Old Oct 10, 2011, 10:31 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Just search ebay for 'CP2102',, tons of stuff for around $5
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 11, 2011, 12:24 AM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
okay so which one lol
http://www.ebay.com/itm/USB-TTL-Conv...ht_4060wt_1066
http://www.ebay.com/itm/USB-2-0-UART...#ht_4379wt_906
paintball_kidz is offline Find More Posts by paintball_kidz
Old Oct 11, 2011, 12:37 AM
timecop is offline
Joined Dec 2010
All same thing, all work...
As long you have TX/rx/GND... All good
Just make a matching cable out of servo wire or something
Old Oct 11, 2011, 02:38 AM
Epic Huckin'
Surrey, BC
Joined Jun 2007
cool beans, thanks a lot.
I put an order on this one. so cheap D
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_4060wt_1066
Old Oct 11, 2011, 04:43 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
@ Mike, Lazy or 8666
My programming friend has tried to flash the LCD chip, he used AVRstudio something, bt to no avail....... still no action.......no or very litle backlight and only one row with squere dot's.
I think i need a step-by-step...... explanation :-/
I dont remember the name of the programmer he used, but can ask him later today.
For the time being i'm thinking about flashing the board with ordenery KK firmware.
Would ver.4_7X be the right one ?
Thancks
KKai
DrEvil is offline Find More Posts by DrEvil
Old Oct 11, 2011, 05:14 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by yeokiwi View Post
Just got my quadrotor up.
Flown it for a while and it was very stable.
I use Hobbyking quad rotor frame. The frame is alright except the undercarriage is too feeble.
But, for that kind of price, what can you ask for .
Anyway, when will the v5.5e be available for ordering?
want to buy one more piece to do some development...
I have the same HK copter, what adjustments did you have to make for the KK+ board and you transmitter to fly it stable ?
jaccies is offline Find More Posts by jaccies
Old Oct 11, 2011, 05:32 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
I don't have Dans LCD, but looking at the picture of it in the first post, it should be straightforward...
He needs to use a proper programmer and then hot-wire from programmer to the 6 holes on the board.
If he's using AVR ISP MkII, he will need to supply power to the board as-well.
Oh - and don't have it plugged into LCD.
Mike Barton is offline Find More Posts by Mike Barton
Old Oct 11, 2011, 07:04 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
1. As i understand him, it's a proper programmer, and i soldered the 6 wires to the holes on the board.
2. We did supply the board with 5V power.
3. And the LCD panel was not connected.
As for looking in the first post showing it to be straight foreward.... he he ! me big noob....
KKai
Old Oct 11, 2011, 07:18 AM
United Kingdom
Joined Nov 2008
KKai
That generally sounds OK - for connections:
Code:
LCD holes	ICSP Pin
MO(si) 		4
ReSeT		5
MI(so)		1
SCK		3
5V		2
Gnd 		6
If this doesn't work, try switching the MOsi & MIso wires.
Old Oct 11, 2011, 08:01 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Hey. All the point are labelled so you just need to follow the point to match your avr cable.
5v power from the 3 pin cable.
Should be straight forward flash. And please disconnect from the LCD module.
dt8666 is offline Find More Posts by dt8666
Old Oct 11, 2011, 12:08 PM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Code:
LCD holes	ICSP Pin
MO(si) 		4
ReSeT		5
MI(so)		1
SCK		3
5V		2
Gnd 		6
What software to use ? Witch version ? Links ?
KKai
Old Oct 11, 2011, 12:51 PM
gsundi is offline
Find More Posts by gsundi
gsundi's Avatar
Sissach
Joined Mar 2008
@Dan,
I just noticed there is the new XX15e Software on the download page.
I can see twice the QUAD+ Version, but no Version for Tricopter.
Is this a mistake or will the Tri-Version come later?
Any documentation about the difference to Version XX15d ?
Chris
gsundi is offline Find More Posts by gsundi
Old Oct 11, 2011, 02:04 PM
United Kingdom
Joined Nov 2008
What software to use ? Which version ? Links ?
KKai
In AVR Studio 4 (or 5) and using say AVR ISP MkII programmer or other supported programmer:
  • click the AVR chip icon (next to Con).
    The first time you do this you will need to select the correct Platform/Port for your programmer.
    Next, the programming window will appear.
  • Select the 'Program' Tab and in the 'Flash' section click the '...' button to select the hex file.
  • The click Program button to burn hex file to chip.
Old Oct 11, 2011, 02:16 PM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
KKai
The programmer is a : stk500 v2
I hope i can use this one ?!?!
KKai
Old Oct 11, 2011, 02:24 PM
United Kingdom
Joined Nov 2008
KKai
STK500 (and STK600) is listed, so you *should* be ok ...
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 06, 2011 12:34 AM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 0 May 22, 2011 10:14 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 10:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 11:21 AM
