Jan 2011
Originally Posted by Gary Mortimer View Post
Don't worry there are more in the pipeline, but I am not going to say anything about those just yet.
Thats a great thing to hear. Please make sure a number of them are sold in shops that ship to Europe as well :-)
Felias is offline Find More Posts by Felias
Old Jul 05, 2011, 07:32 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
I am one of the shops in Europe, so yes I will ;-)
Gary Mortimer is offline Find More Posts by Gary Mortimer
Discussion The Aussie RCG Coffee thread (aka "we don't drink instant") glydr Australia 164 Sep 08, 2012 03:33 AM
Discussion NEW? -Openpilot flight controller tc3wins Multirotor Talk 229 Mar 02, 2012 05:14 PM
Discussion Share your art! PinkYakRC Painting and Finishing Tips 13 Apr 27, 2011 07:04 PM
Discussion RCG 07 JR Indoor Live Coverage Thread Jim T. Graham JR Indoor Electric Festival 19 Nov 04, 2007 01:36 PM
Discussion My first RCG flame thread WBE Chit Chat 6 Sep 04, 2007 09:17 PM
