Old Jan 28, 2012, 02:40 PM
gdenton3 is online now
Find More Posts by gdenton3
United States, TX
Joined Dec 2002
I flashed my board with XX15h, it would arm everytime I needed it to. Took it outside where it's ~50 degrees F and after a few minutes it would no longer arm. Took it back in the house and after a few minutes it started arming again.
Any ideas?
gdenton3 is online now Find More Posts by gdenton3
Old Jan 28, 2012, 02:54 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Timing is changing due to the temp most likely not the firmware. Raise your throttle trim two clicks above low and recalibrate. Then when you take it out in the cold lower your throttle trim all the way and see if it arms. If the esc doesn't have resonator or crytal clock the throttle range will change with temp. All atmel running on internal osc will change with temp including one on flight board.
Any ideas?
pug398 is offline Find More Posts by pug398
Old Jan 28, 2012, 02:55 PM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
Originally Posted by Mike Barton View Post
OK, regarding Rx/PPM options, there are some considerations:
Manufacturers have not standardised on only one sequence of the Rx channels
Some better Tx/Rx do allow this sequence to be user-changed, others do not...
I have catered for different sequences by allowing different eeProm hex files to be flashed after the main program flash.
This is straightforward using say a proper programmer, but, I'm not so sure what the options are when using the typical usb flash devices that abound.
Using a converter *does* allow more flexibility inthat you can set whatever sequence you want, but at the cost of more wires
I previously mentioned you need a 5+ channel RX, but I think in reality you need at least a 6 channel one (1 more than the number of channels you need).
I use a FrSky PPM Rx which outputs in Roll/Pitch/Coll/Yaw/Aux sequence and this will be the default channel sequence.
I will make available other eeProm hex files for the different channel sequences will be available.
Dumb question here... I have the FrSky V8FR 2.4Ghz 8CH Receiver (HV). Will this work?
g00bd0g is offline Find More Posts by g00bd0g
Old Jan 28, 2012, 03:18 PM
United States, TX
Joined Dec 2002
I just tried that but still didn't work.
I even calibrated with min throttle @ -75%, lowered to -100%, still no good.
Old Jan 28, 2012, 03:50 PM
pajonate is offline
Find More Posts by pajonate
pajonate's Avatar
United States, NJ, Fair Lawn
Joined Dec 2009
@Dan and @Mike,
Hmmm,
I experienced a weird situation with my tri (k.k 5.5e with h firmware. I posted couple of videos of me flying it yesterday(http://www.rcgroups.com/forums/showt...92740&page=489, post #7332). When I got home I saw that my yaw servo (Metal gear one from HK, not the cheapest ones, $20) is not moving freely to one of the directions. I have opened it and one of the gears was stripped. No crash at all. In my pre-flight check it was moving freely with the Rx inputs.
Anyhow, I have another MG servo, from EMax, and I've put that one. No changes were made to any other component in the system.
I went out to try it, and suddenly everything is off. The model on my Tx is the right one, but my tri spins clockwise like crazy, What's happening is the tri needs a lot of yaw trim to right, which is OK to some extend, but now i need a lot of right roll trim and a lot of negative pitch.
What can cause this. With these corrections it flies almost as before. I've recalibrated the ESC, I have the board reset-ed, nothing changed, I still needed those adjustments.
I tried the TxStickAdj, but whatever value I put I don't see much difference in controlling the tri. I had -10 on yaw tx trim, and then +10 after that and nothing noticeable.
Any thoughts?
pajonate is offline Find More Posts by pajonate
Old Jan 28, 2012, 03:56 PM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
Any ideas?
I am flying my k.k board on 25-30F and it works/arms fine. Only thing is my zip ties are too brittle and break easily on little rough landing. Emphasis on little rough. I am hovering mainly so I don't do any crazy stunts/crushes yet.
Try lowering the throttle trim, or recal the ESC.
Board off, set the full throttle with no positive or negative trim, connect the board, after the 2 or 3 beeps (depends on the ESC) lower the throttle stick, and wait for the long beep. Unplug the battery, and plug it again, but with the throttle on minimum.
If it doesn't arm, lower the trim a couple of clicks
Old Jan 28, 2012, 04:29 PM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by pajonate View Post
@Dan and @Mike,
Hmmm,
Any thoughts?
Yes - are servo directions consistent ?
I'm thinking your new servo works in the opposite direction to the previous one
Try reversing the Yaw gyro....
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 28, 2012, 04:36 PM
United Kingdom
Joined Nov 2008
Any ideas?
I'm assuming you mean that the board won't arm, rather than the ESC's bleeping.
The only thing stopping arming is the Yaw Stick arming point not being passed (unlikely) or Collective being above zero.
Easiest way to check this is to plug in lcd and look in Diagnostics/Rx/Collective & Yaw numbers (in []).
It's probably Collective, so just trim down a little on Collective so it goes below 0.
Old Jan 28, 2012, 05:10 PM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
@Mike,
yes the servo movements are right. With all that trim on my Tx I am getting a stable flight, and moving the yaw stick to right, spins the tri CW, and vice versa, so reversing the servo is not needed.
Is there some programming trim on the board where I can adjust these settings, cause when I arm the board the yaw motor on my tri is level, not tilted at all. It needs trim as soon as I put the throttle on.
Also, why I needed to add roll trim where before that it flew level with no trim. Do I need to increase the roll/yaw gains maybe, cause I see no oscillations, but also no correction.
What do you think?
Oops, do you think I need to reverse the gyro direction on the Setup:Basic or Advanced? Hmmm, that might be it, but please, clarify was that what you had on mind.
Another thing, what is the difference between the hyster settings. I think mine is set to 0, and if I set it to 1 it is not flyable at all.
Old Jan 28, 2012, 06:38 PM
United Kingdom
Joined Nov 2008
<oops> duplicate
Old Jan 28, 2012, 06:49 PM
United Kingdom
Joined Nov 2008
@Mike,
What do you think?
OK, forget reversing of gyro
Theoretically, changing the servo should not affect the Roll trim.
Can you check that when you go into Diagnostics/Tx/Roll, that the nett output number (in []) is zero when centered ?
I'm suspecting that maybe temperature changes are causing it to generate a small trim adjustment by itself maybe.
Actually the hysteresis is quite important since it widens the TxStick centre point.
Alot of Tx sticks have poor mechanical links and releasing a stick will often result in a nett output when infact it should be 0.
So effectively it's like having small trim set (so causes drift) when you don't actually want it.
This could well be part of the problem.
I'm confused as to why it should make your copter un-flyable
Old Jan 29, 2012, 01:42 AM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
Mike, someone else mentioned the temperature change might caused the change.
Regarding the hysteresis, when I had it at 1 it was sinning , so no lift off was attended, cause the tri left the ground spinning CW very fast and no yaw imput would correct that. I unplugged the tri, change the hyster to 0 and it worked fine, just with a lot of trim on my JR8303 yaw stick.
What the TxStick/TrimAdj is modifying? I had -10 and after that +10 on Yaw trim and I couldn't see any change. Now I have it at 0 to be on a safe side.
Also, do you recommend taking the tri out for some time before I power it up, to give the board elements accommodate the changed values?
Thx.
Pajo
Old Jan 29, 2012, 03:23 AM
United Kingdom
Joined Nov 2008
Pajo
That is very strange
I still think it will work better with hyteresis enabled.
The amount of adjustment is quite small, but is being applied
Certainly for gyros, letting them aclimatise before arming will reduce their subsequent drift.
If the Roll drift is being caused from a nett offset from the Rx in the FC (the oscillator runs faster due to temperature change), then you either need to do:
  • Re-do TxStick calibration in the menu when it has aclimatised
  • apply Roll TxStick adjust trim on Tx
  • apply Roll TxStick adjustment in menu Setup:Advanced/TxStick/TrimAdj/Roll
Old Jan 29, 2012, 11:29 AM
United States, TX
Joined Dec 2002
Got it working by resetting eeprom and re-cal'ing TX.
Couple of observations:
Could you blink the LED when switching between modes?
While hovering in stable mode I heard all motors momentarily cut-out intermittently, I never heard this in default mode.
Now waiting for calm enough winds to try some circuits.
Thank you Mike for this fw and your work on er9x!
Old Jan 29, 2012, 12:31 PM
United Kingdom
Joined Nov 2008
Hi
You can re-do TxStick calibration any time - re-setting eeProm wipes out all your settings.....
I don't see a problem with a momentary flash of the LED when switching modes.
Ah! so you found the line of code I left in saying: 'briefly stop motors in stable mode'
No seriously, it's almost certainly your Rx briefly dropping into failsafe mode.
My FrSky does it occasionally, but reconnects immediately (unlike my previous Spekrum did )
No problem on the XX firmware...
but er9x ? fraid you're confusing me with someone far more talented than moi
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
