Old Apr 08, 2012, 10:48 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by bonnie9496 View Post
Can you please post your suggested 3S motor/fan combo for the Stinger you sell.
The 3S setup I have is about 380 watts on 3S, it is the Wicked 4800 motor. If you have a good high C rated lipo it will go over 400 watts. I don't have anything more than that which I typically suggest for 3S as the amps get really high for higher KV and that wastes power so I usually tell people to go up to 4S as the next progression from the 4800 3S setup. You could go the HET 6404 and the Wicked 4000 Plus motor that is ~450 watts on 3S but it is heavier as well as that is really meant as a higher powered 4S setup, but you would be running on 3S. By the way, that 326 watts your are measuring on the stock system is that the reading after about 15 seconds run time so it settles a little? I thought they were closer to 280 watts or so one settled down.
The Don is offline Find More Posts by The Don
Old Apr 08, 2012, 02:50 PM
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Nice! Any particular fan you'd recommend for this 3S/Wicked 4800 motor setup?
This sounds like exactly what I'm looking for.
Alpha10 is offline Find More Posts by Alpha10
Old Apr 08, 2012, 08:47 PM
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Did the test again. Seems to settle down to about 310-315w
What fan unit do you recommend?
bonnie9496 is offline Find More Posts by bonnie9496
Old Apr 08, 2012, 08:59 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
For the 3S/380 watt setup the fan I call the "EDO Type 2" is what I install the motors into.
Old Apr 09, 2012, 07:45 PM
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
Hi all. Got my Sting64 together for a quick static test and I'm pretty psyched to fly it.
Phoenix 80 esc
CC 10A BEC
AR6110E RX
Cyclone Power turbojet EDF 4500kv Motor
6 blade
Stock servos
35c Turnigy 4s 1800
550g. w/o batt.
761g. w/ batt
56A, 753watts.
Wish her luck.. She's going to need it.
JaggedEdge is offline Find More Posts by JaggedEdge
Old Apr 09, 2012, 07:53 PM
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
Phoenix 80 esc
CC 10A BEC
AR6110E RX
6 blade
Stock servos
35c Turnigy 4s 1800
550g. w/o batt.
761g. w/ batt
56A, 753watts.
Get a thrust tube in that thing, set the exhaust diameter to 49-51mm and you'll really notice a significant difference in top speed.
vanderbrander is offline Find More Posts by vanderbrander
Old Apr 09, 2012, 11:29 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Does fitting a thrust tube increase the current draw? If so , by how much roughly?
Ben D Wing is offline Find More Posts by Ben D Wing
Old Apr 10, 2012, 01:24 AM
Joined Oct 2009
Can the stock motor handle 4S?
I have a 50A esc from my Mirage 4000 which uses 4S.
AlvaSpeed is offline Find More Posts by AlvaSpeed
Old Apr 10, 2012, 04:38 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
I'm using the stock motor on 4s (no thrust tube) and it seems to be ok so far. I only use full throttle for take off and the occasional fast pass and climb out, so maybe that's why it's holding up.
Old Apr 10, 2012, 01:51 PM
Joined Oct 2009
Is it much faster with 4S/stock motor?
Old Apr 10, 2012, 03:39 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Quite a bit faster and it'll now do nice large loops and is able to climb vertically after a fast pass for about 200' before slowly losing momentum.
Old Apr 11, 2012, 11:53 AM
Indonesia, Jakarta Capital Region
Joined Mar 2007
Any good setup recomendation to hit high speed on turnigy or hobbyking motor
Im planning to get one arf model soon
redblur is offline Find More Posts by redblur
Old Apr 11, 2012, 12:49 PM
Joined Oct 2009
Would like to know this as well. I've already burnt two stock motors running on 4S.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Apr 11, 2012, 12:51 PM
Joined Oct 2009
Yup, avoid going vertical at full power.
Old Apr 11, 2012, 02:37 PM
porcia83's Avatar
Joined Jun 2009
Finally donked mine this weekend. 15-20 mph shifting winds. Had three flights trying to 3D this thing in the wind.... Came in on the last run, was about 20 inches from the ground ready to land and got a strong crosswind. I tried to counter it and pulled up and went in on the nose from about 5 feet. I now have a twisted beak. Going to soak it in hot water and blow dry, then reform it.
Or perhaps this is the reason to get my 4S Don's wicked set up going !
porcia83 is offline Find More Posts by porcia83
Latest blog entry: magnum
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 117 May 14, 2013 05:03 AM
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1239 May 03, 2013 08:18 AM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
