Old Apr 11, 2012, 03:53 PM
JaggedEdge is offline
Find More Posts by JaggedEdge
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
Originally Posted by redblur View Post
Any good setup recomendation to hit high speed on turnigy or hobbyking motor
Im planning to get one arf model soon
Originally Posted by nighthawk0077 View Post
Would like to know this as well. I've already burnt two stock motors running on 4S.
I planned on going 4s from the start so pushing the stock motor hard wasn't really an option since I didnt want to lawn dart it on its first flight. None of the HK EDF motors have specs like EDFhobbies or Dons wicked setup have. Both Dons wicked setup and EDFhobbies 4500kv are a great buy.
Wicked Plus 4500kv $40: http://donsrc.com/cart/index.php?_a=...&product_id=93
EDF Hobbies 4500kv $40: http://edfhobbies.com/index.php?rout...&product_id=64
JaggedEdge is offline Find More Posts by JaggedEdge
Old Apr 11, 2012, 05:45 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
I also have a cheaper option, the regular Wicked 4000KV which is for $30 (not as cheap as HK but you will have it in a few days) and will be fine on 4S in the stock fan and it will be about 600 watts on 4S. The 4400KV I sell will most likely make the stock fan rotor fail as the motor is kind of too powerful for the stock fan. Even though the stock motor is like 4300KV it is a physically smaller motor than the regular 4000KV I sell so even with the slightly low KV of 4000 you still get the power as not so much is wasted to heat generation instead it is turned in to rpm which is what matters. The only thing I believe you will need to do is remove the four splines in the stock EDF housing to get the standoff adapter to fit into it. I do that with a Dremel tool and it takes a few second to grind them off.
Don
The Don is offline Find More Posts by The Don
Old Apr 11, 2012, 07:17 PM
RJJ is offline
RJJ
Find More Posts by RJJ
RJJ
Joined Oct 2011
I have purchased a stinger and a turnigy 2815-4800kv to put into it. Already have a turnigy 60a plush esc and will run 3s 11.1v 2200mah 45c packs as all my planes use these.
Should I upgrade the fan or edf unit as well.
Also could somebody post ail/elev/rudd max travel mm please and I can dial in low rates from there & expo.
I have a spare ar8000 that came with dx8, will it fit and should I plug each ail/ servo into separate channels or use y cable. Does anybody have mixes for knife edge etc for the dx8.
This is my 1st edf jet, fly a mpx blizzard, Stryker, zagi and a sebach 342.
Really looking forward to it, all help appreciated
RJJ is offline Find More Posts by RJJ
Old Apr 12, 2012, 09:10 AM
bonnie9496 is offline
Find More Posts by bonnie9496
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Originally Posted by JaggedEdge View Post
Hi all. Got my Sting64 together for a quick static test and I'm pretty psyched to fly it.
Cyclone Power turbojet EDF 4500kv Motor
6 blade
Hi JE, Was the Cyclone Power turbojet EDF a straight fit without adjustment?
bonnie9496 is offline Find More Posts by bonnie9496
Old Apr 12, 2012, 09:24 AM
redblur is offline
Find More Posts by redblur
Indonesia, Jakarta Capital Region
Joined Mar 2007
How about the fans? Need to be upgraded too?
redblur is offline Find More Posts by redblur
Old Apr 12, 2012, 12:50 PM
JaggedEdge's Avatar
Joined Dec 2007
Yes, I bought the complete unit and it slipped right in without any foam removal.
After screwing on the wing once there was no abnormal pressure on the duct causing fan to duct interference. Should work fine.
Old Apr 13, 2012, 05:18 AM
RJJ is offline
RJJ
RJJ
Joined Oct 2011
Can I use the turnigy 2815-4800kv motor on the cyclone Power unit ?
Also what difference will the seven bladed fan make ?
Basically want a balanced unit, any other suggestions or is the cyclone power unit the best for a straight forward replacement.
Old Apr 13, 2012, 05:23 AM
kakofonixx is offline
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
finally crashed my Stinger last week....
had two consecutive brownouts on my spektrum AR6000, and when I regained control I rushed a landing with the wind on stinger's back...
anyway... now I have a great setup and looking for a new, fast airframe, even considering to buy again the stinger!
kakofonixx is offline Find More Posts by kakofonixx
Old Apr 13, 2012, 08:12 AM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
Yes, if (when) I crash my Stinger I will proly' buy another. Usuall I would move on to something new BUT this one just flies great. It is just a strong platform with many power options. (motor,fan,batt). It has something special........
FireHawx is offline Find More Posts by FireHawx
Old Apr 13, 2012, 11:45 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Sorry to hear about your misfortune, but after such problems with your radio gear it's perhaps time to swap to something more reliable?
Ben D Wing is offline Find More Posts by Ben D Wing
Old Apr 13, 2012, 02:04 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
maybe a dsmx setup?
pavcon is offline Find More Posts by pavcon
Old Apr 13, 2012, 02:43 PM
J3 guy is offline
Find More Posts by J3 guy
Broken Arrow, Okla
Joined Oct 2010
Mine has had a few ground encounters with the stock set up. Trying to figure out the best CG and the hand launching has taken its toll at times
Would still buy another one, a stronger motor/fan would help the launching phase.
Will stick with 3 cells, since already have a few.
J3 guy is offline Find More Posts by J3 guy
Old Apr 13, 2012, 02:54 PM
JaggedEdge's Avatar
Joined Dec 2007
Even on 3s I'll never run a plane or heli without a separate BEC.
Old Apr 13, 2012, 03:08 PM
Joined Jun 2009
with my DX7 (dsm2) the AR6000 (dsm) acts as a full range receiver
me and many fellows modelers have done hundreds of flights (even on gliders, going very high) with this setup and never had a single glitch
the problems on my stinger started when I moved from 3 to 4S lipos...
had another two consecutive brownouts on another flight, but I managed to save the plane
in fact I use a separate BEC!! I don't know what caused those brownouts, the plane was close to me when happened and nobody else was flying at this moment
Old Apr 13, 2012, 03:31 PM
pavcon is offline
Joined Jan 2010
better do another range check of that receiver ..
if you pass the range test change your bec just to be sure.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 04:17 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 10:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 03:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 08:52 AM
