Old May 25, 2011, 02:10 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
KK Plus 5.5d/e Best value Enhanced KK Controller And MEMS/ACC Module
KK Plus – A Multirotor controller based on Rolf’s aka KaptainKuk (KK) great work and design. The board uses the version 5.5 design but we also added the enhancement taking the feedback from users to make it as friendly as possible for DIY projects.
KK Plus has the standard KK features:
- Atmel MCU (168 on KK Plus)
- Support upto 6 motor/esc
- 3 Trim pot
- 3 Piezo Gyro
- Programming port for firmware upgarde
Enhancement that is unique to KK Plus:
- Many ports already bring out from the Atmel MCU pin for DIYs to use
- 3V output ready for external sensors that uses 3V, example the MEMS Gyro
- Integrated power distribution board for ease of ESC Power Connection
- Added the Vref pot so user can change to other Gyro that need other Voltage Ref
- Added pin put for LCD module that support Mike's XXController firmware
- Pre-loaded with bootloader for easy flash or firmware upgrade. Flashing now just needs serial link and no need for AVR programmer
- Integrated Low Voltage Alarm circuit, 5.5e with integrated LED driver for 12V LED strip (max 400mA)
GREAT NEWS on the release of MEMS Module complete with IDG 650 / ISZ 650 / ADXL 335.
Now in stock
Example of modification of the KK Plus:
1. PDF file for XXController firmware (Thanks to Mike Barton)
2. Build log from David's NextCopter firmware here (Thanks to David)
3. Also updated here
Release history / Firmware download
14 Jan
Beta test (not release yet) of the MEMS/ACC module, preview
June 2011:
- KK Plus 5.5d, the 1st production board, and custom firmware from XXController by Mike Barton
Oct 2011:
- KK Plus 5.5e, (removed bootloader switch, added dedicated LCD Pin out and integrated 12V LED Driver)
- XXController 1.5e firmware
Nov 2011:
- XXController 1.5f (Enhancement with elimination of balloon effect commonly reported in many KK firmware)
Dec 2011:
- XXController 1.5g (Wider gain setting, simpler Menu and feel better as the developer said )
Early Jan 2012:
- XXController 1.5h (Increased TX Raw Rate, board LED Flash when Arming the board and Gyro initialisation, Gyro gain changes will not affect TX Rate)
End Jan 2012:
- XXController 1.5i: Added Lost model beep function (auot disarm and trigger LVA), Simplified LVA menu, fixed minor bug on LVA calibration
- Released of MEMS module with: 3 Axis MEMS Gyro, X/Y ACC, 3V circuit
March 2012:
- XXController 1.6 relased from Mike for KK Plus with MEMS module
May 2012:
- Improvement to 1.6, 1.6j
The current shipping progress/updates: here
In stock Now: BELOW USD30 !!
Order open at www.multircshop.com
Good news for those who want the ready to use (aka RapidESC) FASTPWM 30A ESC to take full advantage of the fast speed of MultiRotor firmware. It is also availble with limited quantity here.
Reference:
Simple Quad or multirotor setup guide
Nice build info on Tri:
http://www.rcexplorer.se/projects/tr...copterv25.html
___________________
Video for sharing: More video from user can be found within the thread
Video from user with FPV:
http://www.rcgroups.com/forums/showp...postcount=1006
http://www.rcgroups.com/forums/showp...postcount=1235
Example of a Quad with KK Plus and XXControl firmware. all at default settings:
KKPlus Quad (2 min 14 sec)
Example of a Y6 with KK Plus and XXControl firmware. all at default settings: (some tuning, this will perform well)
KKPlus on XXControl Y6 (2 min 20 sec)
Example of how easy to use the LCD with the XXControl firmware:
KKPlus 5.5c with SmartLCD (4 min 47 sec)
KKPlus LCD Menu Setup Demo (9 min 1 sec)
Example of Low Voltage Alarm calibration and setup when using the XXControl 1.5d
KKPlusLVADemo (3 min 16 sec)
__________________________________________________ ___________________________________
FAQs:
Information about Flashtool for easy firmware upgrade:
The KK Plus flashtool example: how to flash the KK Plus in text format below and the video.
Demo video of using the USB Serial Linker to flash the KK Plus:
KK Plus Flash Tool with USB Serial (4 min 20 sec)
or refer to: http://www.rcgroups.com/forums/showp...&postcount=464
Note about the XXController firmware by Mike Barton:
When using the XXControl firmware that support the LCD Menu, you can refer to the Reame file for the setup and the pdf file for the LCD Menu system.
something to bear in mind is that the Configuration Menu is active whenever the copter is dis-armed.
The software doesn't know if the LCD is plugged in or not.
So whenever the copter is dis-armed, don't play around too much with the TxRoll/Pitch sticks as you could accidently change some settings
Info on LCD Baud Rate:
If your LCD baud rate changed for some reason (with LCD shipped with SMART LCD Pro firmware), you can refer to the video on how to reset it to factory default or 9600n1 with any terminal software
LCD Baud rate reset (1 min 59 sec)
Or use the flashtool for easy baud rate reset
What you need:
USB to Serial connection
Example is the MKUSB or USB Serial
KK Plus Flash tool, refer to download page
Which firmware for the KK Plus??
- XXController V1.5d/? is the custom version for KK Plus with LCD output to pin 9 of 10 pin port (5.5e have a dedicated LCD connection). Also support the LVA
-XXcontrol 1.4x, KK, XXControl_KR work as normal wihtout the LVA. Unless you can edit the source code to add the LVA routine.
- KK Plus also support the standard KK firmware:
* Classic KK from KK directly
* XXController from Mike
* XXController_KR from Minsoo
* NextCopter from David
LCD firmware to fixed it at 9600 baud:
http://www.rcgroups.com/forums/showp...&postcount=890
Missing COMDLG32.OCX when running the Flashtool:
http://www.rcgroups.com/forums/showp...&postcount=860
Please note that Win7 64-bit may need this file to be copied to syswow64 folder
MSCOMM32.ocx KKPLUS_Tools V1.23 error message:
http://www.rcgroups.com/forums/showp...postcount=1001
How to set the LVA:
http://www.rcgroups.com/forums/showp...&postcount=977
Reset baud rate using the Flashtool
http://www.rcgroups.com/forums/showp...&postcount=984
How to enter into LCD timing adjust mode (when you see junk character when baud rate is correct @ 9600)
http://www.rcgroups.com/forums/showp...&postcount=989
ESC BEC, should I cut the rest of the 5V line and only have one ESC supply the power to the board and RX?
- From some ESC reference maual, it stated if you are using the ESC with switching BEC, you must NOT connect more than one.
- From one of the reading if I remember it is from HobbyWing, it does recommend to have it as parallel and it will double up the amp rating. Please make sure this is the normal anlogue BEC
- If you are not sure, just use one ESC with BEC will do. the board and the RX current draw is very small
Where the RX and the KK Plus gets it power from?
Both are taking the 5V from the ESC
How the Low Voltage Alarm work?
- You must have the LVA code included to the flight control firmware. The XXControl 1.5d/e/? firmware already precompiled with the LVA code
- You must enable, calibrate and set the LVA. refer to the LVA demo video for details
- You must have the Lipo +ve supply to the KK Plus +ve pad (the distribution board). the LVA will take the Ground direct from the ESC BEC connection.
The Ail stick not responding, cannot select LCD menu and also cannot do roll control:
- Please ensure the bootloader switch is at ON position if you have the 5.5d KK Plus
- Please also ensure you have the RX Aileron Channel plug in to the correct pin
Schematic for the KK Plus 5.5d:
http://www.rcgroups.com/forums/showp...postcount=1157
dt8666 is offline Find More Posts by dt8666
Last edited by dt8666; Jun 02, 2012 at 06:44 PM. Reason: constantly updated with the latest info
Old May 25, 2011, 02:36 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
dongs
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 25, 2011, 02:44 AM
dt8666 is offline
Joined Oct 2005
Originally Posted by timecop View Post
good try... but close.....
Old May 25, 2011, 05:36 AM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
Nahhh with the gyros it's a bit more expensive I think.
I would say it could be a hot product for 60-70$ including shipping.
iacei is offline Find More Posts by iacei
Old May 25, 2011, 06:09 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
looks good will it auto level now like a homemade wii board that would cost around $40/ $50 to build?
n3m1s1s is offline Find More Posts by n3m1s1s
Old May 25, 2011, 06:10 AM
timecop is offline
Joined Dec 2010
blogged out
Old May 25, 2011, 06:28 AM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
none of the kk stuff autolevels. With gyros $60-70?? you do realize those gyros go for $3-4/ea in *single quantity* right?
I HATE Wii boards. The are a PITA to program UNLIKE the KK board. I have MANY KK multis and if you CAN fly you dont need autolevel. I would NEVER use autolevel to SPORT fly. It is ONLY for NOOBS and AP. I have a Wii board in my big Y6 and you have to fool around with the parameters to bget it to fly good. ALL my KK boards were just mounted and ALL I had to do was adjust the pot gains. NEVER had to even hook them up to a computer.
BTW TC ALL u do is BASH in a suttle way EVERY FC but your own. NOT a good way to do business. Makes u look BAD.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old May 25, 2011, 06:30 AM
Z06 Tony's Avatar
Joined Sep 2008
Good GO build one then will ya. Do you think everyone wants to BUILD a board?? I DONT! most that like to build cannot fly so they spend more time building than flying. I am the opposite. I LOVE to fly and building does not excite me at all.
Site Sponsor
Old May 25, 2011, 06:35 AM
ddmt is online now
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
If multiwii is hard to you, gosh you'll hate coptercontrol then
anyway it would be nice if they ditch the piezo gyros and replace them with mems gyros, I've seen KK board with mems and they can use much higher gain.
ddmt is online now Find More Posts by ddmt
Old May 25, 2011, 06:38 AM
Z06 Tony's Avatar
Joined Sep 2008
CC looks MUCH more user friendly than MWC. I never even tried to setup the MWC cus I did not like the interface. Not everyone that flies multis is a computer geek. I HATE computers. Only ike them to surf, skype, and E-mail.
Site Sponsor
Old May 25, 2011, 06:41 AM
timecop is offline
Joined Dec 2010
blogged out
Old May 25, 2011, 06:48 AM
Z06 Tony's Avatar
Joined Sep 2008
get your facts straight.
unless you link me to exact posts where i was not bashing "my fc" (wat is that anyway?) i will report your post for trolling. I have ONE single thread on this entire forum for something I actually care about offering to people and unless you have specific examples where i'm spamming "my products" or whatever elsewhere, you're just wasting time (mine, and mostly yours).
Read post #2.
BT all someone has to do is click on your nic and "see all posts b TC" to see your subtle bashing. Maybe your not sure what bashing means. Post #2 is a good example.
Site Sponsor
Old May 25, 2011, 06:51 AM
timecop is offline
Joined Dec 2010
It's more or less well known that hobbyking's KK board ripoff will be around 20bux or so whenever that becomes available. How is naming appropriate price bashing it?? Thats one more post of you trolling for no reason.
Old May 25, 2011, 06:55 AM
Z06 Tony's Avatar
Joined Sep 2008
I think there is a language barrier here. If you dont know what bashing means look it up.
Site Sponsor
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
bleeeeee ..... eeeeep
I also find KK boards a lot easier to work with than MWCs.
Simon
SSM is offline Find More Posts by SSM
Discussion NEW KK Multicopter Core Board V5.5 Quadcopter and firmware loader terriwang Multirotor Talk 1 Apr 05, 2016 04:21 AM
Sold KK Multicopter Core Board V5.5 Quadcopter and firmware loader $95 Shipped terriwang Aircraft - Electric - Multirotor (FS/W) 20 Jun 05, 2011 11:34 PM
Gallery KK Multicopter multicontroller v5.5,330 and MK sean520 Multirotor Talk 3 Apr 03, 2011 09:47 PM
Discussion Wanted -- KK Multicopter controller // XX Controller Chris Moon Multirotor Talk 0 Feb 07, 2011 10:21 AM
