Old May 26, 2011, 10:27 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
Originally Posted by dt8666 View Post
as your wish... easy upgarde to other gyro
the close to final board will have the connection ready for other gyro and WIP on that MEMS gyro as well..
are you happy now...and more features coming.. stay tuned...
oh very nice
Quad_Addict is offline Find More Posts by Quad_Addict
Reply With Quote  (Disabled)
Old May 26, 2011, 10:36 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
and... value for $ LCD module...
okok...stop for today... more coming later... too much to diggest
What else you need? how much you willing to park your $ for the LCD??
dt8666 is offline Find More Posts by dt8666
Old May 26, 2011, 10:37 AM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
I want 1 of those
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old May 26, 2011, 12:13 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Instead of Rx pin header, provide a wire(s) with RC-female plugs that can be directly put in the receiver...
Don't forget the R10 to be a variable pot instead of a fixed 68Ohm!
manuLRK
alll is offline Find More Posts by alll
Old May 26, 2011, 08:26 PM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
I have motor-drop problems on my new hex where the power to all motors drops for 1/4 second every few minutes. I have seen this before on my tri with HK SS 25A programmable esc's - resulting in changing esc's.
It appears many have glitches like this due to the 400Hz pwm speed on the KK board. My new machine (hex) has 6 x rctimer 30A esc's which have been good in the past but this batch all have the glitch.
Some have shown how to flash the esc's - has anyone changed the pwm down to 150 or 200Hz on the KK board? Is it possible? I can't be the only one struggling with this problem...?
I've got 6 rctimer, 6 HK SS 25A and a few HK 18-20A esc's that can't go on the KK board... I've orded 6 x Plush and I hope they work (just like I hoped the rctimer ones would work).
Pete
Efliernz is offline Find More Posts by Efliernz
Old May 27, 2011, 12:51 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
some videos of the testflights...
was not sunny so the videos are not the best... will upload another funfly video these days.
kk 5.5 plus board - setup flight (2 min 33 sec)
kk 5.5 plus board - testflight no1 (2 min 17 sec)
kk 5.5 plus board - testflight no2 (2 min 15 sec)
warthox is offline Find More Posts by warthox
Old May 27, 2011, 03:23 AM
dt8666 is offline
Joined Oct 2005
nice... Warthox signature.. flying any quad like a toy... lol
Old May 27, 2011, 07:35 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
What else you need?
2 PLEASE and 1 LCD as in 2x boards and 1LCD a package like that would suit me down to the ground
but PLEASE keep the price low
n3m1s1s is offline Find More Posts by n3m1s1s
Old May 27, 2011, 11:27 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
manuLRK testing KK Plus V5.5x "beta"
28-may-2011 18:40
Firmware used : Mike's original XX code adapted by Minsoo KR v1.5
All videos are in "Normal mode".
Transmitter endpoints all to 100%, without expo
Findings: (I will only mention "negative" points , all the rest is assumed to be good!)
  • It is well known that the Murata gyros need to acclimate to the surrounding temperature. If you are not patient for this, frequent disarm-arm landings are needed to reinitialize the gyros.
  • Better to use (like heli gyro's) wire plugs instead of pin headers (personal preference)
  • The 68Ohm R10 (210Ohm R9) gives 1.63 Vref. To be save (for 3D flying), and don't reach too quickly the ADC 1023 limit, I would use a 100Ohm R10 resistor instead to get 1.8Vref.
    Otherwise this can happen (see video). And increasing Vref to a safer value doesn't affect the behavior too much (i don't notice it).
video comes here ...
Here a demonstration of what is possible to achieve with the KKPlus board.
I used XXKR v1.5 and added
* PID yaw control
* Low Voltage Alarm (set to 3.7 V / cell)
* And some other mixing mods
Be warned, to get to this, you need a "good" multicopter and a "good" software well tuned and some flying experience.
KKPlus board fun in the garden (3 min 55 sec)
http://www.rcgroups.com/forums/showp...postcount=1125
First i used (these were used with the WMP gyros)
ACRO_STICK_ROLL_GAIN = 150
ACRO_STICK_PITCH_GAIN = 150
And this is what happens then with 100% endpoints:
So i reduced these!
Final settings of XX KR v1.5
Code:
// Adjust these:
// 		down if you have too much gyro assistance
// 		up if you have maxxed your gyro gain
#define ROLL_GAIN_MULTIPLIER 	3	// 3
#define PITCH_GAIN_MULTIPLIER 	3	// 3, Twin: 4
#define YAW_GAIN_MULTIPLIER 	3	// 3
// Stick Gain
#define NORMAL_STICK_ROLL_GAIN	50		// Stick %, Normal: 50, Acro: 60~70
#define NORMAL_STICK_PITCH_GAIN	50		// Stick %, Normal: 50, Acro: 60~70
#define NORMAL_STICK_YAW_GAIN		70		// Stick %, Normal: 50, Acro: 60~70
#define ACRO_STICK_ROLL_GAIN		60 //150 //70		// Stick %, Normal: 50, Acro: 60~70
#define ACRO_STICK_PITCH_GAIN		60 //150 //70		// Stick %, Normal: 50, Acro: 60~70
#define ACRO_STICK_YAW_GAIN			90 //150 //70		// Stick %, Normal: 50, Acro: 60~70
#define UFO_STICK_YAW_GAIN			90 //155 //90		// Stick %, Normal: 50, Acro: 60~70, UFO: 80~90
#define ADC_GAIN_DIVIDER			200		// Gyro Value Range (-100~100: 150, -150~150: 225, -250~250: 375)
Hello everybody,
I just got the beta test board in my letter box! Thanks Dan & Markus.
After a quick visual inspection, and figuring out the programming pin layout, i couldn't wait to put it on one of my quads (+).
Uploaded the KR v5.1 firmware (to be in sync with the tests of Warthox ) but for a "+" quad.
All tests are done by holding the quad in my hand!
  • Had to raise the board because of the yaw gyro is mounted under the board. Good about this is that i could put the receiver under the board. However, it would be good that one side of the board remains "flat".
  • Once board fixed, and connections made, i set the pitch pot ccw to zero to do a "stick centering"
  • Powered the board (via power supply first, you never now... ), armed, and bingo, the green led went on. Perfect!
  • Gave some throttle input, all gyro directions were OK (lucky ).
Only problem with this beta board, on the roll gyro there is a problem! Sometimes it is ok, sometimes it completely input random signals, sometimes it does not give any signals!
When the roll gyro didn't gave any signal, tried to "bent" the board, and then the weird roll signals appears.
So, for now i can't fly , will look for a bad solder connection...
Here some pictures already of the setup. I hope I can solve the bad roll gyro behavior!
manuLRK
Old May 27, 2011, 02:31 PM
warthox is offline
Joined Aug 2009
Originally Posted by alll View Post
Hello everybody,
manuLRK
great to hear the board arrived save.
i fly with the preloaded firmware. dan said its the XX KR 1.5
so i think it was not necessary to flash it again.
i had the same problem with the gyro. i resoldered the gyros, the resistors from the gyros and the pots. after that everything was fine.
i think it was a bad solder joint.
here are the funfly videos. the other quad is a mwc
and i tried the acro and ufo mode
kk 5.5 plus board - testflight no3 funfly part1 (2 min 39 sec)
kk 5.5 plus board - testflight no3 funfly part2 (3 min 15 sec)
Old May 27, 2011, 02:51 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Yes, thanks for the quick delivery
Yes, i know, did is as a test, i used XX KR 1.5 and i add some personal features i like. (default acro, stick centering, some good stuff of Mike...)
Will try that if Dan agree?
Haaa, this is how you (mal)treat your test equipment!
What does ufo mode do apart from normal mode + faster yaw?
manuLRK
Old May 27, 2011, 02:54 PM
Joined Dec 2006
http://vimeo.com/24325420
http://vimeo.com/24326348
always look like having fun i need people like this close lol
Old May 28, 2011, 01:03 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Hi, good news, same problem as Warthox on my board, bad solders joints!
Went over the solder joints of the gyro and pots. This solved the problem!
Will try to "stress test" today, weather is not ideal...
manuLRK
Hello everybody,
manuLRK
Old May 28, 2011, 03:21 AM
dt8666 is offline
Joined Oct 2005
Thanks. Hand solder too many board so some of them not perfect.
Glad resolder solved it. The production board should not see this.
Thanks.
Old May 28, 2011, 11:58 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
see post #69 manuLRK testing KK Plus V5.5x "beta" for further test results:
Thanks.
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
