Old May 21, 2012, 02:45 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by carguy1994ca View Post
EDIT: 9600 baud rate and version 3.0 g
Not sure whose firmware that is ....
Mike Barton is offline Find More Posts by Mike Barton
Old May 21, 2012, 03:21 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Hi all ! I have been flying a little my KK plus last autumn and just got back to it. I am having problem with the LCD putting out unreadable characters. Just after connectiong, I see the bauds prompt and the it goes with some @@@@@@@ and such instead of displaying "basic menu".
I did some search here and could just find connecting the board to the computer as a programming solution. Is that it ? Should I reflash it ? I think I have the d or e firmware version, board was bought somewhere last summer.
Hi that is your LCD module firmware version. Is your version shows as Smart LCD Pro? You can reflash the LCD module to other version that has fixed 9600 if needed.
However, as in earlier discussion, some Atmel chip may have a little off in timing that will not be able to show correct display. If you have a board as that way, one of the alternative is to use the Virtual LCD.
dt8666 is offline Find More Posts by dt8666
Old May 21, 2012, 03:24 AM
dt8666 is offline
Joined Oct 2005
Just reliased the post number pass 3000 !!!
OK, with this, decided to do a limited time offer of the KKP + MEMS Combo at 30% OFF standard alone order!
YES... It is Live now at the webstore:
http://www.multircshop.com/site/inde...product_id=640
Old May 21, 2012, 06:04 AM
TheZero is offline
Find More Posts by TheZero
South Africa, GP, Krugersdorp
Joined Aug 2011
Hi Mike
Just flashed your 1.6j software and ... well done ... best software so far!!!!
No wind at the moment, but should have some later in the afternoon.
Just a quick question, my spider drifts forwards and towards the right ... my pitch and roll trims are virtually on the end before the spider hangs still. The ESC's are calibrated, stick cal done (with trimms in middle), spider well balanced around COG and spider 100% level during arming.
My props are not balanced yet, could vibration cause drift in one direction only? Or will vibration cause it to drift in any direction?
Again, thanks for 1.6j!!!
TheZero is offline Find More Posts by TheZero
Old May 21, 2012, 06:11 AM
TheZero is offline
Joined Aug 2011
Dan
Interested in package special, but already have spare PPM encoder, don't need it with my TX?
Old May 21, 2012, 07:10 AM
United Kingdom
Joined Nov 2008
Hi
is this in Acro or Stable modes ?
with Stable-mode, the copter does need to be level @ 1st arming after power-on.
If it's happening in Acro mode, then it's harder to pin down.
The only occasion I have had a trim problem was due to bad motor bearings...
Old May 21, 2012, 07:31 AM
TheZero is offline
Joined Aug 2011
Stable mode, and yes it's 100% level (using a level for checking).
Not a problem, just thought it might be something simple.
Thanx for the reply.
Theo
Old May 21, 2012, 07:32 AM
TheZero is offline
Joined Aug 2011
Theo
Old May 21, 2012, 10:07 AM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
How do I use the virtual LCD ?
carguy1994ca is offline Find More Posts by carguy1994ca
Old May 21, 2012, 11:13 AM
chipko is offline
Find More Posts by chipko
Come fly with me ...
United Kingdom, West York
Joined Oct 2007
Wow! 3,000 posts! Glad I was here for the journey - thanks to you and Mike I've really learned to fly a quad (could fly basic co-axial indoor helis and pretty good outside with an aeroplane). Not only fly, but build, flash, and film.
I had a thought - get a KK+ t-shirt that on the front says "I fly KK+" and on the back? Detail what a quadcopter is .. I had to laugh inside when I was flying last night...
Passerby: "What does does it actually do?" (Really?!)
Me: "It just flies ..that's all" (not JUST though)
Passerby "Give up!" (in order words, I don't believe you, stop pulling my leg)
... then I took off
What a fantastic offer you are giving us all Dan .. I want to order but I don't get paid until Friday, will the offer still be available then? *fingers crossed* I can't wait to get another quad with your board and Mike's firmware...
My first "fast" flying LOS video from last night - from the onboard GPS 52.3kmph
Quad KK+ LOS fast flying (for me anyway) (4 min 35 sec)
chipko is offline Find More Posts by chipko
Old May 21, 2012, 01:18 PM
chipko is offline
Joined Oct 2007
Oh and Dan, I now notice you offer the mems installation.. Just wondering if you make it so you can switch the firmware for HappySundays and Mike's FW with a jumper...
I was going to also try HappySunday's FW but I like how I dont need to cut a track for Mike's
Old May 21, 2012, 01:42 PM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
see this post 2986
jaccies is offline Find More Posts by jaccies
Old May 22, 2012, 12:33 PM
chipko is offline
Joined Oct 2007
I love my KK+
Old May 22, 2012, 02:48 PM
Quebec, Canada
Joined Sep 2006
Originally Posted by jaccies View Post
see this post 2986
Thanks, just don't have a bluetooth PC But someone on another tread told me it could be that I triggered the baud rate adjust without knowing while I was trying to boot the KK controller. Gace me some instruction to see if it is the problem, will try that.
EDIT: Just went to the 1st page of this tread and if I had taken care to read it carefully, its all there. Sorry if I asked a repetitive question guys
Old May 22, 2012, 03:51 PM
chipko is offline
Joined Oct 2007
I'm not sure if you can use a PC but I wouldn't see why not .. if you can you could probably get a bluetooth dongle to add BT to your PC (and probably less than $10)
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
