Old Aug 02, 2011, 12:34 PM
JohnnyDeluxe is offline
Find More Posts by JohnnyDeluxe
Lavishly Winged Dork
JohnnyDeluxe's Avatar
Miami, Fl
Joined Feb 2004
Originally Posted by coomarlin View Post
Just feels like I'm trying to balance a basketball on a broom handle (well maybe thats an exageration but it does feel squirelly.)
Have you tried messing with your Tx expo? Read somewhere where it was suggested to someone with similar problem.
JohnnyDeluxe is offline Find More Posts by JohnnyDeluxe
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
THanks, I will remove the props and try your suggestions. My controls seem to be moving the quad in the correct direction when I apply them. Pitch, roll, and yaw. Just feels like I'm trying to balance a basketball on a broom handle (well maybe thats an exageration but it does feel squirelly.)
When using the Diagnostics method, you need to remember that gyros respond to acceleration about an axis.
So when you tilt copter forward you intially accelerate it but then invariably decelerate it. So gyro adjust will add, but then quickly subtract.
Make sure you read it on the accelerate.
Regarding PID, for you I suggest you simply change the Gyro gain % in the Setup:Basic/Gyro menu option.
Forget PID for now - it just complicates things....
Sorry, but I'm not sure quite what squirelly means whan applied to a copter
Mike Barton is offline Find More Posts by Mike Barton
Old Aug 02, 2011, 05:49 PM
coomarlin is offline
Find More Posts by coomarlin
Joined Jul 2004
I tried a few things. First off I held the quad from the bottom and advanced the throttle to just under a hover. I tried tilting the quad along the roll and pitch axis. I felt resistance in both directions. I then got into the controll menu and looked at the gain numbers. The roll was set to 55% and I upped it to 90%. The pitch was set to 90% and I left it there. The Yaw was set to 50% and I left it there. Do these values seem normal or should they go further?
I attempted to fly again in my basement and to my surprise it felt much better. I was still afraid to take it more than 4 feet off the ground. I played around for about 10 minutes trying to get the feel of it. So I let it rest and replaced the battery and took it outside in the yard. Outside the quad felt more unstable. It wasn't windy so I'm not sure why.
I noticed in the perfectly calm basement that it seemed like I need to apply a couple of clicks of right roll trim and a little back pitch trim. I set my smartphone up to take a video and realized after I stopped flying that I had forgot to press record. I had ahard landing and I thought it must be time to quit before I tore it up.
Bottom line I still think it needs properly adjusted and tweaked. But it's generally set up properly and my problems are pilot related. I remember feelign this way when I learned to fly RC planes 11 years ago.
I also set my roll and pitch expo to -70. That also seemed to help. Should I also set expo on yaw and throttle?
coomarlin is offline Find More Posts by coomarlin
Old Aug 03, 2011, 02:02 AM
United Kingdom
Joined Nov 2008
The gyro gain may be a little high, but since no quad is ever exactly the same, difficult to say.
You may find that it flys ok in your basement on this setting, but outside, it may oscillate (basically, it over-compensates) out of control when you perform brisk manouvers.
If it does this, you need to turn the gain down until stable.
Old Aug 03, 2011, 07:14 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
I am a little bit confused. Which of the imges shows the correct wiring for the LCD?
or
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Aug 03, 2011, 07:23 AM
Joined Jul 2004
or
Best Christian
For version 1.5 I wire it like your bottom picture. I put the red wire on pin 2, the white wire on pin 9 and the black wire on pin 10. Works fine. I don't use a clip like the one you show. I just put the pins in individually
Old Aug 03, 2011, 07:29 AM
Joined Jul 2004
Concerning the LVA..... I'm using a 3 cell lipo. Should I set the LVA for 10.8V. As far as calibration is concerned should I connect the battery and then use a multimeter to measure the voltage coming from the distribution board and then enter it into the program menu?
Old Aug 03, 2011, 07:49 AM
United Kingdom
Joined Nov 2008
Setting it to 10.8V would obviously mean 3.6V per cell.
You will probably find that the alarm sounds early as under high throttle manouvers, the voltage will dip.
I would probably go for slightly lower but this is personal preference tho'
Correct - in the Calibration option, it shows what it thinks the battery voltage is, so, if it's not quite right (due to component tolerances etc), just adjust it.
Old Aug 03, 2011, 07:50 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Okay that is the problem. I used the upper image from the 1 Post. and connected the LCD input to 8, I think this was mentioned in one post.
Best Christian
Old Aug 03, 2011, 07:57 AM
Joined Jul 2004
Okay. So since Lipo's shouldn't go below 3.0V per cell Maybe I should set it for 3.2V/cell or 9.6V total? What setting do you guys use?
Old Aug 03, 2011, 07:59 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I usually alarm at 10.3V just to be safe.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 03, 2011, 09:11 AM
helixjones is offline
Find More Posts by helixjones
Joined Oct 2007
LCD help
hi can anyone help! i have connected the lcd and power supply. the lcd comes on, shows smart LCD, then baud rate then nothing. Tried two boards. both the same
helixjones is offline Find More Posts by helixjones
Old Aug 03, 2011, 09:55 AM
United Kingdom
Joined Nov 2008
What is the baud rate on the display ?
Is the LED on the KK board flashing every 4 or 5 seconds ?
Old Aug 03, 2011, 10:01 AM
Joined Oct 2007
Baud is 9600 and led is not flashing
Old Aug 03, 2011, 10:12 AM
United Kingdom
Joined Nov 2008
OK
Does the LED flash ever when you power on ?
There *should* be an initial 'I'm Alive' flash when you connect power.
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
