Old Mar 10, 2012, 02:47 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Thanks man
the runway is one of the best things we have.. but temps in summer and the fact thatthe wheat fields dry out at apoint it's like a period we cannot fly JEts.. not so much for the high temps but in case of a crash the fields will catch on fire
That's why I LOVE my electrics..
and will also start a build of a HK viper next week.. VERY high powered one
pavcon is offline Find More Posts by pavcon
Old Mar 10, 2012, 02:51 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
You just have to love electrics eh.
But they can start a fire just the same, had a wing failure on a prop job due to bad manufacture and the resulting crash caused the battery to catch fire on impact, I live in the country and we have the same problem in the summer.
clive45 is offline Find More Posts by clive45
Old Mar 10, 2012, 02:57 PM
pavcon is offline
Joined Jan 2010
I started learning to fly with an LX models F-22 two years minus 5 days ago,
all electrics all ducted fans
it was time for a turbine don't you think???
Old Mar 10, 2012, 03:01 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
There is nothing like the sound and smell of a turbine but you need a good runway and a pair of hands that would stop shaking enough to fly it, I am bad enough with electrics and don't have a runway to use withing a days travel from me.
Old Mar 10, 2012, 11:24 PM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
There is nothing like the sound and smell of a turbine ........
Hmm, when you been working with full size engines on a daily basis for the last 30 odd years the smell of Jet-A1 isn't that nice any more!
Ben D Wing is offline Find More Posts by Ben D Wing
Old Mar 10, 2012, 11:30 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
I can understand that...................
Also if I had been working on full size ones I don't know that I would want to play with small ones for pleasure.
Old Mar 11, 2012, 04:20 AM
kakofonixx is online now
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
Well done Pav! Nothing comes close to the feel and sound of a jet!
kakofonixx is online now Find More Posts by kakofonixx
Old Mar 11, 2012, 04:53 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
You've got me reminiscing now about when I worked on military stuff many years ago; The feel of a gas turbine is extremely intimidating when you're standing at the side of an engine whilst trying to adjust the RCU (reheat control unit). Your whole body feels like it's being vibrated into oblivion and breathing is a very strange and unnatural feeling. It's so bad that most people are physically sick for the first few times they carry out this operation, and some never get used to it. Model turbines are like Swiss watches by comparison, but can be just as deadly when things go wrong.
Anyway, returning to topic, the Stinger's stock motor is holding up well to 4s so far and this must be because I'm only using WOT for short periods. Time will tell........
Old Mar 11, 2012, 05:18 AM
pavcon is offline
Joined Jan 2010
good luck with that experiment on 4s. I have to find time to do some work on the stinger... That is just a thrust tube btw and also buy some more 4s packs
Old Mar 11, 2012, 06:31 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Is there a noticeable difference with a thrust tube using the standard motor and fan on 4s? Also, is the jet pipe as standard optimised for 3s, or would it be beneficial to fit a tube with that configuration too?
Old Mar 11, 2012, 07:30 AM
pavcon is offline
Joined Jan 2010
if you have descent power then 80 per cent fsa is the optimum. Now on stock power if you go a few units down it will give you more thrust to get u out of trouble but that will cost in top end speed. Now with 4s you got plenty of thrust so downsizing the nozzle even more will cost in top speed that is your goal.
So depending on the power youve got its 80% fsa +/-3%
Old Mar 11, 2012, 08:54 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Absolutely makes a BIG difference. I had a thrust tube in mine for the first half a dozen flights but took it out becasue I'm landing in snow and it keeps getting trapped behind the tube.
Once I took it out there was a noticable difference in top speed and even vertical performance.
The best exhaust diameter for this size fan is 49-52mm. If you run it on 4S or 3S, the exhaust diameter is the same.
vanderbrander is offline Find More Posts by vanderbrander
Old Mar 11, 2012, 04:30 PM
ex-racr is offline
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Have the red version, waiting on ESC
Hey guys,
I thought I'd show you what I just did today.
I put a 6-bladed rotor from the turbojet ducted fan onto the stock motor and shroud.
I couldn't mount the stock motor to the turbojet shroud as the motor tube depth was 20mm and the I.D. was 20mm.
The stock fan (Free wing) has a motor tube I.D. of 24mm and a depth of 16mm.
I did have to trim down the rotor slightly and sand/wear-in any irregularities of the shroud.
There's a lip of about 2mm around the rotor because of the differing motor tube diameters. This was the easier way to go, so I'll just deal with it.
On a partially charged pack and stock ESC I got about 26amps/300 watts, when held in my hand (very carefully!). The stock ESC got a little warm, but not hot.
The stock ESC might work, but I'd rather have a safety margin of a higher rated ESC.
Don't want to gamble and lose a nice plane.
Really don't want to buy another motor, so I'll see what happens with this set up, installed.
I took some pics of the assembled fan. There's a slight amount of vibration through mid-range, but is very smooth at full throttle.
Update: 300 watts, 26-27 amps on stock ESC, fully charged batteries. Thrust unknown. I was hoping for closer to 400 watts. Maybe when installed Only thing left to do is fly it and see what happens.
ex-racr is offline Find More Posts by ex-racr
Old Mar 19, 2012, 06:12 AM
stinger64 is offline
Find More Posts by stinger64
Joined Feb 2012
Kakofonixx I am burning to know what your Stinger is doing with those Nano 65c batteries.
stinger64 is offline Find More Posts by stinger64
Old Mar 19, 2012, 10:34 AM
Joined Jun 2009
flight report from this weekend...:
- the Stinger was faaaaaaaaast, easily over 200 km/h, unlimited verticals
flies like on rails but requires speed on turns - easy stalls wing tips (due to heavy load)
- Mercury edf screams like hell - decals peel off like hell!!
- nanos 65C perform super duper, little warm after flight, 4:00 mins of mixed fast/slow passes
what can I say! I'm impressed of this little bird!
after every flight people come to me and ask about it!!
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1589 Jul 13, 2016 05:57 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
