Old Mar 19, 2012, 11:05 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by kakofonixx View Post
flight report from this weekend...:
- the Stinger was faaaaaaaaast, easily over 200 km/h, unlimited verticals
flies like on rails but requires speed on turns - easy stalls wing tips (due to heavy load)
- Mercury edf screams like hell - decals peel off like hell!!
- nanos 65C perform super duper, little warm after flight, 4:00 mins of mixed fast/slow passes
what can I say! I'm impressed of this little bird!
after every flight people come to me and ask about it!!
ti sou eipa gia tis 65c ? ??
pavcon is offline Find More Posts by pavcon
Old Mar 19, 2012, 11:20 AM
kakofonixx is offline
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
kati ikseres
kakofonixx is offline Find More Posts by kakofonixx
Old Mar 19, 2012, 01:33 PM
pavcon is offline
Joined Jan 2010
kati ikseres
they are ready to power up my 10s Viper 90
Old Mar 20, 2012, 02:58 AM
stinger64 is offline
Find More Posts by stinger64
Joined Feb 2012
That is great news. Do not think you will get the Stinger any faster than that. Thought it is going to be heavy but if you are looking for speed, there is always some consequences. Enjoy.
stinger64 is offline Find More Posts by stinger64
Old Mar 20, 2012, 10:03 AM
tdogg77 is offline
Find More Posts by tdogg77
Joined Dec 2006
Got my Stinger 64 yesterday from Hobby King. It was packed very well, and I found it easy and fast to assemble. I used CA to fill some of the seams between tail surfaces but left the wing detachable. It is really a compact-sized model.
The foam appears to have been formed using the same injection molding process as the Multiplex planes, which says good things about its durability.
I was very impressed with the work that went into setting it up. The servos were perfectly centered with the control surfaces aligned properly. The hardware looks good and they used adjustable clevises, all appropriately secured with
It does need some weight added to the nose with the recommended 1800 mAh 3S battery.
All in all I'm happy and can't wait to fly it!
tdogg77 is offline Find More Posts by tdogg77
Old Mar 20, 2012, 10:45 AM
WillowBlade is offline
Find More Posts by WillowBlade
Singapore, Singapore
Joined Dec 2008
How to set up tail servos
Hello all,
Am really enjoying this plane. Would like to solicit some advice from the collective wisdom and experience here.
I just had a stripped elevator servo, and need to swop it out. Unfortunately, it is the one that is reversed.
Besides buying a reversed servo or using a servo reverser, is there a way to set up mixing in the DX8 TX to enable the use of a regular servo together with the Y-cable?
Alternatively, should I get rid of the y-cable fo elevators and setup the tail as twin elevator in the Tx, and attempt to sync them with mixing?
Thanks in advance for the help.
Cheers,
WillowBlade is offline Find More Posts by WillowBlade
Old Mar 20, 2012, 08:14 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Originally Posted by WillowBlade View Post
Hello all,
Cheers,
No need for servo reversers if you have a DX8. Go into the "wing type" menu and setup as dual elevators and dual ailerons. You can get rid of the Y harness and use separarte channels for the two elevator servos (elevator channel and one of the Aux channels - can't remember which one). No need for mixing - the DX8 takes care of it for you thru the wing type settings. You may need to go into servo setup and reverse one elevator servo. Once you set the linkages up the same (neutral), carefully measure the deflection of each surface at full throw, if there's a difference between the two surfaces you can adjust the amount of throw by changing the servo end points of travel until they are the same.
Hope that helped.
vanderbrander is offline Find More Posts by vanderbrander
Old Mar 20, 2012, 10:27 PM
pavcon is offline
Joined Jan 2010
i ve got the dx8 and i dont use a reverser. Just a y lead on the aileron and a 6channel orange rx
Old Mar 21, 2012, 12:44 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
There are some videos on youtube that shows you how to reverse the direction of the servo. You will have to open up the servo to do it. Just do a google search for the following:
reverse servo site:youtube.com
For me, I setup mine as Dual elevators and dual ailerons on my DX8. I have a mixed a so that i can toggle between normal mode (ailerons, elevator) and elevon mode.
btw, where do you fly your stinger in singapore?
Pavcon, Y cable doesn't work for the elevators if you stripped the reverse servo.
This is because one of the elevator servo has the directions reversed.
If you reverse the direction in the TX with a Y cable, both servos gets reversed and the previously correct elevator now goes the wrong way.
miketre is offline Find More Posts by miketre
Old Mar 21, 2012, 01:14 AM
pavcon is offline
Joined Jan 2010
sorry I wazs talking about the ARF.. never bought the PNP version
Old Mar 21, 2012, 02:52 AM
Joined Dec 2008
Thanks all for your helpful advice. Working well now. :-)
MikeTre - I fly the stinger at OHR on Sundays, when I can manage to get out.
Cheers.,
Old Mar 21, 2012, 11:58 AM
sirjosht is offline
Find More Posts by sirjosht
Joshua Taylor 15yrs
United Kingdom, England, Oxford
Joined Mar 2012
Stinger 64 motor upgrade?
Hello all, this is my first post on a rc forum so I'm new too all this.... anyway I've just ordered a stinger 64 pnf from hobby king and a upgrade 40-50 amp ESC and a 2200mah 4s battery, i hear i need to upgrade the motor, what would be a good choice? i also have this code for you guys to get the plane for $79 and i get a $5 refund so please use it http://www.hobbyking.com/buddy.asp?c...6-5D24977A5348
sirjosht is offline Find More Posts by sirjosht
Old Mar 23, 2012, 09:02 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
I thought I'd try some KE passes with the Stinger as it is my only EDF jet with a rudder. For a start, I took it rather high to be safe.
Knife Edge passes with the Stinger (2 min 57 sec)
Old Mar 23, 2012, 09:19 PM
NCRealEstateGuy is offline
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
Nice video... looks like you got real close to the ground at around 1:15. Anyway, i'll have to get up high and practice this. I am new to EDF.
NCRealEstateGuy is offline Find More Posts by NCRealEstateGuy
Old Mar 26, 2012, 03:27 PM
JaggedEdge is offline
Find More Posts by JaggedEdge
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
Just ordered one from Value Hobby for $89.
I have a stack of 4s packs so I'll be seeing how long it lasts like that.
...and also ordered a Cyclone Power turbojet EDF with 4500kv Motor from EDF Hobbies.
JaggedEdge is offline Find More Posts by JaggedEdge
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
