Old Oct 25, 2011, 11:56 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by jaccies View Post
oops 10 glitches you mean after powering up
if it happens again what i dont hope ( dont like glitches ) i will report the raw values.
so my raw values are normal around 849 to 887?
errmm maybe not a glitch if 10 times in a row
Next time it happens, take down the numbers and note if the readings change with movement.
Yes, those numbers are fine.
<edit> I think you *may* have a bad connection on one of your gyros .....
Mike Barton is offline Find More Posts by Mike Barton
Old Oct 25, 2011, 12:58 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Hey guys, I no longer have my KK boards so for sale I have the
5V Serial LCD Module:http://www.multircshop.com/site/inde...product_id=593 and the
Pololu USB AVR Programmer: http://www.multircshop.com/site/inde...product_id=595
I am looking for either $25 shipped for each or both for $45 shipped.
Thank you!
airbagit13 is offline Find More Posts by airbagit13
Old Oct 25, 2011, 01:10 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
Is there a mixer for a quad v-tail or Y6 v-tail?
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Oct 26, 2011, 02:23 AM
HappySundays is online now
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
MultiWii GUI interface for the KK Plus board and NeXtcopter software
Hello,
Here's something new for the KK Plus that I am working on.
For full details, look in the NeXtcopter thread in this post.
MultiWii GUI for KK Plus board (0 min 58 sec)
HappySundays is online now Find More Posts by HappySundays
Old Oct 26, 2011, 04:42 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
After powering up the board this morning the error showed up again.
checking the Gyro/diagnostics i had values:
Roll 849-0=849
Pitch 155-0=155
Yaw 887-0=887
when i move the copter raw values dont change!
When i had that error i did about 3 times powering up and got still that error,
after number 4 powering up error was gone.
I did not touch the board at all !
What could be wrong?
jaccies is offline Find More Posts by jaccies
Old Oct 26, 2011, 04:59 AM
United Kingdom
Joined Nov 2008
Roll 849-0=849
Pitch 155-0=155
Yaw 887-0=887
ermm .. the Pitch value - it's too low !!!
They must be between 300 and 975.
Not sure why the values don't change tho'
Examine the Pitch gyro solder joints.
Check Pitch gyro voltage next time it happens....
Old Oct 26, 2011, 05:34 AM
jaccies is offline
Joined Dec 2008
I checked also gyro/diagnostics when i have no error at startup
i see now that pitch is varying when copter not moving
and is at stable level 465 -360=110 and the value 465 keeps varying between 430 till 470
copter wants to flip over backwards, and is very unstable
where should i measure pitch gyro voltage?
<edit> i seee now when i push on the board the value changes back to 886 , so it must be a solder joint or defective pitch gyro?
Old Oct 26, 2011, 06:04 AM
United Kingdom
Joined Nov 2008
Those numbers: 465 - 360 = 110 are not good.
The zero point is suspiciously low.
You can re-do the Gyro Calibration (when dis-armed!) by putting Collective Stick high. This will re-set the Zero point numbers
When still, the nett output (right-hand number should be max +/-2 !
To measure the Pitch Gyro voltages, I have attached one of Dans pictures with Roll & Pitch gyros indicated.
Vin's should be ~4.7V (this can vary by +/-0.2)
and Vout's should be ~ 1.38V (this can vary by +/-0.2)
ps: just seen your edit - yes, it could possibly be a bad solder joint ....
Old Oct 26, 2011, 06:07 AM
CX2X3 is offline
Find More Posts by CX2X3
Cape Town, South Africa
Joined Jul 2008
Originally Posted by dt8666 View Post
not sure if this will work. I assume you have the TX and RX line with Ground. you have to know which com port it is in.
try with your FTDI RX pin to TX of KK Plus, TX to RX and ground to ground. page 1 do have the 10 pin layout.
with the known com port, you also can follow the info at pg 1 to do step by step to get to the flashing.
Do you need power to the 5.5e board to flash to quadx.. I have only 3 wires connected like in vid but via FTDI cable ..
when I open port I get "successful" but when I plug in the cable I get "Please check the connection and Power"
I have also tried to swap rx and tx as there's conflicting posts on this thread but still get same message either way around
CX2X3 is offline Find More Posts by CX2X3
Old Oct 26, 2011, 06:55 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Check the Vref, not sure you accidentally adjusted the Vref Pot.
the picture shows the Vref point that you can measure, it should read 1.63V (refer to lower right hand text in the picture)
dt8666 is offline Find More Posts by dt8666
Old Oct 26, 2011, 06:57 AM
dt8666 is offline
Joined Oct 2005
Yes, you need to power the KK Plus after you open the serial port.
you can power it using your ESC cable connected to one of the motor pin.
Old Oct 26, 2011, 07:52 AM
CX2X3 is offline
Joined Jul 2008
thanks so much for the quick reply.. that worked (I think) it completed the flash to Quadx from the pc .. but I cant get the LCD to display anything but garbage.. so I cant confirm
I have tried to change set the board rate from the flash tool.. and also the "timing" but only get some garbage characters when in "timing" mode, otherwise the display is always blank
I have also somehow managed to dim the lcd display..
what am I doing wrong here? :-)
Old Oct 26, 2011, 08:07 AM
dt8666 is offline
Joined Oct 2005
Hi,
that might be the LCD timing adjust needed as you can get from the readme file.
Did you see 9600baud at power up of the LCD?
Old Oct 26, 2011, 08:15 AM
CX2X3 is offline
Joined Jul 2008
Hi,
no the lcd shows nothing on power up.. and only garbage if i start moving up or down in the timing mode
Old Oct 26, 2011, 08:26 AM
dt8666 is offline
Joined Oct 2005
CX, at power up, it should display the baud rate for a second. if not, i am not sure if your LCD is ok or not.
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
