Old Oct 19, 2011, 07:20 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
As far as I know that's always looking DOWN on your model from top, so flight control board top = where you're looking to.
eye
V
prop ----- copter ---- prop
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 19, 2011, 07:25 AM
idS2001 is offline
Find More Posts by idS2001
Joined Aug 2011
From where do you have this information? Out of the source code?
idS2001 is offline Find More Posts by idS2001
Old Oct 19, 2011, 08:13 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Propellers are either clockwise (CW) or counter-clockwise (CCW or pusher) - and thats when looking down on them from above.
So funnily enough, we use same basis for copter propellor rotation...
Mike Barton is offline Find More Posts by Mike Barton
Old Oct 19, 2011, 09:09 AM
CX2X3 is offline
Find More Posts by CX2X3
Cape Town, South Africa
Joined Jul 2008
Can someone please direct me to a youtube tutorial on how to use the sparkfun FTDI cable and KK Plus Flashtool to flash a new KK 5.5e Plus board for QuadX ..
CX2X3 is offline Find More Posts by CX2X3
Old Oct 19, 2011, 09:53 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Originally Posted by jaccies View Post
I have a question , the center plate on your website what are the dimensions length , width and thickness of the center plate and what are the diameter of the holes ?
I just updated the product page with dimension in the image tab
Originally Posted by HappySundays View Post
Hey,
I hope I am not spamming threads but I just posted here about my latest update on adding accelerometers to the KK Plus board.
One more step closer to auto-level capability
http://www.youtube.com/watch?v=0u3wI7L-lYM
Nice progress... hope you able to get the ACC work and all will be happy..
Hello Together,
I have only a short question about the motor direction of rotation ( of Motors / Propellors ) which is written in your Readme.
Is the direction when you are looking from the motor to the propellor or if you look down at your multicopter from above.
In the internet there are different meanings of direction of rotation...
regards
dieter
Normally it is view from top down
dt8666 is offline Find More Posts by dt8666
Old Oct 19, 2011, 10:00 AM
dt8666 is offline
Joined Oct 2005
not sure if this will work. I assume you have the TX and RX line with Ground. you have to know which com port it is in.
try with your FTDI RX pin to TX of KK Plus, TX to RX and ground to ground. page 1 do have the 10 pin layout.
with the known com port, you also can follow the info at pg 1 to do step by step to get to the flashing.
Old Oct 20, 2011, 03:31 AM
CX2X3 is offline
Joined Jul 2008
Thanks for the reply, I will try that.. just one more question please.. I see the 5.5e board doesn't have a BootLoader switch like the one in the vid .. is there another way to "switch" it to programming mode, or is it automatically gonna sense the serial cable?
Old Oct 20, 2011, 04:44 AM
dt8666 is offline
Joined Oct 2005
Basically the switch is to cut off the connection of Ail RX line. We have the switch there so if user has the RX connected, you dont need to unplug the cable and just use the switch to disconnect the connection.
we removed it as some user may forgot to switch on and end up with no Ail control. Something with good intend but not that well receive.
for 5.5e, if you have RX cable inserted, just need to remove the Ail cable before you use the flashtool.
Old Oct 20, 2011, 08:05 AM
CX2X3 is offline
Joined Jul 2008
ok i see - thanks very much - I'm gonna be building this copter on the weekend so might have some more questions soon .. but looks like a nice product so far!
Old Oct 20, 2011, 10:37 AM
msev is online now
Find More Posts by msev
Joined Sep 2010
Which is the currently best "flight code" ?
msev is online now Find More Posts by msev
Old Oct 20, 2011, 12:49 PM
United Kingdom
Joined Nov 2008
That's easy
Old Oct 20, 2011, 04:53 PM
msev is online now
Joined Sep 2010
I meant for the KK platform
Old Oct 20, 2011, 05:06 PM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
For what type of multicopter? Single-, Twin-, Tri-, Quad-, Hex-, Y4, Y6, H6?
LazyZero is offline Find More Posts by LazyZero
Old Oct 20, 2011, 05:14 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
KK-mamarico-firmware-2 (2 min 19 sec)
This one...
manuLRK
alll is offline Find More Posts by alll
Old Oct 20, 2011, 11:46 PM
CrazyLittle is offline
Find More Posts by CrazyLittle
CrazyLittle's Avatar
United States, OH, Brilliant
Joined Sep 2011
Originally Posted by CrazyLittle View Post
Ahh, I touched my LCD to the bus bar on my KK board and I think I shorted it out. Is there any way to fix it? It doesn't light up anymore. I have access to two LCDs, and when I plug the piggyback board from the working LCD into my LCD it lights up with solid black bars in the top row. If I take my piggyback board and plug the other LCD into it, it doesn't light up.
Help?
CrazyLittle is offline Find More Posts by CrazyLittle
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 06, 2011 12:34 AM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 0 May 22, 2011 10:14 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 10:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 11:21 AM
