Old Nov 06, 2011, 01:18 AM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
Okay, So I got male to male servo plugs finally... I went to test my board with 3 servos and 1 more but when I plug it nothing happens, the led just starts blinking and thats it. I have no control and the controls dont move at all.
paintball_kidz is offline Find More Posts by paintball_kidz
Old Nov 06, 2011, 06:00 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Hi kidz.
Will be easier for all to help if you can always provides the details like:
Config: tri? Quad + or quad X etc
Firmware: KK classic? XX KR? XXController etc
Picture of all your connection
dt8666 is offline Find More Posts by dt8666
Old Nov 06, 2011, 07:54 AM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Could someone please tell me how a KK Black board can arm itself without a reciver hooked up to it. It had set on the bench for well over an hour with the battery plugged up (MY BAD) and no rx hooked up. But the light was out. And much to my surprise and guess in the room she armed herself and took to much havic and distruction not joking it was not funny at the moment she trashed herself and a wall and some paperwork. Along with making us almost shs ourselves. Do I have GHOST or what. The paint stick quad is now splinters.
kd4wen is offline Find More Posts by kd4wen
Old Nov 06, 2011, 10:58 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by kd4wen View Post
Could someone please tell me how a KK Black board can arm itself without a reciver hooked up to it. It had set on the bench for well over an hour with the battery plugged up (MY BAD) and no rx hooked up. But the light was out. And much to my surprise and guess in the room she armed herself and took to much havoc and destruction not joking it was not funny at the moment she trashed herself and a wall and some paperwork. Along with making us almost shs ourselves. Do I have GHOST or what. The paint stick quad is now splinters.
Yes, they can arm themselves - it depends on what the stick arming combination is.
It normally requires low Collective, so it it does arm, it shouldn't normally fly away...
however....
since the Rx Inputs are floating, anything can happen and they can easily pick up spurious electrical signals which could be interpreted as say: Max Collective !!
I do not recommend powering up a copter with propellers on but no receiver - its asking for trouble ...
Mike Barton is offline Find More Posts by Mike Barton
Old Nov 06, 2011, 11:25 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I didn't order the LCD when I purchased one of these boards, but accidentally selected a software version that needs the LCD to adjust parameters. Is there a tutorial anywhere that can explain how to flash the board with a different software using one of these:
http://www.ebay.co.uk/itm/USBtinyISP...item27beda2bf6
Cheers,
LG
lovegroove is offline Find More Posts by lovegroove
Old Nov 06, 2011, 11:54 AM
DerRose is offline
Find More Posts by DerRose
Germany
Joined Oct 2010
Hi Folks
I have a question regarding the KK+ board with the use of the smartLCD.
I connected the board like it is shown @ multiRC:
LCD KK Plus
RX ------> 9
5V ------> 2
Ground ------> 10
After switching the board on (with connected RX), I see these two screens:
1) Smart LCD pro Ver 3.0f
2) init OK baud 9600 8in1
Each screnn is 1 Sec activ, and after this I just can see the backlight. Can somenone tell me if this is right? How can I access the menu?
As multiRC says, the Baudratw with 9600 is ok. Also I can see the Menü structur here:
http://www.multircshop.com/site/banners/...D_Menu.pdf
But I have no idea how to access the menu or how I navigate throgh this? Can someone please help me?
Is there anywhere a real manual from th KK+ board?
Thank from GER,
Michael
DerRose is offline Find More Posts by DerRose
Old Nov 06, 2011, 04:57 PM
United Kingdom
Joined Nov 2008
Originally Posted by DerRose View Post
Hi Folks
<snip>
Is there anywhere a real manual from the KK+ board?
Thank from GER,
Michael
After the Baudrate screen, you should be seeing:
Copter: QUAD+ (<= or whatever type firmware you have).
If thats not appearing, there is a problem.
Is the LED flashing at 5 second intervals ?
Does the LED flash once when you move TxYaw left or Right ?
Old Nov 06, 2011, 09:17 PM
dt8666 is offline
Joined Oct 2005
Hi Michael
Can you show a picture of your setup? Maybe easier to find out the issue that way.
If you don't see the greeting message:
XXController by Mike Barton follow by the display of your loaded mixer (quad or tri or hex etc), may need to check all the cable connection. Including the LCD.
Old Nov 07, 2011, 12:46 AM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
Just got my KK Multicopter 5.5e. Couple questions...
Is there a manual for this board? If I could find it I probably wouldn't have to ask the rest of these questions
Should I get the LCD? Are there any features that require it?
How many amps can I push through the integrated power distribution bus?
Is it necessary to re-orient the board when changing from + to X configuration? i.e. rotate 45 degrees to keep it pointed "forward"...
Which + and X firmwares should I be using? I plan on both 1st person aerial videography and 3rd person acrobatics.
Is there a collection/comparison of the common firmwares available somewhere?
Attached is a screencap of the frame I am designing. Uses 10mm Carbon Fiber square booms from HK. I'll 3D print the center and motor mounts.
g00bd0g is offline Find More Posts by g00bd0g
Old Nov 07, 2011, 02:12 AM
allcopter is offline
Find More Posts by allcopter
中国, 广东省, 东莞
Joined Jul 2011
re: a lot of Q
hello ,
//Daniel make a lot of info on page 1.
// if u use KR fireware, DO NOT need SmartLCD.
// if u use mike Firware, to get some useful feature( like . LVA, LED , PID , misc... ) Please get one LCD.
// >40A Total, For quad 10A enough for hover flying.
// u can use 2s 3s 4s ,even high voltage when u install Recom DCDC model.
// normally, we use 3s, bec(5v) of ESC for powering KK PLUS.
// Yes, It is necessary. when changing from + to X .
// X is better for FPV. + is better for beginner.
// yes, Daniel make big effort to collect firewares on his web store.
// www.multircshop.com
// looks good!
//PS : Have a good flying. (english is not my native language)
allcopter is offline Find More Posts by allcopter
Old Nov 07, 2011, 02:24 AM
dt8666 is offline
Joined Oct 2005
Thanks AllCopter,
Basically, it is hard to have a manual as at least we have three firmware in the market that runs on KK. That is why i point that to each of the source for the manual of each firmware.
For the XXController that uses LCD, I do have the readme file in download page
For the KK firmware, it is within the firmware source code or with the link that I setup in page one or the webstore
Old Nov 07, 2011, 04:57 AM
DerRose is offline
Germany
Joined Oct 2010
Thank you fpr your answers!
Hi Michael
Sure! Here it is:
The Quad fyes pretty good out of the box (emax 2822, HK SS 20A and Hitec Optima 6), but I'm looking forward to tune a bit.
OhOh, when I check my order it says:
KK Plus V5.5d Multicopter controller
>> - Flash Firmware Option: XXControl_KR v2 Quad +
>> - USB Linker Bundle:: USB Linker for KK+ Flash KKPlus V5.5d
So the LCD won't work with this fimrware, right?
I cannot really find a manual :-(
BR,
Michael
Old Nov 07, 2011, 06:30 AM
dt8666 is offline
Joined Oct 2005
Hi. The firmware is XXController KR so it is not working with LCD.
The setup manual for krfirmware is www.kkmulticopter.kr/index.html?modea=manualor
Old Nov 07, 2011, 08:00 AM
DerRose is offline
Germany
Joined Oct 2010
dt8666
Thank you for your supprt. Maybe you can tell me which firmware is the best for me:
-I'm flying RC for 6 years
-I owned a X-Ufo with X3D board for 1/2 year
-I want to train myself and start equip my copter with light FPV system soon
-I like an easy way to setup the board
-I own a smart LCD
-Iloocking forward to have a stable platform an donÄ't want to fly acro
A recommendation is very welcome! Thank you!!!
Beside this, is it possible that the flash device
http://www.multircshop.com/site/inde...product_id=603
and the KKplus tool (1.23) is not working good with Win7 64bit?
BR,
Old Nov 07, 2011, 09:13 AM
dt8666 is offline
Joined Oct 2005
dt8666
-I own a smart LCD
BR,
Hi Mike,
if you already have a LCD module, you may like to try the 1.5e code from Mike Barton:
If you fly Quad with + mode:
http://www.multircshop.com/site/bann...D+_M168_EN.hex
If you fly Quad with X mode:
http://www.multircshop.com/site/bann...DX_M168_EN.hex
Also please look at the readme file as it tells how to setup the motor and also the steps needed to setup the firmware
http://www.multircshop.com/site/bann...e_ReadmeV2.txt
As for the question in Win7 64-bit, I am running Win7 64-bit on my notebook and no issue. Just make sure you loaded the driver as suggested and also to ensure you have your com port number ready for the flashtool
Hope this helps.
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
