Old Aug 07, 2011, 04:59 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi all.
Can i use this adapter to reset the Lcd display:
http://www.multircshop.com/site/inde...&product_id=67
or the :st500 V2 ?
Kai
DrEvil is offline Find More Posts by DrEvil
Old Aug 07, 2011, 05:02 AM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Hey guys sorry to post this here, but I have an extra kk + board with LCD I listed in the F/S section if any one is interested. it is in + mode, and I can't use + mode. as the my other KK + boards are in X mode and work perfectly these are the best kk boards out there. and I have a question, will that new . kk board addon with the GPS and sensors work on this board?
tc3wins is offline Find More Posts by tc3wins
Old Aug 07, 2011, 05:05 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi all
Can this adapter be used to reset the Lcd displ. ?
or the st500 V2 ??
Kai
Old Aug 07, 2011, 05:07 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
If resetting a LCD display just requires connecting a TTL serial console to it at a certain speed, then yes that'll work. If resetting it means reloading new firmware, then no it won't work. I think it's the former though.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 07, 2011, 05:21 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
I just need to reset Baudrate to defult speed.
the MKusb or the st500 v2 ??
Kai
Old Aug 07, 2011, 05:23 AM
timecop is offline
Joined Dec 2010
mkusb. (or any other ttl serial/usb thingy). I'm SURE you can find one locally....
Old Aug 07, 2011, 05:34 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
It's Sunday...... and i'm unpatient
My friend has one
wil visit him later today.
Thanks Timecop
Kai
Old Aug 07, 2011, 06:19 AM
coomarlin is offline
Find More Posts by coomarlin
Joined Jul 2004
[QUOTE]
You *do* know that all kk-boards are in "heading-hold" mode for all axises, right? I.e. once you push stick to left and release, quad tilts left, it will STAY left until you apply equal amount of right stick. Same for forward/backward direction. The only channel not affected by this is yaw.
Actually I was not aware of this. When I hear gyro I think auto correction. But I guess it doesn't work that way. I thought that by having gyros that it would auto level itself when I took my hands off the right stick. Oh well, I'll get used to it with more practice. Just gonna take longer than I thought. All of you experts make it look so easy in your videos. The thing is, you rarely see novice videos of people barely controlling their quad. Too embarrassing to post them I guess
I'll try turning up the gain just a tad more and see what happens.
Thanks to everyone for being so helpfull in this thread.
coomarlin is offline Find More Posts by coomarlin
Old Aug 07, 2011, 07:18 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Originally Posted by DrEvil View Post
Hi all.
or the :st500 V2 ?
Kai
yes, you can use that MKUSB.
Pin 3 is the TX pin. which you should be able to connect to the RX of the LCD.
Pin 10 is GND and Pin 2 is 5V
The above is refer to the top row of 10pin
if you use the opposite of the USB port 10pin row, the pin is:
Pin 1: RX
Pin 2: 5V --> to LCD 5V
Pin 7: GND --> to LCD GND
Pin 9: TX -- > to LCD RX
Hope you can solve this with your friend. also refer to the video
dt8666 is offline Find More Posts by dt8666
Old Aug 07, 2011, 08:19 AM
sheep600fx is offline
Find More Posts by sheep600fx
United Kingdom, England, Tiverton
Joined Dec 2006
right struggling here, everythings connected and i have the lcd with my board. the lcd is garbled. Baud is 9600bps i cant access lcd timing? board arms when i move throttle bottom right(left stick) and dis-arms when i move it bottom left(left stick) so i assume ive got things set right. I move yaw right but nothing happens,please help me oh and no tech talk im thick lol, oh also im using this frame http://tinyurl.com/3rg73n6 and think ive got the wrong firmware pre installed, I have xxcontrol hexa installed but think i need h6, can i do this with the lcd ?
sheep600fx is offline Find More Posts by sheep600fx
Old Aug 07, 2011, 08:38 AM
timecop is offline
Joined Dec 2010
Well that link wasnt particularly helpful but if its the flyespider 200 then no, you got correct firmware, hexa.
Old Aug 07, 2011, 08:51 AM
Joined Dec 2006
right thanks yup its the spider 200, right got lcd working,need to move the yaw stick as soon as you plug in battery,delay and you miss it, adjusted timing and working perfectly,now to configure it lol
Old Aug 07, 2011, 08:56 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
If LCD baud rate is 9600 and display is garbled, you need to do the 'Adjust LCD Timing' as detailed in the ReadMe.
Just power the board on and immediately hold Yaw stick to Right for >3seconds.
If LED flashes at regular intervals, then you need to re-try
Then just use the TxYaw stick to change the timing - LED will flash when you make a change
You must unplug and then re-plug display in after each change.
Mike Barton is offline Find More Posts by Mike Barton
Old Aug 07, 2011, 09:02 AM
Joined Dec 2006
Thanks Mike, I wasnt being quick enough holding the yaw stick :-), thanks for replying though
Old Aug 07, 2011, 09:03 AM
DrEvil is offline
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
we cant figure out what software you are using to reset the lcd.
Got any links ??
Not happy !
Kai
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
