Leader Hobby GY520 MEMS Gyro
Received this gyro from Leader Hobby yesterday:
http://www.leaderhobby.com/product.asp?ID=9394001220733 It boasts that it is a MEMS PID fuzzy logic gyro. Analog and digital servo support. It cost me $12.50 + shipping, on sale. Update: Uses the InvenSense ISZ-650 MEMS sensor There are no labels on the plastic case. The display is a single tri-color LED, which is clearly seen through the plastic case, when lit. Manual: http://www.leaderhobby.com/img/menu/GY520Manual.pdf HX900 manual: (easier to understand, thanks to monkeyhanger) http://queenhobby.com/imageupload/3661/HX900Manual.pdf It's about the same size as the Turnigy Mini MEMS gyro. It uses the conventional two plugs for the receiver and a shorter flying lead for the servo. The wires are a good size and look to be strong. The Gain plug has two sockets in it even though only one wire is connected. This helps to stop the plug from falling out. Unfortunately there was no mounting hardware supplied. ![]() Picture of inside: Some components appear to be hand soldered. The MEMS sensor appears to be on the bottom covered in black silicone. When I opened the case the board was not level in the case, and needed to be pressed in further. I will be gluing the board in with E6000 and adding E6000 to the wire solder joints. On the bench the gyro appears to work well. Note: - Make sure your rudder EPAs are set to 100 or higher and you dual rates are at 100% before attempting to program the gyro. - Leave the tail servo disconnected until servo type has been set. The default is digital 1520us 280Hz. - Leave the tail control pushrod disconnected until each limit is set. - If you can't get into programming mode, try setting the rudder trim to full in the direction you are pushing and holding the stick. This is known to fix a problem with the Walkera TX2603 getting into program mode. - The yellow parameter color is not obvious. It's more of a green with a touch of red. - Option 3 is set to 1 by default (not 3, as stated in the manual). I was surprised 3 and 4 were not the other way around (3 = 3 and 4 = 1), especially with it defaulting to a digital servo. - Don't be fooled by the pause in the parameter value flash. There is a longer off period for the end of value, as opposed to the pause after every two counts (see page 9 of the manual). The manual is quite hard to read. Here are some simplified programming instructions. Programming: - In rate mode (green led) hold the rudder stick at full right or left until the LED turns red, and then release quickly to center. This is option 1 (Servo type). - The LED will flash the parameter value (i.e. -- -- - is 5). The default for the servo type is 2 flashes (1520us 280Hz). - Push the rudder stick a short distance to the right or left (under half) and return to center, to change the parameter value. Check the flash count. - Hold the rudder stick at full right or left to change to the next parameter and release to center. If the previous value was changed it will be saved. Holding the rudder at full right or left, will cycle through the parameters at a fast rate. - To exit program mode switch to heading hold mode or move to a new parameter and power down the gyro. Note: - When the left or right limit parameter is reached, the first time, the servo goes to full travel. Make sure your pushrod is disconnected, until you have both the left and right limit lowered. The limit cannot be changed quickly and may damage your servo - To adjust the limit parameter, push the rudder stick a short distance to the right or left (under half) and return to center. The servo will move a fixed step, each time this is done. - Subtrim can be used with this gyro to center the servo. It will learn the new center at switch on. - The gyro will not initialize until it sees servo data from the Rx. Videos: Setup video (thanks to Rob2160): http://www.rcgroups.com/forums/showp...&postcount=230 250 flight: http://www.rcgroups.com/forums/showp...&postcount=165 250 flight (thanks sp00fman): http://www.rcgroups.com/forums/showp...&postcount=360 450 flight (thanks sgbfly): http://www.rcgroups.com/forums/showp...&postcount=200 450 flight (thanks Rob2160): http://www.rcgroups.com/forums/showp...&postcount=225 450 flight (thanks sp00fman): http://www.rcgroups.com/forums/showp...&postcount=356 450 flight (thanks Arey): http://www.rcgroups.com/forums/showp...&postcount=370 450 flight (thanks sp00fman): http://www.rcgroups.com/forums/showp...&postcount=459 My settings: 250 1 = 760us 560Hz (DS95i) 2 = Normal 3 = 2 (direction speed) 4 = 1 (delay) Rudder dual rates (L:55%, R:65%) Expo 15% Gain 24 7mm ball position 40mm blades Tail pitch slider has full travel 450 1 = 1520us 280Hz (D261HB) 2 = Reverse 3 = 3 (direction speed) 4 = 1 (delay) Expo 40% Gain 32 10mm ball position (recommend starting with 7-8mm) Pro tail blades Tail pitch slider has full travel Testing will be on a HK450 V2 with pro head and belt pro tail. The tail servo is an Ino-Lab HG D261HB with a 10mm ball position. Currently the tail is rock solid with a GP780. Test mount: ----------- Single sided foam ======= metal plate -- ....... -- Two strips of double sided foam (Velcro strap goes through here) ======= metal plate ----------- double sided foam The gyro will be strapped to the 1/16 single sided foam on the top, which will allow quick removal, for testing other gyros. ebay link (USD$14.48 + ship): http://cgi.ebay.com/GY520-Head-Lock-...item2312981330 Also sold as a FMT-40 from FMT Model: http://www.ebay.com/itm/F01874-FMT-4...-/270818131078 Now appears to be sold as a Tarot GY550, with a nice thin case, but more expensive: http://www.rcgroups.com/forums/showt...2#post19333112 |
Joined Sep 2009
Hey beenflying,
very interesting, thanks for the report. ![]() I would be most interested about learning a bit more about the hardware. You said, "The MEMS sensor appears to be on the bottom covered in black silicone.", not sure how to interpret that, I would have thought that the "black square" in the left corner in your picture would be the MEMS sensor (looks like an Invensense). Could you take two closer-up photos from both sides of the print board? Olli ___________ www.olliw.eu |
I assumed the top chip was the MPU, since the bottom chip (similar size), had the silicon. The top chip's number is too hard to read, even with a 7x loop. I suspect there would be nothing more to see in the pictures.
Latest blog entry: RC Parts Suppliers - The Good and the...
Joined Sep 2009
thx for your quick reply
"The top chip's number is too hard to read, even with a 7x loop. I suspect there would be nothing more to see in the pictures." maybe not the numbers, but often the layout around a chip tells a lot about the chip... ![]() ___________ www.olliw.eu |
![]() FYI, someone on Leader Hobbies site has already said this: Quote:
Joined Sep 2009
but it's then NOT the cheapest MEMS gyro, and not the cheapest with a ISZ-650... ... the GA250 is significantly cheaper and it also uses an ISZ-650: http://www.olliw.eu/uploads/gyro-GA250-withanno-wp.jpg http://www.olliw.eu/uploads/gyro-GA250-circuit.png ![]() Thx, Olli ___________ www.olliw.eu |
well here is one major flaw that deters me from going with assan until this can be resolved and brian is no beginner either although in the vid flying was just regular so in this case 50 bucks is NOT "significantly more"
I flew the GA-250 on the two 450's, one from the first batch and one from the second batch. The GA-250 had stop problems on both heli's and on one heli, the servo fried (one I've been using for some time on two other heli's). I ran some servo temperature tests and the GA-250 was the hardest on the servos. I fitted GP780's to both of these heli's and they now fly perfectly.
The GA-250 is also known to blow out on reverse flight, something that will definitely cause a novice to crash, when they get in trouble. Anyway this thread is about the Leader Hobby GY520. There is another thread for the GA-250.
![]() Quote:
| Thread Tools | |
| Discussion Tarot GY650 MEMS Gyro | beenflying | Mini Helis | 83 | Nov 13, 2012 02:10 AM |
| Mini-HowTo New Hobbyking GA-250 MEMS gyro set up video | Cipriani | Beginner Training Area (Heli-Electric) | 0 | May 23, 2011 03:17 PM |
| Sold Turnigy DS480 servo + GA250 MEMS gyro | flying4food | Aircraft - Electric - Helis (FS/W) | 3 | May 15, 2011 05:37 PM |
| Question mini-mems GA-250 gyro | Florin777 | Electric Plane Talk | 2 | May 14, 2011 07:53 AM |
| Discussion Help with setting up ga-250 mems gyro | captaintomo | Electric Heli Talk | 2 | Mar 09, 2011 04:48 PM |
