Old Dec 08, 2011, 11:00 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
3s. Delta connection. Pretty much the same as stock, except a lot more copper and 7 turns on every tooth instead of the way they come which is 7 turns on 6 and 8 turns on 3. All three motors were wound that way.
I tried winding with 23 gauge and got 11 turns. It didn't have enough power on 4s so I scrapped it. It would need 22 gauge to wind it perfect for 4s.
Steve C is offline Find More Posts by Steve C
Old Dec 09, 2011, 02:49 AM
FusionTiger is offline
Find More Posts by FusionTiger
Joined Dec 2007
Ok! I'll have mine wounded 7 turns with 21 gauge too! Any pointers? Did you removed the entire stator from the backplate to rewind?
FusionTiger is offline Find More Posts by FusionTiger
Old Dec 09, 2011, 11:54 AM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
The fact that you know how to rewind a motor and It doesn't blow up amazes me. I wouldn't even know where to start.
Killab is offline Find More Posts by Killab
Old Dec 09, 2011, 02:46 PM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
Lol, same here, to a noob like me, it's a 'dark art' right up there with alchemy and witchcraft
protocol is offline Find More Posts by protocol
Old Dec 10, 2011, 01:25 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Ok so quick ?, do the edf rotors come different pitches or is it just the number of blades.
Old Dec 10, 2011, 02:14 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
Different pitches and blade widths, not just number of blades...
Strike3 is offline Find More Posts by Strike3
Old Dec 10, 2011, 04:31 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Ok I've been looking at the 6404 het fan unit to run my stinger on 4s, but it doesn't give any specs. So was wondering.
Thanks for the info. Total newb to edfs
Old Dec 12, 2011, 11:55 AM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
I installed a 40 amp Eflite ESC in my brand new Stinger. This ESC was ran fine on my stock Stryker Q and still has the default settings. When I move the stick above half throttle, the motor stops running, and it won't engage again until I move the stick all the way down and the fan stops spinning. Does anyone know how I can resolve this issue?
sickwitit is offline Find More Posts by sickwitit
Old Dec 12, 2011, 12:38 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
have you set your throttle end points and the throttle travel ??
pavcon is offline Find More Posts by pavcon
Old Dec 12, 2011, 01:15 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
I had the same issue with mine. The esc worked fine with other motors at the default setting, just not with this one (stock stinger) motor. Mine winded up shorting out and sent sparks flying out of the rear of the plane. Looked really cool, but toasted the motor.
I then got the wicked 4000 motor from don and it worked perfect didn't have to change a thing. Just plugged it in and it went.
Old Dec 12, 2011, 06:41 PM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
My DX6i radio doesn't have "end points". But the throttle travel is set to 100%. Also, the E-Flite manual doesn't list how to set the throttle range (with the throttle stick) like my Hobbywing and Turnigy manual does.
Old Dec 12, 2011, 06:51 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
could also be a timing issue. default timing on the eflite esc is 15. try lower timing.
jim350 is offline Find More Posts by jim350
Old Dec 12, 2011, 07:41 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Would a higher timing cause it to short out and burn up? Cause I was messing with that on mine and that's what happen
Old Dec 13, 2011, 03:50 AM
jim350 is offline
Joined Aug 2011
btw what's your overall flying weight jimmy???
Sorry for the long delay in responding. i've been pretty busy of late and also had a week of not looking at anything R/C after i wrote off my hawk
Complete flying weight of my stinger64 arf with turnigy plush 80esc, erc2445-3700 edf motor, GWS64 fan, HXT900 servos, Orange 6ch receiver + satellite, Turnigy 4s 30c 3000mah LIPO
Plane weight w/o battery 560gm
battery weight 364gm
total weight 924gm
Old Dec 13, 2011, 11:57 AM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
total weight 924gm
How did you fit all that inside their? Please post pics showing where you installed the Rx + satellite, ESC, and the battery. I'm having issues with getting everything to fit in this small space.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
